Old 10-16-2017, 01:25 AM   #505
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
Some practice / testing today.
[ame]http://www.youtube.com/watch?v=WdwqEJAG5HY[/ame]
iLuveKetchup is offline   Reply With Quote
The Following User Says Thank You to iLuveKetchup For This Useful Post:
strat61caster (10-16-2017)
Old 10-16-2017, 02:23 AM   #506
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Looks like you tamed that front end push quite a bit
Edit: Also where do you mount the foot camera? That might be rather useful if it's not intrusive.
ineedyourdiddly
Old 10-16-2017, 10:43 AM   #507
iLuveKetchup
Drives: EFF JAY
I have a GoPro Session stuck underneath the steering column interior panel. It doesn't get in the way while driving or racing. I leave the frame in place and take the Session camera with me when not in use.
Old 10-16-2017, 02:47 PM   #508
snoxracer183
Drives: 2014 FR-S SSC
Anyone have a source for Rota weights? Looks like the Titan 17x8 might be exactly 17.0lbs but looks like a bathroom scale from the one pic I found.
snoxracer183 is offline   Reply With Quote
Old 10-16-2017, 02:58 PM   #509
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
What's the offset on that wheel?
Twinz is offline   Reply With Quote
Old 10-16-2017, 03:16 PM   #510
snoxracer183
Old 10-16-2017, 03:32 PM   #511
blkwrxwag
Drives: DS FRS
Those and the Konig Ultraforms are top of my shopping list
-Max H.
blkwrxwag is offline   Reply With Quote
Old 10-16-2017, 03:40 PM   #512
snoxracer183
They look good
The Following User Says Thank You to snoxracer183 For This Useful Post:
blkwrxwag (10-16-2017)
Old 10-16-2017, 03:43 PM   #513
tony_r
tony_r's Avatar
Drives: '15 STX
You need to get your studs in first! :P
tony_r is offline   Reply With Quote
Old 10-16-2017, 03:47 PM   #514
blkwrxwag
Drives: DS FRS
F*** those f***ing things!
I did acquire a proper punch and hub puller for my next attempt
-Max H.
The Following User Says Thank You to blkwrxwag For This Useful Post:
Old 10-16-2017, 03:58 PM   #515
Bitters
Drives: Searching for next
I think you can also get the Rota Titan's in a 42 offset. Although if you are spacing to the allowed 40mm, you might be better off with the 45 and getting an easier to find 5mm spacer.
Bitters is offline   Reply With Quote
Old 10-16-2017, 04:06 PM   #516
Twinz
Twinz's Avatar
If I was going the spacer route, I would get the TR wheels.....Or the 17.7lb Enkei's for less if I wanted to spend a little extra for looks. The Rota wheels look way too expensive from my quick search.
Old 10-16-2017, 04:13 PM   #517
Bitters
Those titans should be cheaper than the Enkei set. I would expect to get them from around ~$1,000 (CAD).
Old 10-16-2017, 04:15 PM   #518
Twinz
Twinz's Avatar
The Enkei TS-10'S are listed under $200 each on Tire Rack.
Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 07-01-2016 02:36 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 03:36 PM
my twin RWDGUY Mid-Atlantic 2 04-08-2013 10:23 PM
JDM Spec-C V9 Twin Scroll VF36 complete Nico TURBO Engine, Exhaust, Bolt-Ons 0 12-05-2012 12:20 PM
