#351 |
Drives: '13 FRS - STX
Reread the alignment section again, crash bolts are manufacturer approved parts for aligning the car, they're still allowed and probably why they're specifying the 14mm spc bolt so you can put it in the bottom hole and use the bottom bolt in the top hole.
#352 |
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
I think wheel/strut clearance will be the limiting factor on front alignment. -Particulalrly with the new offset specs.
#353 |
Drives: 2013 Asphalt Scion FR-S
It is the limiting factor. The 8" wheel at about 3 degrees of camber rubs the shock. Might also have the tire rubbing on the spring. I still need to play around to see what camber level the rubbing goes away. Was going to remedy with a 5mm spacer on the 45mm offset wheel, but that's now out...
| The Following 3 Users Say Thank You to chucky12012 For This Useful Post: |
#354 | |
Drives: In Perfect Control At All Times
| The Following User Says Thank You to Cueman For This Useful Post: | Twinz (10-01-2017) |
#355 | ||
I sure as hell want it too... just to add a little bit of personality. Quote:
#356 |
I can't help but think they are steering people toward keeping the stock exhaust without actually mandating it.
#357 |
Drives: Red frs and a few 90s celicas
Will baffled midpipes be the big issue with most of the aftermarket exhaust or the 5" muffler?
#358 | |
The stock exhaust seems to do that well enough without spending extra $$$. (for those of us that still have stock exhausts laying around) |
| The Following User Says Thank You to Twinz For This Useful Post: | Shark_Bait88 (10-02-2017) |
#359 |
Drives: 2013 Firestorm FR-S
I think the best solution for exhaust is going to be buying an axleback with a baffled muffler, which there are a few options for (though it limits the options quite a bit), and keeping the stock midpipe.
Hopefully they clarify and straight through resonators are deemed legal, otherwise the exhaust rules are pretty lame for SSC.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
#360 |
My VTEC fluid is full
Drives: EFF JAY
Pardon my ignorance but are extended wheel studs allowed in SSC? I've already broken 3 wheel studs and looking to replace with ARP. I just bought the car used and the previous owner must have over torqued the lug nuts.
Wheel spacers allowed too? |
#361 |
Work dual exit muffler seems like it would play by the letter of the law but not the spirit, no mention of if the exhaust must pass through the muffler...
Edit, sorry I meant Work, not Berk.
| The Following User Says Thank You to strat61caster For This Useful Post: | Shark_Bait88 (10-02-2017) |
#362 |
I think it would fall under "industry standard repair" allowance on the wheel studs, no weight savings, but could be wrong on that given that it's an aftermarket part it could cause someone to nitpick.
#363 | |
| The Following User Says Thank You to Shark_Bait88 For This Useful Post: | strat61caster (10-02-2017) |
#364 |
| Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) | OnionTou | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 55 | 07-01-2016 01:36 AM |
| what's the difference between twin screw, centrifugal, single turbo and twin turbo? | warplane95 | Forced Induction | 86 | 04-17-2014 02:36 PM |
| my twin | RWDGUY | Mid-Atlantic | 2 | 04-08-2013 09:23 PM |
| JDM Spec-C V9 Twin Scroll VF36 complete | Nico TURBO | Engine, Exhaust, Bolt-Ons | 0 | 12-05-2012 11:20 AM |
