Drives: frs
Intermittent power steering
Did some quick searches in the Issues/warranty/recalls/TSB. Didn't see much on intermittent power steering function and intermittent "pulling" in one direction or the other (except some Australian or UK recall articles... sounds almost exactly the same though).
2014 BRZ with less than 60k miles. Car has been very reliable, but this has sprung up since as early as approx. 22k miles. It seems to be more sensitive in the cold (perhaps below 40 degrees F). Even if the power steering is working, it often pulls hard (not tractor-level "hard" here, but noticeable in a car like the 86) when I first start driving (first few minutes on slow roads). The problem has lasted as long as an hour, or sometimes just happens for a couple minutes. Should I just go pester a dealer for a new steering rack? I question their ability to get the car back to me in better condition. I've not been impressed the last few years with most repair outfits (dealer or otherwise) on any sort of mechanical endeavor. It is quite rare... but I'd hate to see it get worse. Many thanks |
#2 |
Drives: Subaru BRZ
My car is a 2014, it's going back to Subaru this coming Friday to have the power steering ECU replaced (Warranty recall). I haven't actually experienced any issues with the power steering but then it only has 7.5k miles under its belt.
#3 |
Drives: frs
The steering issues are not "critical" so to speak (to me), but they are annoying.
I'm in the U.S. so I'm not sure if there is a similar recall in place. Most cars I've had have many many miles, so chasing recalls and warranty claims is new to me. If I had accurate wiring diagrams and decent schematics I'd just figure it out, or I'd tolerate it if time didn't allow. Still... 1st owner, paid the premium... would like to see it somewhat bug-free until that 100k mile mark. |
#4 | |
![]() I'd suggest you have the dealer check it out. Why? * why put up with a pain like that * if it should happen to go south (when you want to turn north) that might not turn out good humfrz |
#5 | |
1. When, after acting up, it kicks in, does it do so like a light switch? 2. Does it tend to act up turning in one direction, or does it not matter? 3. "Not tractor-level hard" is vague. Is there some assist but at a lower torque, or is the servo as dead as if you had pulled the power steering fuse?
#6 |
Drives: frs
1. Instant. It is electrical for sure. That assumes it completely cuts out. Usually it does random pulls left and right. I can tell it's electrical because it isn't always consistent and it is intermittent. When the power steering is gone it feels perfectly consistent.
2. I don't have to turn to notice. If I let go of the wheel at 30 it will pull pretty abruptly to the right, or maybe the left, i.e. zero consistency. Sometimes I can turn it hard one way or the other and get strange feedback (like it doesnt pull to the right anymore after I rack it hard to the left). 3. It is either dead with the dash light on, or it has inconsistent feel. I only notice it at the start of a drive. Usually on the highway it's completely gone. I work with machines ALL day long. I notice when something isn't quite working right. Obvious when it cuts out and throws the dash light, but the frustrating part is when it gives strange pushes and pulls buzzing down the road at 35 before you hit the highway. Guess I might have to bring it in finally. Will let all know how it goes. |
#7 |
Something could be wrong with the Power Steering ECU. The motor is speed sensitive so it's lighter (more assist) at slow speeds but if there's an issue with the ECU it may be confused somehow. Internals of the rack or bent tire rod end bar could cause issues but would be more constant. The steering rack is manual so no fluid thus no hydraulic seals. The motor is the assist.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#8 | |
If at a standstill with the engine off you wiggle the steering wheel, you'll notice some left to right play before the wheels start turning. That's the "torque sensor" The control error signal corresponds to how hard you yank on the wheel. The controller responds by driving the servo motor to eliminate the error. the rotation angle sensor tells the controller just that, the steering angle. I don't know exactly the logic of the control system but a loose plug or intermittent connection could cause what you describe.
#9 |
Drives: FT86
Their was a recall out on power steering , well in australia anyway they replaced power steering control unit and sensors free
#10 |
Drives: frs
Thanks for all the responses.
If it helps anyone in the future... Got a front end alignment with the new tires and the problem has not surfaced since. |
| The Following 2 Users Say Thank You to FencebusterTDI For This Useful Post: | humfrz (12-31-2017), Ultramaroon (12-31-2017) |
#11 | |
Now, folks, go figure this. mrs humfrz's Saturn's steering was acting up (it's a hydraulic system). It was creaking and groaning when the wheel was turned. So, I took it into the dealer for a look see. $100 later, they told me the car needed a new power steering pump, hydraulic lines and steering rack ......which they could install for $2,200........ ![]() Hey, since I'm on a fixed income and too lazy to do my own work ...... I decided to just live with it. But, I then decided to take the car up to my buddies at the local auto shop and have them take a look see. They recommended adding power steering fluid, new tires (OEM had 45,000 miles on them), new brake pads, two new front rotors and a four wheel alignment. Well, I knew that deferred maintenance stuff should be done, so I said OK. Now, guess what, the steering works perfectly ........ ![]() So, I got the steering fixed, new brake pads, new rotors, new tires and an alignment all for $1,300. So much for the dealership's diagnosis .......... ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (12-31-2017) |
#12 |
We went way down the wrong road with this one. Yikes!
#13 |
| Power Steering | rosol16 | Issues | Warranty | Recalls / TSB | 15 | 12-15-2015 10:44 AM |
| Where is our power steering ECU? | brillo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 10-24-2015 01:38 PM |
| power steering | ender2664 | Engine, Exhaust, Transmission | 32 | 03-21-2015 05:16 PM |
| Intermittent buzzing from below the steering wheel? | brzninja | BRZ First-Gen (2012+) — General Topics | 12 | 01-05-2013 11:01 PM |
| Electric power steering | madfast | Scion FR-S / Toyota 86 GT86 General Forum | 33 | 10-13-2011 11:11 AM |
