Old 11-20-2017, 06:37 PM   #239
pacaveli420
Drives: Badass
Originally Posted by notout86 View Post
I have wondered about doing this too. With just the tube plugged, engine compartment noise is still transmitted to the firewall. By disconnecting the tube/grommet, did you notice a reduction in cabin noise?
I didn't really notice a difference. I just wanted to clean up the engine bay a bit and fully remove the whole thing. That and I noticed people were just plugging the little rubber piece after I'd already pulled it out.
pacaveli420 is offline   Reply With Quote
The Following User Says Thank You to pacaveli420 For This Useful Post:
notout86 (11-27-2017)
Old 04-24-2018, 02:29 AM   #240
Cheeky
Drives: 10 Series FRS
Late to party but I figure I could share my journey in plugging up the hole....
Wasn't to fond of just stuffing it up with cotton, or re-purposing secret 12V cover. I live in Canada, so idk... my first instinct was Canadian Tire.
I found the ones suggested "DORMAN Panel Trim Fastener", but you need to request from the auto desk as the inventory thing said "Ask an Associate". Further... the design looked like it might not be easy to pull out.
Went to Home Depot next cuz it was close, couldn't find the right Crown Bolt nylon type covers, only metal ones.
In the end I went to Lowe's, Hardware section where you find drawers with all the screws, nuts, fasteners. Here is a pic of the packaging...
You need the #881289 7/8 size, two for $2.79. Did a quick test, can plug and unplug easily. Cabin sounds cleaner, less engine rasp and more smoother tones. Even on stock muffler it sounds better. Great mod
Cheeky is offline   Reply With Quote
The Following User Says Thank You to Cheeky For This Useful Post:
sfdai0 (04-24-2018)
Old 08-03-2018, 04:37 PM   #241
Seanzky
Drives: Slow
When you remove the entire sound tube and plug up the hole, do you also need to do anything on the firewall side or just the passenger side (LHD - US)?
Seanzky is offline   Reply With Quote
Old 08-03-2018, 04:54 PM   #242
norcalpb
norcalpb's Avatar
Normally one plug takes up the entire tunnel, so yes you don’t need 2 plugs.
The Following User Says Thank You to norcalpb For This Useful Post:
Seanzky (08-03-2018)
Old 08-07-2018, 03:13 PM   #243
Cheeky
For those of you who want the canadian tire plug, the package looks like this...
(I didn't use this one, so I don't know how well it works)
Old 10-27-2018, 01:57 PM   #244
Manuel020
Drives: Seat leon
learn about brentwood home
Please where can I find them ?
Manuel020 is offline   Reply With Quote
Old 10-29-2018, 01:16 PM   #245
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I would google the numbers and words on the package.
Like this....
https://www.google.com/search?q=4509...hrome&ie=UTF-8
I LIKE TIRES!
Old 11-25-2018, 04:08 PM   #246
multistraddler
Drives: '13 White BRZ Ltd
I'm a motorcycle guy who has a tendency to just remove things that don't make you go faster. This collection of plastic, rubber and clips fits that description to a tee.
I had a rubber bung plug in the garage that fit nicely into the hole off the intake. I pulled one of the elbows off the hose on the firewall end and shoved a end cap in the opening to block sound and moisture from getting into the cabin.
Job done. Now time to go for a ride and contemplate making the car louder with an aftermarket header...
multistraddler is offline   Reply With Quote
The Following 2 Users Say Thank You to multistraddler For This Useful Post:
bcj (11-25-2018), Leonardo (02-05-2019)
Old 02-05-2019, 02:23 AM   #247
Lav
Drives: Frs
Is there a difference in sound between deleting the tube entirely vs just plugging the hole?
Plugging the hole made the drone on my TRD catback way more noticeable. Im guessing if the TRD causes the drone then its coming through the bottom of my car and has nothing to do with the engine bay, but i just thought id check. Has anyone plugged the hole, driven for a while, and then deleted the tube entirely?
bibbity boppity give me the zoppity
Lav is offline   Reply With Quote
Old 02-05-2019, 11:36 AM   #248
Interlocker
Drives: 2017 Toyota 86 860
So glad I stumbled upon this thread. Years ago, I didn't mind a noisy interior at all and even when out of my way to increase it. I'm older and more easily annoyed now... LOL!
This car seemed oddly noisy, but I was chalking it up to the TRD exhaust the car came with along with the lack of sound deadening. Not a real pleasant noise either, but not the worst thing I've heard.
I read through the full thread and figured it sounded easy enough and I already had the 12V adapter cover in the glovebox anyway, so it would be free to test it.
With how easy it sounded, I decided to time myself just for fun, too. From the moment I opened the passenger door to the moment I closed it when finished took all of 63 seconds, and that included trying to press the adapter in a bit harder to make sure it was actually in.
I wish I'd have known about this before the 200-mile drive home with the car last week. It's a subtle but VERY welcome difference.
I do love open-intake induction sound, but that's not what you get from the factory sound tube. The engine sounds smoother and more "upscale" to a certain degree. I didn't realize how "cheap" the sound tube made the car sound inside.
Very happy with the outcome of the easiest and cheapest (free!) mode I've ever done to a car. Thanks!
Interlocker is offline   Reply With Quote
The Following User Says Thank You to Interlocker For This Useful Post:
Lav (02-05-2019)
Old 07-18-2019, 03:25 AM   #249
Clutch
Clutch's Avatar
Drives: 2018 Subaru BRZ Limited (Silver)
Just did this on my 2018 and wish I had done it a year ago. Immediate reduction in cabin noise. Simple and reversible. Thanks!
Clutch is offline   Reply With Quote
Old 07-18-2019, 05:42 PM   #250
DarkSunrise
DarkSunrise's Avatar
Just tried this mod again. I initially tried it when running a full exhaust setup, then took it off when I switched to just a CBE thinking I'd enjoy some more sound. I was wrong. Sounds much better plugged. Engine sounds less course and thrashy. Much more enjoyable now.
2022 BRZ Build
2013 FR-S Build
Old 08-22-2019, 05:53 AM   #251
Grizzly
Drives: 2020 BRZ
Just did the 12v plug mod, makes a massive difference, I'm sure the wife will be a bit more relaxed now.
Grizzly is offline   Reply With Quote
Old 09-16-2019, 01:16 PM   #252
Erci
Erci's Avatar
Drives: 2018 BRZ Limited
I don't have quantitative data to support my theory, but my guess is that blocking sound with piece of plastic is not as good as blocking it with a material specifically made to reduce noise. I already had disposable ear plugs (32dB NRR) and the 2 of them, side by side, fit and expand perfectly into the tube below the glove-box.
Erci is offline   Reply With Quote
enouf is a damned genious, plug, sound tube, toyoburu kazoo banned.
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 06:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 06:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
Switching stereo from TC to "FR-S" mode frsinpa Electronics | Audio | NAV | Infotainment 8 06-21-2012 11:48 PM
*NSFW* "Check Out My Subaru" on You Tube Axel Other Vehicles & General Automotive Discussions 4 01-17-2010 06:56 PM
