| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
A.K.A. Starlord
Drives: 2015 Series.Blue
Using Mirror Harness to Power Dual-Channel Dashcam
I feel this is a long shot since 0.02% of people here seem to even have a dashcam, but I'm asking anyway.
I have a dual-channel dashcam that I originally hardwired to the fuse box months ago using some add-a-fuse adapters. (Always on +12V from STOP light fuse, Switched +12V from Power Outlet fuse, Ground to fuse box bolt.) Works fine, no issues. My BRZ is a Series.Blue, which came with a frameless mirror, which is cool, but also lame in that it doesn't have homelink or a compass, and isn't powered in any way. I was just made aware of the existence of Subaru Part #: H501SAJ010 (picture attached). This is the harness that would normally be used to connect a powered mirror to a pre-existing harness in the headliner (at the dome light location.) I'm tempted to purchase this $8 harness, and re-wire my dashcam as it allows me to eliminate wires running across the dash, and the extra fuses sticking out of the fuse box. My only question is if anyone knows offhand if this harness provides the same 3 types of power (constant, switched, and ground), and also if anyone has any idea if it would be okay to power the dashcam through it. I imagine a two-channel dashcam that gets warm during normal operation draws a decent bit more power than a mirror...
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
#2 |
A.K.A. Starlord
My current setup has the wires running to the fuse box under the driver's side dash:
#3 |
Junior Pizza Joe
Drives: 2017 BRZ Limited Manual WRB
I'm not electrically minded, but i ran my dash cam from behind the mirror, wire tucked into the headliner, down through the a pillar cover and into the power outlet in the glove box.
Works great. No wires on the dash or messing with the fuse box. Starts up everytime the car does. Bill
Scooby-Doo: Scooby-Dooby-Doo!
Shaggy: And like, Shaggy too. |
| The Following User Says Thank You to Willie Swoopes For This Useful Post: | Jordanwolf (11-01-2017) |
#4 | |
A.K.A. Starlord
#5 | |
https://demos.starbase7.net/t3Portal...+2016+MY+FR-S+[05%2F2015+-+]&docid=989162&context=ti
| The Following User Says Thank You to Tcoat For This Useful Post: | Stang70Fastback (11-01-2017) |
#6 | |
I think therefore.....
Drives: Toyota 86 860 Halo White (Manual)
Your correct, I just installed the auto dimming mirror with the same adapter, I checked the power line so I would not have to disconnect the battery. There is a single power line going to the mirror: Off: COLD. Accessory: HOT. START: COLD. Running: HOT (Obviously). I did NOT check the amp rating on the fuse. I would suspect 3/5 amps but a pure guess. Truth is I don't even know if it has a dedicated fuse.
May the N.A. force be with you.
| The Following User Says Thank You to Darth Khan For This Useful Post: | Stang70Fastback (11-01-2017) |
#7 |
A.K.A. Starlord
Damn. Oh well. It was worth a try. That would have been convenient! Just makes me tempted to upgrade my mirror with one with HomeLink...
https://www.amazon.com/Gentex-Framel.../dp/B00PXGZESO
#8 |
After thinking about this you could make it work by using the power line to the internal light. There is power that goes to the ON switch, you could splice into this before the switch and use that line as your "Always On".
#9 |
A.K.A. Starlord
Yeah, that was always a possibility, but the idea here was a clean-simple install without any extra work or wiring, using the OEM harness. I'll just leave my current setup, I suppose.
#10 | |
I would buy the Subaru auto dimming rear view mirror kit. It comes with the adapter and the mirror cable tidy. When installed correctly no cables are visible. I would then splice in my power for the dash cam utilizing the same power lines as the mirror and the interior light. All of the cables would be in the head liner. There are a couple ways to do this, none of them are difficult. Alternatively you could buy the cable tidy and the cable and keep the manual mirror.
| The Following User Says Thank You to Darth Khan For This Useful Post: | Tcoat (11-01-2017) |
#11 | |
A.K.A. Starlord
The dashcam isn't attached to the mirror, but to the front and rear windshield directly.
#12 |
Drives: 2014 BRZ Limited
That harness may not be useful for a dashcam, but I bet it will do just fine for my Valentine 1.
| The Following User Says Thank You to extrashaky For This Useful Post: | Stang70Fastback (11-01-2017) |
| DIY Blackvue DR400G-HD/Power Magic Pro Dashcam | F1point4 | DIY (Do-It-Yourself) Guides | 194 | 06-12-2020 02:08 PM |
| Auto Dim Mirror Harness Needed | Burritos | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 04-06-2017 01:11 PM |
| Blackvue DR750LW-2CH Full HD dashcam 16GB Wi-Fi + Power Magic Pro | ucsmfu | Canada Classifieds | 10 | 08-16-2015 02:15 PM |
| Fs: Blackvue DR550GW-2CH Dashcam (built in wifi + power magic pro) | ucsmfu | Audio/Visual, Electronics, Infotainment, NAV | 9 | 02-27-2014 11:06 PM |
| T Power C battery and dashcam | Speedoponic | Electronics | Audio | NAV | Infotainment | 0 | 01-10-2014 07:39 PM |
