Old 01-18-2018, 12:50 AM   #15
norcalpb
norcalpb's Avatar
Originally Posted by gtengr View Post
Here's an example of what I'm thinking about using the 2019 ZR1. Ignore for a second that its hood vent caused a dramatic change to the high pressure zone in the center of the windshield. Just look at the area I zoomed in on and notice how the high pressure area on the windshield ends at roughly the height of the back of the hood, and what's under that point is low pressure.
Don’t our cars come with rubber vents in the area you are circling?
Old 01-18-2018, 01:20 AM   #16
Brink
Drives: 2017 BRZ
Originally Posted by Pat View Post
Defeats the purpose? What is the purpose?
To look like carbon fiber of course. Gotta show off that nice CF weave.
Brink is offline   Reply With Quote
Old 01-18-2018, 02:39 AM   #17
Hello OP ....... you still with us ....??
Old 01-18-2018, 02:41 AM   #18
Yep, I'm still waiting for that since post #2.
Old 01-18-2018, 05:04 AM   #19
Kodename47
Kodename47's Avatar
Drives: UK GT86
The cowl piece is shielded from airflow, so I think that's debatable. I think it's likely a low pressure area exists in the airflow void where the vents would be. Also need to consider there is an underhood pressure component, and the underhood air is hotter. Seems you should know that once you cut a vent into something that the pressure zones can easily change and need to be reanalyzed.
This was proven years ago on here, probably find the threads if you have a look about.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-18-2018, 09:54 AM   #20
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I see what your saying.
Lunatic is offline   Reply With Quote
Old 01-18-2018, 11:36 AM   #21
Pat
Pat's Avatar
Drives: 2023 BRZ
Believe it or not, the original purpose of carbon fiber was not to be used as automotive jewelry. I wouldn't assume everyone thinks that is of course its purpose.
Old 01-18-2018, 09:31 PM   #22
gtengr
Drives: 2017 BRZ
I looked at it today but didn't look closely at the edges. I think I know what you're talking about but I'll have to reinspect. The cowl trim piece serves as a big inlet chamber for the HVAC, so any venting except for the very edges would get sucked into the cabin.
gtengr is offline   Reply With Quote
Old 01-18-2018, 09:32 PM   #23
gtengr
Drives: 2017 BRZ
I searched a few variations of "windshield cowl" and couldn't find anything.
Old 01-18-2018, 10:13 PM   #24
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Talking
@Tcoat
What about cutting the side fender open into engine bay.... I know those are not that effective but it should work to a certain point too?
The Following User Says Thank You to chaoskaze For This Useful Post:
Leonardo (01-18-2018)
Old 01-18-2018, 10:35 PM   #25
Gunman
Drives: 2019 Mazda Miata RF
Cowl/base of windscreen, is a high pressure area.
The Following User Says Thank You to Gunman For This Useful Post:
Pat (01-19-2018)
Old 01-18-2018, 10:40 PM   #26
Lunatic
Lunatic's Avatar
Originally Posted by chaoskaze View Post
@Tcoat
Like I did.
The Following 2 Users Say Thank You to Lunatic For This Useful Post:
chaoskaze (01-19-2018), Gunman (01-18-2018)
Old 01-19-2018, 01:17 AM   #27
gtengr
Drives: 2017 BRZ
I saw that model and I don't think it's detailed enough to check. I've already discarded the idea due to HVAC interference, but you realize the vent would be recessed under the back of the hood about 4 inches or so towards the front? And the CFD model doesn't consider the radiator airflow, which is the target of the venting. If airflow into the engine compartment is high enough, the firewall can create a high pressure zone too. I'm guessing that is what makes the hood dance at speed.
Old 01-19-2018, 01:33 AM   #28
@Tcoat
If I recall proper, that had been tried .....
HELP: hood pins/latches on carbon fiber hood scubie.brz Cosmetic Modification (Interior/Exterior/Lighting) 1 05-13-2016 01:10 PM
Custom GT 300 hood vents/heat managment kuczynskika Cosmetic Modification (Interior/Exterior/Lighting) 7 10-21-2015 01:00 PM
Florida: Trade Silver hood for Black hood 555 Exterior Parts (Aero, Lighting, Etc.) 0 05-06-2015 11:52 AM
