#2619 |
Drives: '13 FRS - STX
The evap system performs a periodic pressure test of the gas tank, it's mentioned in the manual.
| The Following User Says Thank You to strat61caster For This Useful Post: | B T (01-11-2018) |
#2620 |
Drives: 2014 Scion FRS (Asphalt)
Not without e85. On pump gas you're going to be octane limited before you hit 300whp.
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
#2621 |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Yes, I'm well aware of that. But the question is whether the supercharger water pump is turning on by itself, or only when the evap system performs its pressure test. Does anyone know the frequency of the evap system test and how the frequency is determined?
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
#2622 |
Drives: 2017 BRZ
The water pump only turns on when the relay is activated. The relay is activated when 12v is sent to it through the evap connector. Either the relay has to have an intermittent short (seems unlikely given the descriptions), or the evap is telling the relay to activate the circuit at certain intervals while the car is turned off. If all that's true, the solution is to scrap the evap harness splice and find another switched 12v source to trigger the relay.
| The Following User Says Thank You to gtengr For This Useful Post: | shiumai (01-11-2018) |
#2623 |
Drives: 2013 FRS
Just about every other time I go into my garage I hear but evap pump going and/or the IC pump going. I do believe they are related since I often hear them together. The most times I've heard it in one day is 2-3 times, when I just happened to be in there, so figure it's a bit more than that each day. I have no idea what other dependencies the evap system has to kick off though, maybe it varies depending on conditions? |
| The Following User Says Thank You to 86fun For This Useful Post: | shiumai (01-12-2018) |
#2624 | |
#2625 | |
Judson
Drives: 15 FRS 6spd Edelbrock SC
| The Following User Says Thank You to jordanthebass For This Useful Post: | CSG Mike (01-12-2018) |
#2626 | |
Drives: 2017 860 SPRINTEK
#2628 |
Drives: 2017 BRZ
| The Following 3 Users Say Thank You to Barefootdan For This Useful Post: |
#2629 |
Drives: frs
I prefer do the trim rather than electrical issues. But thanks for the info mate
#2630 |
Drives: Toyota 86 2017 TRD Modded
I made it fit on my 2017 cuz I had to lift a pin on the alternator that allowed plugins to fit by. I'll have to take a picture of the fitment later on when I get the chance.
![]() Sent from my SM-G950U using Tapatalk
Life is like a car, you press the gas to go, steer around all the things blocking your way through Life, and park it when you reach your destination
#2631 |
Drives: Toyota 86
What kind of exhaust setup is everyone running?
Currently on stock exhaust and want to get a header/catback combo... Would like a system that isn't super loud but it doesn't have to be as quiet as stock. Also, it's worth mentioning that my car is RHD. |
#2632 |
Drives: 2017 BRZ
Any word on when the 2017 kits are to be released?
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 05:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 03:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 11:09 PM |
