Old 07-05-2012, 12:21 PM   #253
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by Kido1986 View Post
That was similar to what I was thinking but theory and actuality don't always meet up. Real results trump estimated math.
Eh, I'll trust the theory :P These aren't estimates anyhow, it's either more fuel or less, and past the stoichiometric point the more fuel you add the less you get.
serialk11r is offline
Old 07-05-2012, 12:25 PM   #254
Visconti
Drives: 05 STi
I'm all for real results - math.
Its just too soon.
Once a few of these cars get a few more miles on them I'll be able to report back with info.
I wouldn't be surprised with there was a bump in fuel economy.
Visconti is offline
Old 07-05-2012, 12:52 PM   #255
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
I know this has been covered before but I want to ask.... if I were to have my car tuned will I then have a method of reflashing back to stock for the sake of warranty work and then back to the desired state over again once I get the car back?
Sent from my Galaxy Nexus using Tapatalk 2
Chewie4299 is offline
The Following User Says Thank You to Chewie4299 For This Useful Post:
Visconti (07-05-2012)
Old 07-05-2012, 12:55 PM   #256
Visconti
Drives: 05 STi
This is a good question.
With the EcuTek ProECU cable you'll be able to flash the car back to stock, then put the tune back in it whenever you want!
Let me know if you have anymore questions
John
Visconti is offline
The Following User Says Thank You to Visconti For This Useful Post:
Lytheum (07-05-2012)
Old 07-05-2012, 01:21 PM   #257
feedbag
Seasoned Spirit
Drives: 2013 DGM BRZ Premium
Does the ECU have some sort of flash counter / modification flag / efuse that gets triggered upon flashing a new map?
feedbag is offline
Old 07-05-2012, 01:25 PM   #258
Visconti
Drives: 05 STi
Ecutek has their own.
When the car gets a dealer flash update the dealer tools mark the ecu with a time stamp and thingy to know it was updated with dealer tools and not some after market thing.
It doesn't automatically update, only the dealer tool can update that special marker.
If you did go to the dealer for a flash update you would dump the rom send it to me and I would insert the tune on that OR just save it as your stock rom.
But the dealer isnt checking anything unless you come in broken - so you have nothing to worry about + friendly with one of my local dealers so
Visconti is offline
Old 07-05-2012, 02:18 PM   #259
cruzinbill
Drives: Argento 6spd FR-S
What about the TPMS light going off when you swap back to your old wheels? Not everyone wants to mount/dismount tires to get to their TPMS sensors to swap them every year. That's you working for your car, not your car working for you.
Ah, ok see I didnt know you were tryin to keep both sets of wheels. You could always have sensors in both sets, would just have more initial cost.
cruzinbill is offline
Old 07-05-2012, 04:00 PM   #260
OrbitalEllipses
Drives: Attitude
Not keep the other set? You plan on driving on summers all year?
OrbitalEllipses is offline
Old 07-05-2012, 04:18 PM   #261
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Can you please post the actual dynojet files or post a new graph with SAE correction factor and smoothing of 5 which is the industry standard as I am sure you know. Did you have a tach signal? Why did you post in MPH? Also conditions of each run would be nice.
King Tut is offline
Old 07-05-2012, 04:35 PM   #262
zelix
Drives: 2013 Asphalt FR-S
Originally Posted by arghx7 View Post
I don't trust you. Why should I? You're trying to sell me something. Is this forum already that commercialized? We all know that whatever number you put in that post people will be repeating over and over again and there's zero standardized practices for this stuff. Just because you paid a vendor fee doesn't mean you shouldn't be held accountable for your claims.
Perrin's numbers make sense--I'm sure they leaned it out some and so did you. Why are you getting three times (depending how you calculate it) their numbers in terms of horsepower gain? Are you advancing the timing more? You can't be doing much with cam phasing because there's very little cam phasing near redline.
Buddy if youre skeptical dyno your own car or look at other tuners results for baseline power srt is getting 167hp stock and like 174 with exhaust so there baseline numbers are similar
zelix is offline
Old 07-05-2012, 04:47 PM   #263
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
So just to clarify this 18hp was with a header, or did the owner put a header on right after getting a tune?
Also, why do you have speed as your x axis instead of rpm?
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline
Old 07-05-2012, 04:49 PM   #264
Visconti
Drives: 05 STi
Read the last two pages...
Visconti is offline
Old 07-05-2012, 04:54 PM   #265
Superhatch
AIM4APX
Superhatch's Avatar
I did. I'm just wondering if the dyno prior to the header was just so that you could show a base number gain? I read where you said "BONE STOCK" but then talked about the owner having a header on it.
It seems weird to have your car tuned, then go buy a header but no other exhaust pieces, and then come back for another tune.
I didn't see the x axis mentioned since the graph. I'm assuming it's just not set correctly when the test was run.
Old 07-05-2012, 05:04 PM   #266
Visconti
Drives: 05 STi
We had a problem picking up the tac signal ... so no rpm or trq.. But you get the picture.
This car I tuned is a shop car and they are testing out parts for a few different guys.
So normally your right - wouldn't make sense.
So car had no boltons during baseline and STG1 flash.. Now has a header, waiting to hit the dyno again
John
Visconti is offline
FS: BRZ & 86/FR-S pre-release memorabilia bambbrose Miscellaneous 16 11-19-2012 01:38 PM
SOA and BRZ Release lies SkullWorks BRZ First-Gen (2012+) — General Topics 62 05-02-2012 08:49 AM
Release Series rL-gT Scion FR-S / Toyota 86 GT86 General Forum 55 01-18-2012 02:02 PM
Cellphones, Software, Transportation Toyota introduces Touch Life smartphone mirrorin quik1987 Other Vehicles & General Automotive Discussions 0 10-27-2011 03:27 AM
