Old 10-23-2017, 12:10 AM   #1
drz400dude
Joying 8" 2GB Toyota Universal install
Installed my Joying 8" Android unit a week ago, thought I'd give it a review on here in case anyone else was thinking about it.
First off, it is most definitely Chinese. The instructions are in Engrish, but the install is super straight forward. The only thing that was kinda wonky was the mounting brackets. The way it lined up I could only get 3 screws in each side, and I had to mash the little bubble detent on the bracket down so it would sit flush against the head unit. Not a big deal.
Note, you will lose your stock USB and AUX ports, but it does come with 2 USB inputs you can use for whatever. I use one to hook up my phone, and one I plugged in a hard drive with all my music and movies and ran it to my glovebox so it is hidden. It's nice being able to chill in the car on lunch and watch TV shows or whatever.
The screen is detachable, it just pulls straight out and you disconnect a little ribbon from the back. Nice if you are in the not so nice part of town or have to park somewhere kinda shady.
The GPS is nice, comes with the antenna. I just run google maps just like I do on my phone. While I'm home I connect to my wifi and DL the map for my area, or the area I'm going if it's a long trip. If I need to connect on the fly I can tether with my phone, or do screen mirroring which is easy enough to set up.
Most things seem to run fairly smoothly. I can run maps and music at the same time without much lag. From the factory I had to calibrate the side buttons for volume up and down as they were not responding correctly. But now they work great. You can actually program the side buttons to do a host of things from the menu, which is nice. I have my power button set to dim the screen for nighttime driving. The only thing is I kinda miss having a volume knob.
The screen doesn't sit perfectly flush, there is a tiny gap. You can't notice from either seat unless you put your head almost right next to the dash, so its not a big deal for me.
Any other questions just ask!
drz400dude is offline   Reply With Quote
The Following 4 Users Say Thank You to drz400dude For This Useful Post:
chaoskaze (08-01-2018), MaximaZero (11-09-2017), Pointmutation (10-29-2017), rixter145 (11-13-2017)
Old 10-23-2017, 05:30 PM   #2
ze12o
Drives: BRZ 2015 DGM
pics of it working please!
ze12o is offline   Reply With Quote
Old 10-25-2017, 09:54 AM   #3
drz400dude
I'll upload a few later. Anything specific you want to see? I didn't do it originally because they have shots of the screen on their website.
Old 10-28-2017, 10:15 PM   #4
mausr
Drives: GT86
Thanks for the mini review. I am considering the same HU, however, I'm a bit hesitant due to the sound quality. What is you experience reagarding SQ?
(My other take would be the Sony xav-ax100, which sounds great but it starts with an annoying message and it looks not as good when it is installed.)
mausr is offline   Reply With Quote
Old 10-29-2017, 02:58 PM   #5
Pointmutation
Pointmutation's Avatar
Drives: 2016 ZC6
How firmly does the tablet connect to the unit? Any worries it'll come off on extremely bumpy/crappy roads? Hard to remove? I've been looking at their larger screen units and the thing that concerns me is the stability of the display when mounted.
Pointmutation is offline   Reply With Quote
Old 10-30-2017, 03:50 PM   #6
rixter145
Sleep Chomper
rixter145's Avatar
did you have to repin any of the wiring harnesses? Also back up cam install? I have a 2014 brz with the beatsonic bcam so with this, do I just forgo the beatsonic harness and connect the rca cable?
rixter145 is offline   Reply With Quote
Old 11-08-2017, 05:53 PM   #7
drz400dude
Sound quality is hard to tell. The speakers in this car aren't great to begin with. It's not any worse, that's for sure.
Sent from my SAMSUNG-SM-N920A using Tapatalk
Old 11-08-2017, 06:57 PM   #8
drz400dude
It attaches very firmly. It doesn't move at all going down the road. The thought of it coming off didn't even cross my mind. It is also very easy to remove. Just a bit of firm pressure pulling on the back directly outward and it pops right out.
The Following User Says Thank You to drz400dude For This Useful Post:
Pointmutation (11-08-2017)
Old 11-08-2017, 06:59 PM   #9
drz400dude
I didn't have a backup cam so I'm not sure about that. I didn't have to repin anything. All plug and play. The only thing you'll need is an adapter for the fm antenna if you still use that.
Old 11-08-2017, 07:00 PM   #10
drz400dude
Here's some screen pics
Old 11-08-2017, 07:51 PM   #11
rixter145
Sleep Chomper
rixter145's Avatar
What year is your car?
Sent from my F8131 using Tapatalk
Old 11-08-2017, 08:28 PM   #12
drz400dude
2013
The Following 2 Users Say Thank You to drz400dude For This Useful Post:
CraigVM (11-12-2017), rixter145 (11-08-2017)
Old 11-12-2017, 06:41 PM   #13
mausr
Drives: GT86
Did not reach the necessary number of posts to thank you via the built-in function, so let me do this way:
The Following User Says Thank You to mausr For This Useful Post:
Old 11-12-2017, 09:27 PM   #14
CraigVM
Drives: Car Collector
Ditto
Ditto as said. Another thanks here also.
I like the idea of a tablet sized display. Just installed what most would consider a cutting edge HU as far as features. Yet many look at it and with the trend of larger OEM screens that come in so many cars, they ask if I am looking to upgrade it to something newer and BIGGER
CraigVM is offline   Reply With Quote
head unit, joying, universal
Joying Android 4.4.4 Kitkat Toyota Head Unit Griffon Electronics | Audio | NAV | Infotainment 542 09-12-2017 11:49 PM
Joying Head Unit in the Toyota 86 GT FRS2017 Electronics | Audio | NAV | Infotainment 1 09-05-2017 08:59 AM
Joying Toyota DVD Android HU Rican_D Audio/Visual, Electronics, Infotainment, NAV 9 08-05-2017 03:40 PM
Install a Aftermarket Android Head Unit (Joying) -- HELP FRS2017 DIY (Do-It-Yourself) Guides 0 07-04-2017 12:45 AM
WTB: CA-FI DASHLINQ CT 701000 TOYOTA UNIVERSAL 7" Guzic Want-To-Buy Requests 0 12-28-2015 01:34 AM
