| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: 2013 frs
Timing cover leak
I got a leak coming from my timing cover in the driver's side I'm out of warranty
Baisically what I want to know if anybody on here has resealed it themselves, I'm a tech so it's not a problem just want to know if anyone here has the list of the parts I would need to do the job I have extended warranty but if the cost of parts is less then my deductible I'd rather do it myself I'm going turbo next week so I wanna get this took care of before |
#2 |
I'm having the same issue and following this to see what's said, I can't find much as far as DIY, there was a TSB floating around on one of the threads for some o rings and had some recommended things to do if you do pull it off but I haven't been able to find it again yet.
#3 |
Drives: 2013 frs
I ordered the parts and i will be doing a DIY once this bitcj ass hurricane passes cause I have noticed that I'm not the only one with this problem
| The Following User Says Thank You to sid94 For This Useful Post: | Teseo (09-09-2017) |
#4 |
Drives: 2013 FRS
Did you ever find a good write up?
#5 |
Drives: Late 2014 Subaru BRZ
I got one of my passenger side got towards the top there's not much that you could do about it. Other than pulling the motor and resealing it. There's a liquid gasket that's applied, not a drop-in gasket unfortunately. I don't really lose much oil don't have to worry about it because my 3K oil changes. I'll deal with it when I add my rods and pistons personally.
I wish I never got divorced because my new intake manifold, rods and pistons, head studs & valve springs would be installed already. I got to wait for a new girl to move in to help me with bills before I pull the motor. But I'm already working on that.... these damn rods and Pistons have been staring at me for a year now it's really pissing me off...
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
| Timing Cover Oil Leak | AllDayJonRay | Issues | Warranty | Recalls / TSB | 18 | 06-06-2016 04:12 AM |
| Timing Cover Oil Leak | Keenercarguy | Issues | Warranty | Recalls / TSB | 66 | 05-31-2016 12:59 AM |
| Timing Chain Cover Leak | alexand3r | Engine, Exhaust, Transmission | 17 | 09-29-2015 12:05 PM |
| Oil Leak from either Timing Cover or Valve Cover | BRZY | Issues | Warranty | Recalls / TSB | 5 | 04-06-2015 09:31 AM |
| oil leak at timing cover | choi0706 | Issues | Warranty | Recalls / TSB | 8 | 09-10-2014 07:25 PM |
