go_a_way1
Old 09-19-2017, 02:52 PM   #1345
Shady195
Drives: '13 10 Series FRS #1203
Finally starting to get the hang of this tandem thing
[ame="https://www.youtube.com/watch?v=fWqPS-J_4jo"]4 deep at Thompson - YouTube[/ame]
Video was taken from my friend in my team mates 86
Shady195 is offline   Reply With Quote
The Following 3 Users Say Thank You to Shady195 For This Useful Post:
6-Shift (10-15-2017), CarzCarzCarz (09-26-2017), x808drifter (09-19-2017)
Old 09-28-2017, 07:40 PM   #1346
Kouki86
Drives: 2017 86
Is anyone using PBM rear lower control arms? Is trimming the subframe really necessary?
Kouki86 is offline   Reply With Quote
Old 09-29-2017, 03:16 AM   #1347
t_welby_86
Drives: Stock frs
It's not necessary, but I trimmed mine to make adjusting much easier!
Cheers!
t_welby_86 is offline   Reply With Quote
Old 09-29-2017, 03:47 AM   #1348
Kouki86
Drives: 2017 86
Cheers!
Thanks!
Old 09-29-2017, 02:31 PM   #1349
Shady195
Not necessary, but its a pain in the ass.
I'm probably going to get different LCA's for this reason honestly.
Not to mention im not to happy with the durability of the powdercoat they use. I've put barely put 10k on my car since i installed the PBM ones and they coating is already destroyed and they are looking rusty.
Old 09-29-2017, 06:14 PM   #1350
Kouki86
Drives: 2017 86
That sucks.. I was hoping they would be better, but I guess that's why they're cheaper than most.
Any recommendations? I've heard good things about Stance.
Old 10-03-2017, 08:37 AM   #1351
Shady195
I don't think theyre going to fail. They are really solid pieces, im just a little turned off by the coating flaking off.
Ill probably go with Stance or Voodoo 13
Old 10-06-2017, 01:06 AM   #1352
15limited
15limited's Avatar
I've had the ft86speedfactory X Velox cnc'd goodness for almost 2 years and besides some road grime look the same as when I bought them
Sent from my 2PQ93 using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
The Following User Says Thank You to 15limited For This Useful Post:
2015firestormFRS (11-03-2017)
Old 10-10-2017, 06:00 PM   #1353
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Stance is the same. I just slightly notched the subframe to allow for easier access for adjusting. However after two harsh Oklahoma winters and plenty of abuse, I can confirm they held up great and with a quick cleaning, still looked new when I parted the car out.
I think pretty much every LCA that uses a turnbuckle type of adjuster will warrant subframe notching for easier access. You can get away with not doing it, but adjusting is more time consuming.
Old 10-10-2017, 06:05 PM   #1354
eherschend
How many of you have broken axles? I'm reasonably low, make about 300whp, and heading to my first drift event this weekend.
eherschend is offline   Reply With Quote
Old 10-10-2017, 07:59 PM   #1355
TylerLieberman
Drives: '24 GR86
What tires are you running on the rear? (type and size)
Old 10-11-2017, 12:35 AM   #1356
eherschend
The Drifting Thread
Probably going to burn the stock primacy tires and possibly my Watanabe's some Toyo 185/55/r16
Old 10-11-2017, 11:04 AM   #1357
TylerLieberman
Drives: '24 GR86
You'll probably be fine. Though, I would recommend getting a spare axle to have just in case as soon as you can. The low ride height and higher power doesn't help, but at least you aren't running big wheels with wide, grippy tires.
The Following 2 Users Say Thank You to TylerLieberman For This Useful Post:
15limited (10-11-2017), eherschend (10-11-2017)
Old 10-12-2017, 08:05 PM   #1358
Shady195
A lot of factors, all comes down to how hard you shock the driveline.
I make about 400whp and drift on the stock axles, generally run 215/45/17 Westlake SA-07's, have two seasons on these so far.
I have broken 1 axle, but it wasn't drifting, it was a hard launch at a drag strip.
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 01:24 PM
BRZ Drifting. Hunter BRZ Photos, Videos, Wallpapers, Gallery Forum 7 09-20-2012 09:57 AM
So Cal drifting Thefear13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-10-2012 05:53 PM
REAL drifting thread TylerLieberman Off-Topic Lounge [WARNING: NO POLITICS] 17 02-28-2012 05:20 PM
FT-86 II (RC) Drifting ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 11-11-2011 03:02 AM
