#267 | |
Drives: DS FRS
-Max H.
#268 |
I've expressed my hate in a header and tune for a Spec class, as you leave it open to vulnerability and removed the one thing you were trying to accomplish.
I've already written my letter against that.
Kyle H. - #89 STX
#269 |
Drives: 2013 Firestorm FR-S
Yeah, I'm also in the anti-header/tune for spec camp.
I'm wary of the Stage 3 spec tune, but will reserve judgement until a determination is made and more details are released. I highly doubt it will be OFT, since they're not a TireRack supplier. My best guess is that they are talking/working with Cobb to see about developing a flash tune for the platform, since Cobb is both a well-known entity within the Subaru community and a supplier for TR. If they can slightly reduce dip and, more importantly IMO, do something with the rev limiter/fuel cut, it might actually be pretty nice on an otherwise "stock" engine.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
#270 |
Drives: DS FRS
I can see it both ways... it's something I think would make the car more fun and is something I want to do, but it does make everything less spec and more expensive. I think it might not be good for year #1, but should be looked at for year #2.
-Max H.
#271 |
Going down the tuning path IMO is not the greatest of options. I've written it out pretty much my thoughts on tSB so I'll just copy and paste it over.
A 2013 tune vs a 2016 tune are completely different animals. Even a 2016 to a 2016 tune can be different in the parameters that are used due to how the ECU adapts to what's there. My example, which is what I also sent to the SEB regarding my stance against headers and a tune. Run 1 - was a baseline dyno WITH a canned tune that Moto-East has used regularly to send to his customers. If you were to order a tune from him and wanted it done remotely, this is what you'd get pretty much. Blue Line Run 1 As you can see, with WITH a tune, Headers, OP, Exhaust...the torque dip is still very much there. It took 8-9 runs later to end up at the final pull numbers as seen. For what it's worth, this particular dyno runs 5% short of other dynometers. As well, if you compare my tune to say a 2013, you'd see that the 2013s are able to pull harder up in the redline band and not have much of a drop-off at high RPM. I can fix this by running 100 octane when available, but still knock protection on a 2016 is much more intrusive than a 2013. If you to take my tune, load it onto another car with exact same mods, you'd probably discover different results.
Kyle H. - #89 STX
#272 |
Drives: DS FRS
OFT has tunes for 2013-2016 based on ECU type. Are you saying that their tune will net better results on one year vs another?
I have an OFT Stage 1 map I run for street driving - it definitely helps with the torque dip. Not a lot, but enough to make it worthwhile. I'm not sure it would make much difference at autocross as I don't feel the dip there very often.
-Max H.
#273 | |
Pallotta and Simmons for example, they could run their car and never encounter engine knock on ECU side and they netted some serious gains up top. My car has a lot more inherit knock encoded within the ECU which needs to be corrected w/protection. Talking with Moto-East, along with my own research, as the years for the FRS/BRZ go from 13-16, the ECUs have changed and such that more protection is coded within. So, the amount of actual knock hasn't really ever changed between a 2013 and 2016. But the ECU has become more precautionary with sensing knock and correcting it. So, yes I could probably turn off knock protection and be gain a couple horsepower...but I'm doing so now at the risk of my engine. If a spec tune came out with obvious knock protection, a 2013/14 would benefit more so over a 15/16. Make sense?
Kyle H. - #89 STX
#274 |
Drives: DS FRS
Understood - thanks for the explanation.
-Max H.
#275 |
Is half of me making sure SSC doesn't get too close to STX in terms of rules? Yea probably.
But IMO, just from the side of competition aspect - Stock Tune is about the closest you can get for driver against driver.
Kyle H. - #89 STX
#276 |
Drives: DS FRS
But I want the sound of a UEL header, dammit!!
-Max H.
#277 |
Funny, they make a class like that...
Just buy your car back already
Kyle H. - #89 STX
#278 |
Drives: 2013 Asphalt Scion FR-S
I like the idea of running header and tune in the class from a benefit to the car, but I think for health of the class and keeping it in a nice healthy place further from STX, I prefer they steer clear of it.
#279 |
Drives: DS FRS
I made an offer. They laughed.
-Max H.
#280 |
Drives: between cars...
I'm also doubtful of the header and tune combo. If you are gonna buy a header mind as well go STX.
| Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) | OnionTou | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 55 | 07-01-2016 01:36 AM |
| what's the difference between twin screw, centrifugal, single turbo and twin turbo? | warplane95 | Forced Induction | 86 | 04-17-2014 02:36 PM |
| my twin | RWDGUY | Mid-Atlantic | 2 | 04-08-2013 09:23 PM |
| JDM Spec-C V9 Twin Scroll VF36 complete | Nico TURBO | Engine, Exhaust, Bolt-Ons | 0 | 12-05-2012 11:20 AM |
