Old 10-15-2015, 03:50 PM   #15
D_Thissen
D_Thissen's Avatar
Any sound clips?
Old 10-15-2015, 05:01 PM   #16
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
Originally Posted by redlined600 View Post
It has been my assertation that the stock header with the cat removed would be as good as any sub $700 header.
Here is the one I made by welding in a collector where the cat was. More pics in my build thread if anyone is interested.
That said I can't imagine a gutted cat is good for exhaust velocity.
Thanks for putting this on a dyno.
Nice! If I had the skills, I would have probably done the same. Wishing I took pictures, but the gutted cats definitely don't promote smooth laminar flow. The transitions in the header/FP after the cat is terrible.
But if you're in the business of paying someone to remove your header/fp, cut out, and replace your cats with pipe, then you may as well buy a budget header/fp. It'll probably cost the same. The car will benefit from slightly bigger diameter tubing as well.
That being said, I'm out a couple hours worth of work and my wallet is untouched, but I've netted a couple ponies and a few ft-lbs. Worth it in my books...
Joe-G is offline   Reply With Quote
Old 10-15-2015, 05:03 PM   #17
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
Originally Posted by D_Thissen View Post
Any sound clips?
I'll try and get some later today if that helps? But I find recordings don't really come close to what most exhausts sound like in person.
Old 11-14-2015, 07:19 PM   #18
Plxdjake89
Plxdjake89's Avatar
Drives: 2013 Scion FR-S-white out
Ever get those clips?
Plxdjake89 is offline   Reply With Quote
Old 11-14-2015, 09:04 PM   #19
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
I used a Hero 3 to try and record the sound just now... It doesn't sound as good as it does in person...
Custom muffler delete, and both cats are gutted.
Video shows cold start, idle, minor blips, and banging off 4k launch control.
[ame="https://www.youtube.com/watch?v=IbA_jWi88ws"]FRS Exhaust - Gutted Header, Front Pipe, & Muffler Delete - YouTube[/ame]
Old 11-14-2015, 11:21 PM   #20
Plxdjake89
Plxdjake89's Avatar
Good looks bro, I haven't heard it yet but I'll take a listen a little later.
Old 03-14-2017, 02:34 PM   #21
Somerandom18
Drives: 2017 manual BRZ
Wonder how the 2017 revised manifold will do if gutted.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 03-15-2017, 12:25 PM   #22
Andyxin
Drives: 2017 BRZ WR blue PP
Gutted Header & Front Pipe - Dyno Inside
is it possible to weld a high flow cat on stock header?
Andyxin is offline   Reply With Quote
Old 03-15-2017, 12:38 PM   #23
churchx
churchx's Avatar
Drives: 2014 GT86
Yes, but why? Unlike with just gutting it you'll get smaller performance gains, and added costs of buying cat and paying for welding work will nullify cheapness bit. And even if primary cat in header is HF one, you won't be 100% safe from seeing cat readiness CELs. If you are ok with doing something to stock cats, aftermarket header with HF cat or even catless aftermarket header will be better choice (one stock secondary cat should be sufficient to pass smog tests, if those don't include visual checks).
Old 03-15-2017, 02:13 PM   #24
bfrank1972
Drives: 2013 FR-S Argento
Yeah the only reason I can see to gut the stock cat (aside from just for the sake of science) is for those looking to remove one of the major restrictions in our exhaust with basically no cost (other than tuning, which is a given in my book). You'd be much better off finding a proper aftermarket header with a cat if you're worried about emissions impact or noise. If you're looking to stay legal, *any* mods you do won't pass visual (unless you fool them by just gutting the cat and leaving the cat shell intact).
Old 05-17-2017, 01:59 PM   #25
NJ10
Stiggasaurus Rex
NJ10's Avatar
Drives: '14 WRB Subaru BRZ 6MT
I plan on doing this, but have sourced a cheap OP and Berk HFC FP to go along with the gutted stock header. I am a complete noob in terms of tuning, would it be safe to assume an OFT OTS EL 93 octane tune would be a good starting point for this setup?
My primary use would be for autocrossing
meh.
NJ10 is offline   Reply With Quote
Old 05-17-2017, 03:02 PM   #26
churchx
churchx's Avatar
Drives: 2014 GT86
I guess you can use OFT Stage 2 EL tune with gutted stock header, which, while not completely, is EL header, and Stage 2 tunes are for catless headers.
Old 05-17-2017, 07:52 PM   #27
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I've been gutted on Stage 2 OTS 93 tune since last summer. No probs
guybo is offline   Reply With Quote
Old 09-18-2017, 08:56 PM   #28
guybo
Huge E85 fan!
guybo's Avatar
I just found this article. Interesting read on gutting the cats.
http://www.circuitmotorsports-blog.c...-fr-s-86s.html
Power modifications for this class are very limited, basically restricted to an air filter, catback exhaust, and the allowances of a gutted cat. The rest of the mods and work are all in the chassis and safety systems.
Yes, in this series, they only allow you to gut the cats, not use an aftermarket header. You can have an aftermarket catback
Surprisingly, even with the factory header and overpipe/front-pipe in place, the absence of the main cat made a big difference in flow. Most stock header cars we tune with an intake and exhaust are around 185-190whp. A header being required to reach or exceed the coveted 200whp mark. The race prepped FR-Ss we tuned for Dynasty all made over 200whp, we were pleased!
They tuned with Ecutek
Best Catback/Front Pipe/Over Pipe/Header Combo for the BRZ? O.Z. BRZ Engine, Exhaust, Transmission 22 04-17-2019 09:44 AM
Ceramic coating header only vs header/over pipe/front pipe pixel67 Forced Induction 8 08-18-2015 02:39 PM
FS: OEM FRS/BRZ Header w/ Gutted Cat malubawla Engine, Exhaust, Bolt-Ons 10 06-06-2014 11:29 AM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
