#15 |
The high humidity is probably caused by respiration. The simple solution is do not breath while in the car with the windows up. But murdoc has an easier way to reduce the in cabin humidity before leaving the car to cool down.
| The Following 2 Users Say Thank You to ls1ac For This Useful Post: | Cole (01-06-2018), Ultramaroon (01-07-2018) |
#16 |
Drives: 2014 BRZ
frost/condensation is from moisture on the inside of the vehicle getting cold/freezing at low temp.
Best way to avoid this is to cover the floor in towels to soak up the moisture/snow/ice from your boots/shoes and before you sit in the car each time, pull the towel out, shake out what is on it, put it back over the carpet/floormat and then sit in the seat and kick off as much snow from your boots as possible before turning and putting your feet into the vehicle. Doing this every time will keep the floor dry/clean. I do this every time I go on trips in winter or summer to keep the interior from getting messy. Just lay a towel down, get it dirty/wet and shake it off or take it in and dry it. |
#17 |
My car gets this every single time it is cold. My mats are saturated since I drive it at least twice a day when it is snowy. I get at least two coffees which pump moisture into the air every single day. The snow brush is usually still covered in snow when I put it in.
None of this is going to harm anything in any way and it will all dry up as soon as the weather is nice enough to drive with the windows open. People in humid places have a much larger exposure to moisture every day but since it doesn't make a pretty pattern they just can't see it. The inside of the car is manufactured using plastic, metal and fabrics made to withstand such things. It is not made of sugar that will spontaneously disintegrate because of exposure too a little moisture.
| The Following User Says Thank You to Tcoat For This Useful Post: | navanodd (01-07-2018) |
#18 | |
[insert cool phrase here]
Drives: BRZ Premium
His car is going to catch on fire and there is nothing we can do about it.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| The Following 2 Users Say Thank You to Mr.ac For This Useful Post: | strat61caster (01-07-2018), Ultramaroon (01-07-2018) |
#19 |
Drives: '13 FRS - STX
Run the defroster
#20 | |
![]() ![]() humfrz ********************** AC's mobile wrecking pick up and civic delivery Anywhere in North America ....... our car carriers will deliver you a Honda Civic (within your price range) and pick up your junk (or soon to be junk), FR-S or BRZ. Just contact us, give us a few details that would allow us to set a price range for your Civic. We already know the value of your FR-S or BRZ is zero. ******************* |
| The Following User Says Thank You to humfrz For This Useful Post: | Mr.ac (01-07-2018) |
#21 |
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | humfrz (01-07-2018), strat61caster (01-07-2018) |
#22 |
| The Following User Says Thank You to humfrz For This Useful Post: | strat61caster (01-07-2018) |
#23 |
Because compromise ®
Drives: Red Herring
To beat the meat....beat the meat.
#24 |
You can pick your friends and you can pick your nose but you can't pick your friend's nose.
#25 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
How an elephant got in my pajamas, I'll never know.
"I gotta rock." -- Charley Brown |
| The Following User Says Thank You to bcj For This Useful Post: | Tcoat (01-07-2018) |
#27 |
........ snap out of it ...........![]() humfrz |
#28 |
Drives: Red Herring
I refute your assertion.
| Tags |
| buy a civic, problem solved |
| Which interior fuse slot to install led interior lighting in? | btan219 | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 06-27-2017 11:43 PM |
| Cfig's Emma Frost | cfig21 | Member's Car Journals | 62 | 12-11-2016 04:19 AM |
| DCW Carbon Fiber interior items! Center console Plaques / Interior panels | doggy | Interior Parts (Incl. Lighting) | 143 | 10-11-2013 12:17 PM |
| LED interior conversion kits (interior), USA stock & warranty | WTF | Interior Parts (Incl. Lighting) | 0 | 05-22-2013 11:17 PM |
| Sun shade / windshield cover for ice/frost/snow | sastexan | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 8 | 11-29-2012 11:27 AM |
