Old 09-30-2017, 10:31 PM   #1
joro2
joro2's Avatar
Drives: 2017 BRZ Premium MT (DGM)
"Best" Battery Tender for long term BRZ storage?
I've had to park my MY17 BRZ Premium for several (2+) months of inactivity. I'm looking to purchase a "Battery Tender" (float charger?) to charge/maintain the battery during this long term storage period. The BRZ is (fortunately) in a secure temperature controlled weather-proof private garage with access to a power outlet.
(It's actually already been stored/un-driven 5 weeks as of tomorrow/Sunday 09/30, so it's already possible the battery has lost its charge -- hence the battery tender has to both recharge a possible drained battery and also keep it on a "float" charge during the following month or two remaining in unattended storage.)
I've done the usual Google searches but no one product seems to be "the best". Does anyone here have experience with a battery tender and long term storage? I've never used one of these before and want to make certain whatever I purchase and connect to my (beloved) BRZ during this unattended storage period doesn't end up damaging the electrical system (or worse), and keeps my battery fully charged to preserve settings and crank the starter upon my return.
joro2 is offline   Reply With Quote
Old 09-30-2017, 10:40 PM   #2
ls1ac
ls1ac's Avatar
Battery Tender and Schumacher are the big names but the larger unit from Harbor freight works quite well. I have used them all on boats and cars with good success.
(After long storage check the water level.)
The Following User Says Thank You to ls1ac For This Useful Post:
joro2 (09-30-2017)
Old 09-30-2017, 11:06 PM   #3
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
I use this one "
Battery Tender 021-0123 - Battery Tender Junior 12 volt .750 amp"
http://www.canadiantire.ca/en/pdp/ba...1940p.html#srp
I store my car between 5-6 months and have no issues with this one. Plug it in and forget about it. Works great!
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
The Following 2 Users Say Thank You to Mr.Impreza For This Useful Post:
DarkSunrise (09-30-2017), joro2 (09-30-2017)
Old 09-30-2017, 11:14 PM   #4
DarkSunrise
DarkSunrise's Avatar
Originally Posted by Mr.Impreza View Post
I use this one "
I use this one as well. I think I bought it for around $20 USD and it works great.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
joro2 (09-30-2017)
Old 10-01-2017, 12:03 AM   #5
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
I have been using the Battery Tender Plus for over 5 years on my classic cars...
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
The Following 2 Users Say Thank You to nextcar For This Useful Post:
jmark (10-03-2017), joro2 (10-01-2017)
Old 10-01-2017, 02:23 AM   #6
swarb
There are usually two types, tender only, or charger(2-5+amps) and tender in one. I have a 2in1 shumacher(5amps) and it has been good for the last 4-5 months. The second cheapest 2in1 unit at harbor freight went out on me after 2 months. I believe the shumacher has a 3 year warranty.
The Following User Says Thank You to swarb For This Useful Post:
joro2 (10-01-2017)
Old 10-01-2017, 03:03 PM   #7
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
This is one of those weird things in life....(Cheap Chinese shit which actually works).
I've been using the cheapest 'automatic battery float charger' cen-tech brand named (item #42292 in my case) from Harbor freight for about two years.
I paid around $5. for it. Now listed on their site for $10. and currently on Amazon for $7.45.
Surely, wait shortly, and you'll see it again from Harbor Freight for around $5...one of their items they often greatly discount.
This battery tender has worked just fine...even recharging a battery which was low enough to not start the car...after tender was then attached to that battery for a couple of days.
I do live in a climate in which outdoor temp never gets below 27 degrees, therefore can't say how it would do elsewhere.
Note: Battery which got recharged above is a 4 year old 'Everstart plus' brand from Wallymart, which had a 2 year warranty. Cheapest place I know of to purchase a new battery.
ToySub1946 is offline   Reply With Quote
The Following User Says Thank You to ToySub1946 For This Useful Post:
joro2 (10-01-2017)
Old 10-01-2017, 09:03 PM   #8
InvalidConflict86
Drives: 2017 Toyota 86, 2007 Silverado,
So to chime in here in a different sense. I plan on putting my 86 in the garage for storage. I will be around it constantly tho. So could i just start it once a week and not have to trickle charge it?
InvalidConflict86 is offline   Reply With Quote
Old 10-01-2017, 09:20 PM   #9
ls1ac
ls1ac's Avatar
yes starting every week or two works well as long as you let the engine warm up. This is needed to dry out the condensation from cold starting and to fully recharge the battery from the starting load.
Old 10-02-2017, 12:13 AM   #10
cjd
cjd's Avatar
Drives: 2017 BRZ
I use this one on our lead acid batteries:
https://www.amazon.com/gp/product/B000FQBWCY/
Get a tender. The battery will do better and last longer. It's also nicer than trying to start/run the car enough to charge it up properly.
The Following User Says Thank You to cjd For This Useful Post:
joro2 (10-02-2017)
Old 10-02-2017, 01:37 PM   #11
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
I've used a Battery Tender plus for at least 10 years on my cars and motorcycles (when I had them). I drive a short distance every day in my BRZ, and actually hook it up to the tender every two weeks. Same thing with the Outback. I keep both car batteries fully charged whenever I remember.
shiumai is offline   Reply With Quote
The Following User Says Thank You to shiumai For This Useful Post:
joro2 (10-02-2017)
battery tender storage
AP Racing "Sprint" BBK long term update CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 90 06-18-2016 11:58 PM
Will the dealership "ECU Flash" be reset to factory after disconnecting battery? spatcha88 Engine, Exhaust, Transmission 5 04-02-2015 03:35 AM
FA20 Long Block and Port/Polish "Bare" Heads Allaskew Engine, Exhaust, Bolt-Ons 1 06-08-2014 01:48 AM
Question about Long-Term "Garaging" arleewa BRZ First-Gen (2012+) — General Topics 25 01-12-2013 10:13 PM
Hyundai Calls 2011 Sonata Turbo "Very Delicious," Reveals Near-Term Future Plans vh_supra26 Other Vehicles & General Automotive Discussions 1 02-19-2010 03:53 PM
