Old 10-01-2017, 11:40 PM   #15
Somerandom18
Drives: 2017 manual BRZ
Originally Posted by Harvir View Post
What are headers, if they are something i can add later on i might.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
The Following User Says Thank You to Somerandom18 For This Useful Post:
lantsalot (10-02-2017)
Old 10-01-2017, 11:53 PM   #16
Harvir
Harvir is offline   Reply With Quote
Old 10-01-2017, 11:55 PM   #17
StraightOuttaCanadaEh
Wes
Corsa exhaust is the one I have and it's fairly loud
Old 10-02-2017, 01:08 AM   #18
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
No. I mean it is functionally identical to your opinion.
Not if my opinion changes.
(And yes, I am getting lost with this argument.)
Old 10-02-2017, 01:51 AM   #19
That depends on whether or not I can draw enough similarities between your new opinion and your previous response to OP's questions.
Old 10-02-2017, 04:03 AM   #20
Hi i am looking to make my car more louder what is a good and a loud exhaust that i should buy for my car.But I don’t want to make it too loud either.
I suggest you look into an axle back muffler ....... like nameless for example.
http://namelessperformance.com/
Old 10-02-2017, 01:58 PM   #21
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
I am not sure what I got budget is maybe 1000 or 1500. Is that a good budget.
That's a good budget. You want loud then get either Invidia or Tomei.
Here's some links.
Invidia N1
http://www.ft86speedfactory.com/invi...l#.WdJt9zVrzMg
Tomei 80, single exhaust
http://www.ft86speedfactory.com/tome...l#.WdJuNTVrzMg
Tomei is LOUDEST!
If you decide later to get a header buy a Perrin catback or Q9300 that way it won't be hella LOUD.
Perrin, 2.5 resonated.
https://www.86speed.com/products/per...k-exhaust.html
Perrin is loud when it needs to be even without a header. Good solid catback. I'll be adding a header in the future.
Invidia Q9300
https://www.86speed.com/performance/...ps-hs12sstg3s/
Q9300 is quiet on it's own. Add a header and it'll be louder when it needs to be.
Join your local FT86 club and check out their meets. You can hear all kinds of exhaust systems and ask questions.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 10-02-2017, 02:09 PM   #22
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Loud pipes save ... uh
audiologists new boat payments.
Ultramaroon (10-02-2017)
Old 10-02-2017, 02:28 PM   #23
I am just shocked that you are still able to function after reading that several times.
Old 10-02-2017, 03:25 PM   #24
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
I got catless headers then a catless custom made header-back...
let's just say it rattles the windows like a thunder storm on a cold start. So don't go custom unless you really don't mind extra noise.
In design the header back is most similar to the Perrin I reckon.
I like driving!
86 South Africa is offline   Reply With Quote
The Following User Says Thank You to 86 South Africa For This Useful Post:
Tcoat (10-02-2017)
Old 10-02-2017, 03:42 PM   #25
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
I would look into nameless exhaust set ups. Those get loud and are not too expensive. https://shop.namelessperformance.com...haust-brz-frs/
Sorry but I couldn't help it but
But I forgive you if English isn't your first language.
DandoX is offline   Reply With Quote
Old 10-02-2017, 03:51 PM   #26
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
What are your actual goals, usage habits, and intent with your car?
If you want to add power either now or later, you need to consider a header. That's where the majority of the performance gains with this car come from until you're boosting it, or swapping a different motor in.
A catless header alone will gain a bunch of power and add a decent amount of volume, but the stock exhaust sounds pretty awful with it. If you can hear a catless header with a mild catback like the Invidia Q300, or GReddy Supreme SP you can get an idea of what a typical aftermarket setup on this car sounds like.
If you want it louder than that, get a louder catback. Invidia N1 and Tomei 80R are super loud examples, Perrin, MXP SP and Dezod are good examples of the catbacks that fill in the gap.
If you make a conservative choice with catback volume and you have a header and catback, and want it to be a bit louder, you can grab a front pipe. Getting a catless one will be much louder, but if it has a high flow cat, a resonator, (or two/both,) it will split the difference.
Edit: Nameless catback, 2.5" inlet with 5" mufflers is $650, and a JDL UEL Header is $750.
If you start there, you'll enjoy a bunch of extra volume, and still be able to add more with the front pipe if you see fit.
Intelligent part selection will help you gain power, lose weight, and tune the sound you want quite a bit.
Also keep in mind when you do a header you need to accommodate for tuning. You can have a local flash an OFT map on your ECU for likely $20 or a 6 pack.
JazzleSAURUS is offline   Reply With Quote
Old 10-02-2017, 04:03 PM   #27
Somebody needs to define "loud". The actual decibel levels on many exhausts are the same but some seem much louder than others. Tone can be more important than decibel level for what somebody is actually looking for in the sound. Just going loud for the sake of loud can be a big mistake.
JazzleSAURUS (10-02-2017), Ultramaroon (10-02-2017)
Old 10-02-2017, 04:29 PM   #28
I did it for science but now I have cancer.
Tcoat (10-02-2017)
Loud exhaust / Buddy Club Spec II exhaust help! chiefshayan Engine, Exhaust, Transmission 26 12-06-2019 06:59 PM
Exhaust Advice. I want a loud exhaust system please help Rambo2469 Engine, Exhaust, Transmission 28 04-21-2017 03:41 PM
How loud is the n1 exhaust? ( in db) jon2 Scion FR-S / Toyota 86 GT86 General Forum 7 02-22-2015 04:04 AM
My exhaust is loud mike2100 Mid-Atlantic 1 08-25-2013 10:13 PM
Looking for a loud exhaust Itssrayyxd Engine, Exhaust, Transmission 66 04-01-2013 04:53 PM
