Old 11-20-2017, 11:15 AM   #1
D-rek07
Drivers door issue
Hi,
I'm having trouble with the drivers door lock on my 2013 BRZ limited.
Here are the symptoms
When using the keyless entry on the drivers door: The car double beeps five times, unlocks the passenger door but doesn't unlock the drivers door.
When using the keyless entry on the passenger door: The passenger door unlocks but the drivers door doesn't.
When using the keyfob to lock/unlock the car: Only the passenger door locks/unlocks.
When using the door lock/unlock button on the inside door trim: Only the passenger door locks/unlocks.
The drivers door only locks using the manual lock on the door trim or the key hole and unlocks when doing the same.
I have done the 12v reset. Unhooking the battery. No change. I have tried both keyfobs with new batteries. I have checked all the fuses under the hood.
Can anyone recommend anything?
D-rek07 is offline   Reply With Quote
Old 11-22-2017, 11:46 AM   #2
D-rek07
Darn 85 views and no opinions? Guess its a trip to the dealer
Old 11-22-2017, 12:08 PM   #3
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
2013 model and nothing but the manual lock/unlock works? sounds like the actuator/motor/whatever on the driver side door is dead/unhooked/etc.
Not sure if theres a fuse for that, worth a check. You said you checked the fuses under the hood, but theres a separate fuse box under the dash on driver's side.
Or pull off the door card and see if theres any fried/dangling wires?
I havent seen this problem on the forums or myself yet, so im just taking guesses.
Old 11-22-2017, 01:09 PM   #4
D-rek07
Okay I'll check that. I didn't realize there was another fuse box. Thanks
Door Unlock Issue TONYpepperon1 Issues | Warranty | Recalls / TSB 20 01-05-2018 08:06 PM
FS: '13 BRZ SWP drivers door (damaged) TAKS 86 Exterior Parts (Aero, Lighting, Etc.) 3 02-19-2016 01:59 AM
Door lighting issue... DarrenFord Cosmetic Modification (Interior/Exterior/Lighting) 18 07-02-2015 08:48 PM
WTB: drivers side door TAKS 86 Want-To-Buy Requests 1 07-14-2014 12:30 PM
Door Rattle Issue DriftEightSix AUSTRALIA 4 06-28-2012 02:11 AM
