| Software Tuning Discuss all software tuning topics. |
#15 | |
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
https://www.toyota.com/content/ebroc..._ebrochure.pdf
NARFALICIOUS
Noob Poster 1988 | 2016 |
#16 | |
Well look at that! I never Knew about the SST. So did it just show up with the 17s? I stand corrected.
#17 | |
SST is supposed to cut fuel while braking and gas at the same time.
NARFALICIOUS
#18 |
Drives: Toyota 86
guys thanks for helping me..
i know how to burnout and also i know this car isnt good for burnout like V8 american muscle car.. i did that before with manual trans.like camaro,mustang,z370 and... but i cant do it in this car. you know.i go with pedal dance.i push the gas pedal and break lightly ,but ecu went to stop the car.. im angry... is there anyone knows how to off that damn tech? i love this car..i can drift..but burnout is a wish to me.. SST = Smart stop technology >> when you push gas pedal and break at the same time, ecu goes to reduce the speed until the car stop. help help Last edited by Pouria; 01-12-2018 at 01:08 PM. |
#19 |
Drives: 2014 GT86
Oh, finally understand what you mean. And probably you want burning tires moving as little as possible, thus brake usage. What's wrong with doing donuts while drifting in circles?
BTW, i'm not that sure, that it's electronics that stop you. In most cars brakes are more powerful then engine (especially less powerful one then in american muscle cars). Tried simply brake less while being in lower gear? LOL, spill some oil under rear tires. I know that no SST stops my car, when i want to quick dry brakes after carwash and press brakes while going in 1st or 2nd for some heat in them. Resulting speed just depends on how i modulate brake & throttle pedals. |
#20 |
Drives: 2013 BRZ Limited / 2024 G70 3.3T
lol, that brought back a memory...in high school my buddies and I all worked at service stations (back before they were just gas stations)...if we got bored we'd spill some gas out on the ground and spin the rear wheels of our motorcycles in it. Plenty black smoke...pretty busy street, got a lot of 'you f*ckin idiots' looks. lol.
#21 |
Famous Potatoes
Drives: '15 ultramarine
didn't the whole SST thing come about because of the runaway Prius thing a few years back?
| The Following User Says Thank You to Sapphireho For This Useful Post: | Summerwolf (01-12-2018) |
#22 | |
I think therefore.....
Drives: Toyota 86 860 Halo White (Manual)
I could be paranoid however I suspect if you ever have a warranty claim this may come back and bite you in the ass.
May the N.A. force be with you.
| The Following User Says Thank You to Darth Khan For This Useful Post: | Summerwolf (01-22-2018) |
#23 |
Drives: 15 BRZ LTD, 05 FXT
Yeah try some tire shine on your rear rubber. That oughtta get things moving.
#24 | |
Drives: 2017 Toyota 860 Halo white
Sent from my Pixel XL using Tapatalk |
| The Following User Says Thank You to Wolf359 For This Useful Post: | Tcoat (01-13-2018) |
#25 |
More of an off shoot from autonomous cars.
#26 |
Huge E85 fan!
Drives: 2016 Scion FRS
http://www.ft86club.com/forums/showp...55&postcount=3
We all have the SST. I haven't tried a brake stand but the brochure says it isn't activated if you hit the brake first and is only activate at speeds over 5 MPH. So maybe try this to trick the system- start the brake stand and when it starts to reduce power, if the speedometer says over 5mph, let off the gas but keep the brake down then hammer the throttle again.
#27 | |
Drives: Crapcan
I have done a brake stand with my car once, and have seen others do it. Must be more perimeters to the SST then that. |
#28 | |
Time to turbo it! |
| Tags |
| 2017 86, smart stop technology, sst |
| Stop Tech Sport Kit | akuhei | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 26 | 07-10-2018 09:06 PM |
| Disable turn signal light when not blinking? | Avo1789 | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 10-09-2015 08:46 PM |
| Disable Turn Signal DRL? | 636 | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 09-14-2014 08:09 AM |
| used stop tech pads f/s | Grip Ronin | Brakes, Suspension, Chassis | 3 | 04-01-2014 12:32 AM |
| Smart Stop Technology...how does it work | HachiRokuBoy | Engine, Exhaust, Transmission | 6 | 06-23-2012 11:50 AM |
