Old 10-15-2017, 01:01 AM   #15
subarubrzz
Drives: dont have one... yet
Thank you all for your input. It really helped.
subarubrzz is offline   Reply With Quote
Old 10-15-2017, 07:27 AM   #16
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Don't worry about it. An inch over is nothing and a lot of times when you get an oil change they over fill a little.
Mine drinks a tiny bit of coolant too. You'll never save enough $$ on cheaper coolant than the cost of one coolant system repair. Use the Toyota coolant, you won't use much and 1 bottle should last you a long time. I've gone through maybe a quart in 30,000 miles. I bought a gallon almost a year ago and I have plenty left.
guybo is offline   Reply With Quote
Old 10-15-2017, 11:42 AM   #17
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by subarubrzz View Post
Here are some pictures of the dipstick when I pulled it out.
That's not overfilled. You read the level where it covers the stick from one side to the other. That point is well below the full mark.
The Following User Says Thank You to extrashaky For This Useful Post:
mrg666 (10-21-2017)
Old 10-15-2017, 01:24 PM   #18
guybo
Huge E85 fan!
guybo's Avatar
@OP Now that I look again, I think you checked the dipstick wrong. Pull it out, wipe it off, fully insert it again then pull it out again and it's like extrashaky says, it's where the level covers the stick one side to the other.
Also, sniff your dipstick. If the oil smells like coolant, or burnt you have a problem. When you wipe the dipstick, check the rag and make sure there's no debris (esp. metal!) on it. It should be a nice oily smelling amber/brown color that is clean and clear. If it's too black, change that oil.
The Following User Says Thank You to guybo For This Useful Post:
mrg666 (10-21-2017)
Old 10-15-2017, 05:06 PM   #19
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
My only suggestion is to check the oil a bit more frequently than 2500 mi / 3 months. One board member recently ran his car down to the last quart with painful results. I'd rather check it frequently, soil a few shop rags and find it overfull than let it go for a while and not find any on the dipsitck. It may be anal retentively oild school but an ounce of prevention ans all that.
Enjoy the car!
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 10-15-2017, 05:52 PM   #20
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Have you replaced your radiator cap? If yes, do a leak test. I beat the piss out of mine and lose no coolant.
I haven't gotten down to that one on the 'crap I need to deal with' list yet since its really not that bad. Any reason not to go straight to a leak test?
Lol I was responding to this last night, but fell asleep mid-post.
Old 10-15-2017, 06:42 PM   #21
99.975% of the time, an otherwise good cooling system will fail to maintain pressure because of some shit causing a pinhole leak in either of the valves on the radiator cap. If it can't maintain pressure it'll start simmering somewhere on the engine. The bubbles collect at the top of the radiator and bleed out the cap instead of fluid. With each heating/cooling cycle a little more of the liquid coolant is pulled back into the system.
I wouldn't consider a leak check until after eliminating the radiator cap.
Spuds (10-15-2017)
Old 10-16-2017, 06:41 AM   #22
noodlefish
noodlefish's Avatar
Drives: Toyotas 86 (2013) & RunX RSi (2003)
OP will get thanks button sometime in 2019.
I've been looking for a thanks button for months. Now I know why
noodlefish is offline   Reply With Quote
The Following User Says Thank You to noodlefish For This Useful Post:
Ultramaroon (10-16-2017)
Old 10-21-2017, 05:10 PM   #23
NRXRaptor
Originally Posted by HKz View Post
this. if both sides of the stick are abnormally high then maybe there might be a overfill worry. otherwise i think OP is fine, as others have mentioned, the fa20's dipstick isn't the best indicator (I assume this is the case with most if not all boxer designs)
You gotta upgrade to a short throw dipstick
NRXRaptor is offline   Reply With Quote
The Following User Says Thank You to NRXRaptor For This Useful Post:
HKz (10-22-2017)
Old 10-21-2017, 05:22 PM   #24
mrg666
pessimistic skeptic
mrg666's Avatar
17% LTFT. Checked for leaks and none. edwardleeaf Software Tuning 10 02-08-2017 03:02 PM
Anyone with a BRZ get brake-checked tonight? HachiRo Northern California 52 02-02-2015 05:37 PM
get your brakes checked... tibsy92 AUSTRALIA 22 09-21-2012 10:10 PM
First time this happened to me... brzninja FR-S / BRZ vs.... 53 07-26-2012 05:39 PM
Anyone checked this site out? ryude Southeast 3 01-16-2012 01:40 PM
