Old 10-19-2017, 11:42 AM   #1
Bronchole
Bronchole's Avatar
Drives: 2015 FR-S
Type of base for H11 bulb?
I went to order a set of H11 HID's for my 2015 FR-S. The options had 4 options for the base of the bulb:
H11
H11B
H11 L shaped base
H11 metal Base
Here is what I am trying to order: https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
I did try searching for combinations of "HID H11 base" but none of the subjects even had anything to do with headlights.
Anyone got an idea of which I should be getting?
Dan
Bronchole is offline   Reply With Quote
Old 10-20-2017, 06:19 PM   #2
Bronchole
Bronchole's Avatar
Drives: 2015 FR-S
Over 60 views and no comments?
Old 10-20-2017, 09:02 PM   #3
Kravos
Drives: 2015 Scion FR-S
I believe b is the type of connector L is the way the base is. And obviously metal base is metal. With that said, I believe it's H11 normal. The metal base uses a wire spring loaded system to keep it in. My old mr2 had those.
I'll double check the bulb in a few minutes.
I also have some hardly used diode dynamic hid ballasts if you're interested.
Kravos is offline   Reply With Quote
Old 10-20-2017, 09:28 PM   #4
Kravos
Yup, standard h11.
https://imgur.com/a/LMr7J
Dealer set the wrong Car Type in FR-S base audio pkny Electronics | Audio | NAV | Infotainment 112 05-08-2017 11:04 AM
WTB: Voltex Type 7 Swan Neck Wing with FRS Base Plates leunglambs Want-To-Buy Requests 1 01-09-2017 02:44 PM
SPECIAL PRICE TOMEI TITANIUM MUFFLER TYPE -80,60S,60R/FRONT STRAIGHT PIPE TYPE-80,60 myjdmparts Groupbuys 15 10-08-2015 11:41 PM
HID bulb size/type on Monogram series chicagokid Cosmetic Modification (Interior/Exterior/Lighting) 1 05-27-2014 01:20 AM
