Old 08-18-2017, 01:40 AM   #141
tawheed
Drives: '13 Sport Tech
Had my alignment done yesterday, only mod is Cusco Street Zero A coilovers.. I'm not sure whether I should ask them to match the front camber to the natural rear camber, or get rear LCA to get closer to what the front is set at - daily driver.
tawheed is offline   Reply With Quote
Old 08-18-2017, 03:48 AM   #142
Lust
Drives: 2017 Subaru BRZ
More front camber and less rear camber. Get some SPC LCAs if you're on a budget. Have them fix your toe too.
Lust is offline   Reply With Quote
The Following User Says Thank You to Lust For This Useful Post:
tawheed (08-19-2017)
Old 09-19-2017, 08:46 PM   #143
mulekr1
mulekr1's Avatar
Drives: 15' Limited BRZ
Hey guys,
After reading the thread I'm understanding that when I lowered my car I got natural camber. Basically I need 0 degrees toe as well
So what's the best camber to go on all 4 wheels -2 degrees with 0 degree toe (after I raise my front suspension back up)
mulekr1 is offline   Reply With Quote
Old 09-19-2017, 09:40 PM   #144
gtengr
Drives: 2017 BRZ
Thoughts on adding ballast for the alignment? On my previous car it was recommended to be aligned with a certain amount of weight in the car. I played around with it at the shop and it made a small difference in the numbers.
gtengr is offline   Reply With Quote
Old 09-20-2017, 02:42 AM   #145
swarb
Sit in the car. Done.
If you're planning to track the car, take the spare/etc out.
Old 09-20-2017, 02:43 AM   #146
swarb
Originally Posted by mulekr1 View Post
Hey guys,
Max camber or close to 3 up front, or at least more than the rear. 2+ for the front is a good start.
Old 09-20-2017, 04:25 AM   #147
churchx
churchx's Avatar
Drives: 2014 GT86
Handling wise - depending on for what/where/how you'll use your car. For daily driving only i'd go for -1.5 to -2 front camber, -1 to -1.5 rear. If taking also to track, then -3 front, -2.5 rear. In both cases zero toe front, slight 0.1deg toe-in rear.
Old 09-20-2017, 04:57 AM   #148
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by churchx View Post
If taking also to track....
... buy a pyrometer.
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
finch1750 (09-20-2017), swarb (09-20-2017)
Old 09-20-2017, 05:07 AM   #149
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Hey guys,
Really depends on use and tire selection
Old 09-20-2017, 10:26 AM   #150
mulekr1
mulekr1's Avatar
Daily driving 20% spirited driving (I live in NYC so that's rare)
245/45/17 hankook ventus 2
Old 10-06-2017, 07:02 AM   #151
churchx
churchx's Avatar
Drives: 2014 GT86
So with stock shocks/springs, at stock height, without slotting, -3 camber front is possible even with rubber top mounts.
SPC 81305 camberbolts lower hole, Whiteline KCA416 ones in upper, Whiteline KCA434 LCA bushings anti-dive kit for slight extra caster, Powerflex PFF69-801G LCA bushings for extra camber, (non eccentric) Subaru group-N topmounts:
But it's about max for front camber (~ -3.1dg), so if more is needed, camberplates or lowering or slotting probably is unavoidable evil for extra camber.
The Following 7 Users Say Thank You to churchx For This Useful Post:
Bach415 (01-03-2018), Code Monkey (01-03-2018), R2 (10-06-2017), Racecomp Engineering (01-02-2018), strat61caster (10-06-2017), tony-brz (03-02-2018), Ultramaroon (10-06-2017)
Old 01-02-2018, 10:52 AM   #152
timmydatooth
Drives: Scion Frs
So I just got an alignment from tire kingdom. But now I notice when I drive it still pulls to the right a little bit. Is this normal or is this something I should be concerned with? I know alignments will not be prefect every single time but just don't want any extra wear on my car or tires.
timmydatooth is offline   Reply With Quote
Old 01-02-2018, 10:59 AM   #153
churchx
churchx's Avatar
Drives: 2014 GT86
timmydatooth: first things to check - tire pressures (if tires & their wear same). And who knows, what alignment really is, do you have printout? Alignment been done != alignment done right.
JazzleSAURUS (01-02-2018), Ultramaroon (01-02-2018)
Old 01-02-2018, 11:05 AM   #154
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
A car with a fresh alignment that is pulling consistently either gt a bad alignment from the get go, (either their tolerances are bad, did a sloppy/imprecise job, or they did not tighten a fastener correctly and it slipped out of alignment,) OR there is component failure occurring that they didn't notice. (A worn bushing may only show it's influence under acceleration, and it's throwing geometry out of wack every time you step on the go pedal, or slam on the brakes, for example.)
Somebody missed something, either a sloppy job, or a failing component.
Hope that helps!
JazzleSAURUS is offline   Reply With Quote
Alignment Specs? 86_ZN6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 06-10-2013 07:30 PM
Anyone do their own alignment? TemeCal Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 11-10-2012 12:36 AM
Another crash bolts alignment thread jeebus Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 10-28-2012 01:29 AM
DIY alignment dsgerbc Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-17-2012 12:41 PM
where to get alignment? FML Hawaii 2 08-08-2012 02:36 AM
