Old 01-06-2018, 01:13 PM   #1
becausethexo
Drives: Subaru BRZ 2015 Limited
Interior frost?
Is this normal? Found this just now never seen anything like it, albeit it's -21 celcius outside right now. Should I do anything?
becausethexo is offline   Reply With Quote
Old 01-06-2018, 01:27 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
It's totaled. Sell it before it catches fire. Buy a civic. Problem solved.
The Following User Says Thank You to Mr.ac For This Useful Post:
Captain Snooze (01-07-2018)
Old 01-06-2018, 01:46 PM   #3
cjd
cjd's Avatar
Drives: 2017 BRZ
That just means the humidity inside the car was high enough to produce frost as the car cooled. Don't use a hookah inside the car in the winter any more? Could also be something you cleaned the car with left residue that facilitated this?
I've never noticed it on anything other than windows. It's been hovering around the same temperature off and on here the last few weeks.
Also, totaled. Time to take the bus.
Old 01-06-2018, 01:46 PM   #4
becausethexo
Omg , it's that rare of an occurrence?
Anything I should do in the meantime? I'm so sad right now
The Following User Says Thank You to becausethexo For This Useful Post:
Ultramaroon (01-06-2018)
Old 01-06-2018, 01:55 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I am able to keep mildew out of my project cars in Oregon with a 100w light bulb...
I wonder how many BTU's it would take to combat -21c?
OP, I assume that you do not have a garage.
I LIKE TIRES!
Old 01-06-2018, 01:56 PM   #6
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Buy one of those flame resistant flame suits.
Leonardo (01-06-2018)
Old 01-06-2018, 01:58 PM   #7
ST185RC
Drives: White Out FR-S
Get damp rid and put it in the car. During summer time, the calcium carbonate will be a good desiccator. In the mean time you cant do much except scrape off the frost and throw it out. It'll mean you'll have rusty metal where there's exposed metal, like bolts under the carpet etc.
ST185RC is offline   Reply With Quote
Old 01-06-2018, 02:00 PM   #8
cjd
cjd's Avatar
Drives: 2017 BRZ
Buy lots of earplugs for when you gut the exhaust on your new civic and can't stand the sound.
More seriously - make sure to get the car up to temp and run the A/C with the heat (I think this happens by default as often as not), which will help dry things out. Be careful in the spring as things warm up - it may very well be excess moisture (or soaked out wet) somewhere that really should be dried properly; if it's into the carpet, that can cause mildew and mold.
Running the A/C with heat can still help with this.
The Following 2 Users Say Thank You to cjd For This Useful Post:
humfrz (01-06-2018), Ultramaroon (01-06-2018)
Old 01-06-2018, 02:13 PM   #9
navanodd
Drives: 2013 BRZ Sport-tech WRB
May want to take your floor mats indoors and let them dry out completely. Often run into this in the winter from tracking snow into the car and it creating a moisture source.
Haven't seen it on the lower dash panels before, but its the same thing as when the windshield does it. If you have the chance to park at a spot warm and dry, leave the windows cracked open slightly to allow evaporation to occur and the moisture to leave the car.
navanodd is offline   Reply With Quote
Old 01-06-2018, 02:26 PM   #10
Cole
Not a troll
Cole's Avatar
Crack your windows a tiny bit overnight.
My windows have been freezing on the inside pretty bad this winter (first winter of not having the car garage parked overnights) and cracking the windows a touch has helped.
Cole is offline   Reply With Quote
Old 01-06-2018, 03:38 PM   #11
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
I usually run my heater on high with the windows down before turning off the car for the night to prevent this.
I had it happen the other day after having two people in the car and the heater on recirculate and not airing it out.
murdoc is offline   Reply With Quote
Old 01-06-2018, 04:00 PM   #12
I suggest you get a room next time .......
BirdTRD (01-06-2018), cjd (01-06-2018)
Old 01-06-2018, 04:13 PM   #13
JD001
JD001's Avatar
Drives: Subaru BRZ
I was going to suggest that the OP wears a carbon filter mask and to stop farting in his car..
The Following 2 Users Say Thank You to JD001 For This Useful Post:
Cole (01-06-2018), humfrz (01-06-2018)
Old 01-06-2018, 04:27 PM   #14
FirstWinter
Drives: Car
Quick get it a blanket and some hot cocoa with a splash of bourbon. That'll warm her right up.
FirstWinter is offline   Reply With Quote
buy a civic, problem solved
Which interior fuse slot to install led interior lighting in? btan219 Cosmetic Modification (Interior/Exterior/Lighting) 11 06-27-2017 11:43 PM
Cfig's Emma Frost cfig21 Member's Car Journals 62 12-11-2016 04:19 AM
DCW Carbon Fiber interior items! Center console Plaques / Interior panels doggy Interior Parts (Incl. Lighting) 143 10-11-2013 12:17 PM
LED interior conversion kits (interior), USA stock & warranty WTF Interior Parts (Incl. Lighting) 0 05-22-2013 11:17 PM
Sun shade / windshield cover for ice/frost/snow sastexan Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 11-29-2012 11:27 AM
