Drives: S15 Silvia
Compression Test Values - Factory Specifications?
Hi Guys,
I just got my car compression tested because I saw white smoke coming out the exhaust once or twice, issue seems to be resolved but I got a compression and leak test anyway. Compression test came back 193, 197, 208, 198 (PSI) Leak down returned less than <5% across all cylinders.. Just wondering if anyone knows what are the factory specified compression values? E.g. New from factory = 210-230 PSI range, Engine in serviceable condition = ... 170PSI+? Thanks in advance guys Rob |
#2 |
Resident Gear Head
Previous engines I have had at 12.3:1 were around 210-215 and that was after 60k Miles. I would expect some issues at sub 200 on an engine with less mileage.
Subaru BRZ/FRS Facebook News and Tech Page
My FB Build page CLICK AND LIKE! Twitter and Instagram @misairubrz |
#3 |
Drives: 2013 GBS BRZ Limited
Funny that atmospheric pressure at sea level is ~15 PSI.
CR of 12.5 means 15 X 12.5 = 187.5 PSI. That should be the highest static pressure you can get unless cranking the engine with the starter gives you a dynamic CR higher than 12.5 (not likely).
#4 | |
Resident Gear Head
#5 | |
Sometimes I'm wrong.
Drives: '13 FR-S/'96 240SX
When you compress the air, it heats up, which further increases the pressure even more than just mechanically reducing the volume. The higher the compression ratio, the more heat adding to the pressure. Last edited by murdoc; 11-24-2015 at 10:40 AM. |
| The Following User Says Thank You to murdoc For This Useful Post: | Spartarus (11-25-2015) |
#6 |
Drives: Raven Fr-S
[Pedantic]Sea level 14.7. And TDC pressure equation is 14.7X(12.5^1.3x).
Although, since throttle bodies are closed and Engine is running at ~200RPM on the starter, it is tough to know the manifold absolute pressure without logging.[/Pedantic]
FR-S Mod target: 200 BHp / Tonne 4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff |
#7 | |
Resident Gear Head
#8 |
Junior
Drives: a car
Totally unrelated but i cant pass it up, lol
[ame="http://m.youtube.com/watch?v=yetwdpsiM8Q"]http://m.youtube.com/watch?v=yetwdpsiM8Q[/ame]
#9 |
Drives: 2005 Toyota Camry
#10 | |
Drives: S15 Silvia
#11 |
Drives: 2015 BRZ Ltd 6MT
#12 |
#13 | |
Drives: 2014 Scion FR-S Monogram Series
Is that what the service manual calls for during the test on the twins? When I turned a wrench for a living back in the 1980s, the throttle was always set at wide-open during a compression test.
2014 FR-S Monogram Series, Raven Black, MT
Mods -ARP wheel studs, Bilstein B6, Michelin Pilot Sport 4S, Diode Dynamics "Tail-as-Turn" kit. Fuel Economy - Best was 37.2 mpg, Worst was 28.2 mpg Semi-truck crushed it on 1-1-2023. |
#14 |
| Requesting OEM Clutch Line Specifications | RJasonKlein | Engine, Exhaust, Transmission | 6 | 05-21-2015 01:06 AM |
| TRD GT86/AERO Specifications | 1904 | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 11-06-2014 03:03 AM |
| BRZ Values | Apex_BRZ | BRZ First-Gen (2012+) — General Topics | 20 | 10-16-2014 06:38 PM |
| front and rear fender well specifications | PineappleFriedRice | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 07-22-2013 07:06 PM |
