Old 11-14-2017, 08:25 PM   #1
Dogster70
Dogster70's Avatar
Drives: 2013 Scion Frs Whiteout
trying to figure out rim sizes after fender flare install
Hey guys im just trying to figure out exactly what rim sizes i should be looking for with a fender flare kit installed. i want something that fills the wells real nice atm im sitting on stock springs but i do look to maybe go about half an inch lower to and inch lower with some different coils. some good insight and a good range of sizes would be super helpful thanks guy!
Dogster70 is offline   Reply With Quote
Old 11-14-2017, 11:24 PM   #2
monkeybike
Drives: 86
http://www.ft86club.com/forums/showthread.php?t=20429
monkeybike is offline   Reply With Quote
The Following User Says Thank You to monkeybike For This Useful Post:
Dogster70 (11-15-2017)
Old 11-16-2017, 02:31 AM   #3
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
What fender kit? You gotta understand some kits flare more than others.
Another recommendation would be to get coils in order to fit the wider wheels you're probably going to need to get the flush fitment you want.
tyler_win_photo is offline   Reply With Quote
The Following User Says Thank You to tyler_win_photo For This Useful Post:
wparsons (11-18-2017)
Old 11-17-2017, 04:10 PM   #4
Dogster70
Dogster70's Avatar
prolly either the v2 flares or the duraflex ones but i havent heard anything about the duraflex fender kit so im not sure about them. but i also dont know any good coils i dont wanna spend alot on suspension jsut whatver can get me by honestly.
Old 11-17-2017, 04:16 PM   #5
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
don't do it half assed or else it's just going to be a nightmare for you.
if you do decide to go non authentic, you'll probably end up spending the money you saved on the amount of work needing to get it fitted and prepped.
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
The Following User Says Thank You to Soloside For This Useful Post:
Old 11-17-2017, 04:20 PM   #6
DAEMANO
Time Traveller
This argument often overlooks the fact that many people have more skills and time than money. If that's the case, then unless OP was working as a mechanic or at a body shop would his own time spent on the project be a waste.
Also, believe it or not, some folks just like to work on cars.
Old 11-17-2017, 04:40 PM   #7
redhalo
Drives: MY20 Hakone Toyota 86
Fair statement, but if that were the case would he be asking here with zero info to work with?
redhalo is offline   Reply With Quote
The Following 2 Users Say Thank You to redhalo For This Useful Post:
Dogster70 (11-17-2017), wparsons (11-18-2017)
Old 11-17-2017, 05:20 PM   #8
DAEMANO
Time Traveller
Probably not, but still it never hurts to ask those that may have done the work before (or in this case, the wheel fitting), regardless of his skill level.
The Following User Says Thank You to DAEMANO For This Useful Post:
Old 11-17-2017, 05:28 PM   #9
Leonardo
Country Boy 4 Life
Leonardo's Avatar
This is how I start projects.
Set a total amount I can spend.
Make a list of desired parts.
Find parts that "fit" in my budget.
Research, Research, Research.
Oh, yeah - Don't forget Paint.
Am I going to install myself?
Do I have all the right tools?
Once I have made a list and answered these questions, I am ready to start. Usually, I use this as an excuse to buy myself some new tool I have been wanting.
I have done ALL the mods to my car.
If you install the suspension and kit first, then you will be able to get solid measurements for the wheels you want.
I LIKE TIRES!
Old 11-17-2017, 06:42 PM   #10
Dogster70
Dogster70's Avatar
well see i have 3000 to spend atm but i dont want the full rocket bunney kit and buying the fenders alone are about 1200 bucks then if i get them ill have to cut the fenders and then have the car wrapped. thatll be prolly around 600 bucks. that will leave me with barely any money to get new rims and tires since the rims i own are small they are basically stock rims with a tiny meatier tires on it lol.
Old 11-18-2017, 10:25 AM   #11
Cole
Not a troll
Cole's Avatar
Then maybe don't get the flares?
Parts cost breakdown:
Flares- 1200
Wheels- 1200-5000
Suspension- 500-3000
Wrap (materials)- 600
Your budget is far too low, unless you're buying replica everything and raceland coils.
Cole is offline   Reply With Quote
The Following 2 Users Say Thank You to Cole For This Useful Post:
Dogster70 (11-18-2017), wparsons (11-18-2017)
Old 11-18-2017, 10:36 AM   #12
Soloside
Flares- 1200
Wheels- 1200-5000
ULTRA LOW BUDGET Cost Breakdown
Rep Flares ~ 275-500
Wheels ~ Forgestars auto fitment 1700 + tires ~700. Maybe you can get lucky and only spend 1k on a set of used rb fitment forgestars with tires.
Suspension ~ 500-600
Wrap ~ DIY Mats cost.
You're a little under budget even for reps/used parts
2014 Subaru BRZ
The Following 2 Users Say Thank You to Soloside For This Useful Post:
Old 11-18-2017, 05:40 PM   #13
Dogster70
Dogster70's Avatar
so pretty much im gonna go fenderless and wait on my wrap for another time, i just bought bilstein b16's and am looking at getting a set of 18x8.5 and 18x9.5 both with a +45 offset, maybe with some 245/35 in the front and 255 or 265 in the rear. does anyone here know if that fittment will work without over fenders? the offset is a bit much for the front i am assuming? or do you guys know anyone running this?
Old 11-19-2017, 01:35 AM   #14
tyler_win_photo
Yes that will fit in the front for sure. The rear will fit, but will rub occasionally with a 255 or 265 depending on how low you go and how much camber you plan on running.
Before you do anything else, I recommend you do more research on the topic. For example when you install the b16's and lower your car, the camber in the rear is going to be way off... which in turn you'll have to buy lower control arms because stock the rear has no camber adjustment.
Dogster70 (11-19-2017)
body kit, fender flares, rims, size, wheels
Fender flare identification. swarb Cosmetic Modification (Interior/Exterior/Lighting) 2 04-10-2017 07:32 AM
I cant figure it out... Need help snapplepat Forced Induction 9 02-20-2017 10:22 AM
Rocketbunny flare Install - Rivet Nuts ? Iamwu Cosmetic Modification (Interior/Exterior/Lighting) 7 07-18-2016 01:16 PM
FS> VALENTI front Toyota emblem ornament plate (flare red) k1s3k1 Australia Classifieds 0 06-06-2014 08:23 PM
BRZ rear diffuser + flare caps omgwtfbbqsauce AUSTRALIA 6 10-16-2012 04:34 AM
