Old 01-07-2018, 05:17 PM   #1
xenarc
xenarc's Avatar
Drives: 2017 SUBARU BRZ
Morimoto XB LED fog lights on 2017 BRZ
So being new to the BRZ I’ve been doing a lot of digging on what parts fit on the 2017 BRZ. I am about to order the Morimoto XB led fog lights but I see 3 different ones, SCION FR-S, Subaru Morimoto and Subaru GR WRX on the theretrofitsource.com website.
Can someone confirm if these fit the 2017 bumper:
https://www.theretrofitsource.com/as...to-xb-led.html
Also, will I need any screw clips or mounting brackets for the fog lights?
xenarc is offline   Reply With Quote
Old 01-07-2018, 06:08 PM   #2
Si_Chris
Drives: 2016 ISM BRZ Limited, 2000 Civic SI
Those will not fit on the 2017+ models. I have the Morimoto XB LED foglights on my 2016, and they have a 4 bolt hole/bracket design as opposed to a 3 bolt hole/bracket design of the 2017+ BRZ and 86.
You will need something like these for your car:
http://www.ft86speedfactory.com/suba...l#.WlKZDN-nHSE
Si_Chris is offline   Reply With Quote
The Following 2 Users Say Thank You to Si_Chris For This Useful Post:
eastendraceshop (01-22-2019), SkyeHack (01-07-2018)
Old 01-07-2018, 06:36 PM   #3
SkyeHack
SkyeHack's Avatar
Drives: 2018 BRZ tS
If only they sold fog lights for the 2018 BRZ tS.
SkyeHack is offline   Reply With Quote
Old 01-08-2018, 12:03 AM   #4
xenarc
xenarc's Avatar
what about the Winjet set on EBay?
https://m.ebay.com/itm/Winjet-2017-S...%257Ciid%253A1
Old 01-08-2018, 12:53 AM   #5
Si_Chris
Originally Posted by xenarc View Post
Those will fit, they have the 3 bolt bracket design.
Old 01-08-2018, 08:22 AM   #6
xenarc
xenarc's Avatar
Thank you guys, I have purchased the Winjet kit. I did not want to dish out so much money on fog lamps. I really had my heart set on the Morimoto XBs but i guess ill have to wait until TRS makes them with the correct bracket.
Old 01-10-2018, 03:03 AM   #7
NRXRaptor
Honestly I wouldn't get them due to how that plastic covers the foglight lens with the morimotos in particular. Here's what they look like on my 2016 BRZ. I like how the lens housing is black which matches my new headlights. Don't have a pic on hand with the new headlight beam pattern, but it is not as good as stock. The stock ones were really nice. The stock ones didn't have sequential indicators though
NRXRaptor is offline   Reply With Quote
Old 01-28-2018, 08:54 PM   #8
Si_Chris
You need to aim your Morimoto foglights up a bit, there is an adjustment knob on the back. Yours are basically pointing at the ground.
Old 01-30-2018, 01:16 AM   #9
NRXRaptor
I know. I like the pattern it makes
Old 01-30-2018, 07:56 AM   #10
Si_Chris
Mine was like that at first. I found out that they do go way wider if you adjust them up if you're thinking of a wider beam pattern.
Old 01-31-2018, 12:50 AM   #11
NRXRaptor
I thought about it, but I don't really need it and I like how they look. Sometimes I have to commute on rural highways at night and I just use highbeams
My opinion/experience is that foglights on a car with projector headlights are decorative. The stock bixenon projectors that came with BRZs are outstanding. I didn't realize how great they were until I replaced them with the Intec ones. The Subaru ones spread light very wide whereas the Intec ones concentrate them more in front of the car. In terms of practicality, Subaru's are better, but the Intecs are full led and have a sequential turn signal. When I replaced the foglights I realized that the stock ones were worse than a flashlight in addition to not matching the color of the stock headlights. I'm not wanting for additional light, moreso just to match the color of the foglights and headlights. They are much closer now.
WTB: 2017 Tail lights swarb Want-To-Buy Requests 10 08-19-2018 02:33 PM
FS: Morimoto LED Fog lights HeresMyMind Exterior Parts (Aero, Lighting, Etc.) 1 01-10-2018 10:32 PM
FOUND PLEASE DELETE pleasurevictim Want-To-Buy Requests 0 12-31-2017 01:55 PM
Install Morimoto Retrofit kit into Winjet lights? Khyron686 Cosmetic Modification (Interior/Exterior/Lighting) 2 03-17-2014 06:55 PM
Stock FR-S Headlights & Tail Lights, Morimoto Elite HIDs, and OEM Mud Guards tbox Exterior Parts (Aero, Lighting, Etc.) 14 01-11-2014 03:18 PM
