Old 10-29-2009, 08:09 PM   #43
White Comet
Resident Skeptic
White Comet's Avatar
Drives: '04 WRX
Originally Posted by OldSkoolToys View Post
From what I've gathered, thats about the same psi range for any NA engine turned turbo.
Really depends on the tolerances of each individual engine. PSI isn't what matters in terms of stressing the engine's parts, the HP a given psi produces does.
White Comet is offline   Reply With Quote
Old 10-29-2009, 08:58 PM   #44
joshuo
Drives: 2002 audi TT quattro
Usually on a turbo NA engine (lol) the rods are the first to go.
So torque would be the biggest limiting factor there.
joshuo is offline   Reply With Quote
Old 10-29-2009, 09:52 PM   #45
Shadowsong6
Shadowsong6's Avatar
Drives: 2014 Ford Mustang
Usually people who boost end up replacing rods/pistons eventually though, if not as they were having the snail put on.
Shadowsong6 is offline   Reply With Quote
Old 10-29-2009, 10:32 PM   #46
White Comet
Resident Skeptic
Drives: '04 WRX
Technically, torque would be the limiting factor on all engines, not hp as I previously stated. HP itself is a function of torque, after all.
Old 10-29-2009, 10:44 PM   #47
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
and it's always amazes me how Rally car only have 300hp, but have like 650Nm of tq.
Old 10-29-2009, 10:47 PM   #48
White Comet
Resident Skeptic
Drives: '04 WRX
Low end grunt, baby. That, and they have those restrictor plates...
Old 10-30-2009, 01:48 AM   #49
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
if i'm not mistaken, often times rally cars don't run wastegates, they just let the boost spike as high as it will go, and it trails off at higher rpms due to the restricter.
as far as turbo'd n/a engines, it's alllll in the tuning (well, mostly). you could run 5psi and blow your ring lands to pieces, or you could 10psi and have a safe, reliable engine. tuning, fuel, and maintenance.
-Mike
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 10-30-2009, 08:49 AM   #50
scape
scape's Avatar
Drives: yaris
i'd think any extra weight on the front of this car will diminish other performance characteristics; if engine swap is really something of interest, I could possibly see the 2.5L h4 turbo getting stuck in there as a first choice
scape is offline   Reply With Quote
Old 10-30-2009, 05:19 PM   #51
Shevon
Shevon's Avatar
Drives: Accord Coupe
check this out... what motor does the exige scura use heres a ling to the specs it mentions VVTL-i wouldnt mind that motor in the FT86...http://www.conceptcarz.com/vehicle/z...ige-Scura.aspx
Shevon is offline   Reply With Quote
Old 10-30-2009, 06:16 PM   #52
ichitaka05
Site Moderator
ichitaka05's Avatar
It's a 2ZZ-GE engine iirc.
and don't forget it's SC, that's why it's putting 260hp
Anyways, isn't Exige GT3 has more hp and performance?
Old 10-30-2009, 06:39 PM   #53
Shevon
Shevon's Avatar
I want lol
Old 10-31-2009, 07:28 PM   #54
4agze
4agze's Avatar
Drives: Toyota Corolla SR5
Lotus Exige GT3 spec:
Engine
Toyota supplied 2ZZ-GE, 1796 cc I-4, DOHC with VVTL-i and Lotus T4e engine management system, Roots-type Eaton M62supercharger and intercooled[6]
Bore/Stroke 82.0 mm / 85.0 mm
271 bhp (202 kW; 275 PS) @ 8000 rpm[6]
190 lb·ft (258 N·m) @ 7000 rpm[6]
Compression Ratio: 11.5:1
Transmission
C64 6-speed, close ratio with uprated clutch and cover, open differential[6]
Gear ratios I/II/III : 3.116:1 / 2.050:1 / 1.481:1
IV/V/VI : 1.166:1 / 0.916:1 / 0.815:1
R/final drive : 3.250:1 / 4.529:1
I was going to Buy a used exige s next year but after seeing the FT86 concept i want to see the numbers first, if this car promises light weight & performance on a cheaper price why not. i test drove a 2005 exige s and it was good wow complain only was the brakes but thats an easy fix
4agze is offline   Reply With Quote
Old 10-31-2009, 07:31 PM   #55
ichitaka05
Site Moderator
ichitaka05's Avatar
Engine
Transmission
just don't expect Eaton SC come in FT-86 lol
Old 11-02-2009, 08:47 PM   #56
Shevon
Shevon's Avatar
O you know TRD will throw thier own on there if they did.
