Old 12-29-2017, 03:44 PM   #1
Chris1083
Drives: None
Chris Cessna 2jz swap frs.
Best way to start is with an intro. So I'm Chris a little about my past and where my passion comes from on this build. Back in 2008 I met a great shop who turned my ordinary Evo 8 into something extra ordinary. The car ended up running a 9.99 1/4 in 2010 to become the 1st stock block evo in the 9s. Then fast forward to 2013 i decided to venture away from the Evo and open a shop of my own. Why would i do that? Well you can't promote yourself while repping another shop which I opened in 2014. But I needed a shop car. Enter my 97 MK4 Supra (Start of my 2jz love). The car was overhauled and fully built in house. I closed up a year later when the military informed me I was transferring to NY. Upon getting to NY I decided I'm going to sell the Supra (biggest mistake ever) and just get out of the military and cars because within 6 months of selling I bought the FRS. Enter my 2013 FRS and the start of the build. I knew I wasn't going to be happy with a stock FRS so I found one for sale turboed with the intentions of driving it a little and then selling off the parts and doing a 2jz conversion during the winter. Well I drove it once and said yea this wont cut it. And so it begins.
-FBM EL Turbo manifold
- Garrett GTX2867 with Tial V-band housing
- FBM Aluminum intercooler Piping with couplers
- FBM 3" V-band Downpipe
- FBM 550hp Cast Intercooler
- FBM Intake Pipe
- FBM Dump tube
- Tial 50mm BOV
- Tial 44mm Wastegate
- FBM 550cc injectors
- FBM 270LPH Pump
- FBM Dual slim fans
- All Hardware/oil lines and gaskets
- Cast Oil Pan
- South Bend Stage 3 Clutch
- Custom Berk-replica muffler delete.
- Custom fabricated intake piping from Driven Fabrication to re-locate MAF sensor to more ideal location
- Tuned by Turn-in Concepts on 93octane
I will keep update as progress is made. Hoping a march run time. Follow my Instagram zna2jz
Chris1083 is offline   Reply With Quote
Old 12-29-2017, 03:44 PM   #2
Chris1083
Drives: None
So to start the motor had to come out. Wasn't to bad, took about 3-4 hours taking my time.
Old 12-29-2017, 03:54 PM   #3
Chris1083
Drives: None
Next the parts fairy came and left some presents.
Old 12-29-2017, 03:57 PM   #4
Chris1083
Drives: None
To go with the trans of choice a T56 magnum you have to remove the stock trans mount. It sucks drilling all the spot welds out. But worth it. Got the motor and trans mocked together, and test fitted.
Old 12-29-2017, 03:59 PM   #5
Chris1083
Drives: None
Got the motor and trans put in. Had to get an extended shifter but it fits. And it brings to where I'm at now.
The Following 3 Users Say Thank You to Chris1083 For This Useful Post:
DIY (12-29-2017), DustinS (12-29-2017), Lococholo84 (02-25-2018)
Old 12-29-2017, 04:48 PM   #6
jubella2
jubella2's Avatar
Drives: DGM BRZ
That's a big turbo.
jubella2 is offline   Reply With Quote
Old 12-29-2017, 05:28 PM   #7
Chris1083
Drives: None
Just a s363, woulda been bigger but had to stay in class regulations.
Old 01-21-2018, 02:54 PM   #8
Chris1083
Drives: None
Been slow go but started mocking up the Ford 8.8, needs a new front cover to fit but will fit good. Then to figure out the mounting for it.
The Following User Says Thank You to Chris1083 For This Useful Post:
SkAsphalt (01-24-2018)
Old 02-25-2018, 04:37 PM   #9
Chris1083
Drives: None
Mods please move to engine swap section.
Old 02-25-2018, 04:40 PM   #10
Chris1083
Drives: None
So decided against the 8.8 for some reason. Not sure why, probably to show the naysayers that this diff can hold power. But today was a good day with progress. Installed the new 3.5" t56 to stock diff driveshaft, new intake manifold with Bosch 1600cc injectors, got turbo and downpipe secured, removed stock fuel lines, and mounted/centered the intercooler.
Old 02-26-2018, 09:42 AM   #11
Swift
I just Drive.
Swift's Avatar
Drives: in the womb still
Well depends on the power level you want to make, but yeah lets see how well the stock diff does.
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project
Swift is offline   Reply With Quote
Old 02-26-2018, 09:58 PM   #12
Chris1083
Drives: None
I have the 8.8 here so conversion will cost a little but heck I'll push till the diff blows and then worry about it. I can make a little selling the built axles to offset. I just like to push limits and see. Kinda like I did with my old evo.
Old 04-07-2018, 05:50 PM   #13
Chris1083
Drives: None
Been slow going but getting everything fabbed up thanks to RT Design & Fabrication.
Old 04-09-2018, 06:51 PM   #14
supahotfya_86
Drives: Firestorm FR-S
What adapter plate did you use to mount the T56? Is is the Granna racing adapter plate?
supahotfya_86 is offline   Reply With Quote
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Chris Harris at Spa Captain Snooze Other Vehicles & General Automotive Discussions 1 10-01-2016 06:55 PM
Chris Harris - Ferrari 488 GTB M1K3 Other Vehicles & General Automotive Discussions 9 02-28-2016 05:23 PM
Chris Harris - Do you need anything more than a BMW 320d? M1K3 Other Vehicles & General Automotive Discussions 7 06-23-2015 10:54 PM
Chris's BRZ nyhockey09 Member's Car Journals 1 09-10-2013 12:17 AM
