Old 09-02-2017, 06:28 PM   #1
Q2
Drives: 2015 FRS Whiteout
350whp
So I'm completely new to this I have a 2015 scion frs completely stock except the wheels which I may change soon and the fact the owner before me cut out the grille weight reduction I guess. Anyways I use to always hear my brother brag about his 300whp Acura RSX type S which is actually pretty impressive and fun to drive minus the stage 3 clutch anyways in a effort to beat his car and overall throw it in his face that my car is sexier and faster than his. What would I have to add to make my frs hit around 300-350?
Q2 is offline   Reply With Quote
Old 09-02-2017, 06:31 PM   #2
Somerandom18
Drives: 2017 manual BRZ
Turbo/supercharger
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 09-02-2017, 06:34 PM   #3
Q2
Originally Posted by Somerandom18 View Post
Turbo/supercharger
I was looking at the MAP Performance's turbo kit would that work?
Old 09-02-2017, 06:38 PM   #4
Somerandom18
I don't know much about turbo kits for these cars as I never plan on going FI. I'm sure someone else will chime in soon enough to answer any FI questions you may have. Personally I'd go with an Edelbrock supercharger since that brand is known quality and dates back to the beginning of time. I'm also just a fan in general of those type of FI systems. Mmmmm.. the flat torque curve.
Old 09-02-2017, 06:41 PM   #5
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Here you go.
https://www.86speed.com/products/jdl...turbo-gtx.html
JDL UEL Turbo kit,
This one I'm assuming has the GTX2860.
If you really wanna embarrass your brother,
E85 Flex Fuel kit
Get injectors and pump from whatever your tuner recommends, usually DW700 but the new trend now is ID1050x
E85 can get you to 350-400whp easily depending on how crazy you wanna go.
Alltezza is offline   Reply With Quote
Old 09-02-2017, 09:22 PM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
Factor in a potential engine rebuild for that power too.
.: Stealth 86 :.
Kodename 47 DJ:
Old 09-02-2017, 09:33 PM   #7
IDFWU 420
Honarary Member
IDFWU 420's Avatar
Drives: 2015 FRS
If you don't have much to afford, the SBD 500x with e85 at 10 psi will easily beat the RSX.
$3k + installation + tune.
IDFWU 420 is offline   Reply With Quote
Old 09-03-2017, 01:49 AM   #8
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Turbo plus other supporting mods such as clutch and etc... Not cheap. The general rule of thumb for street turbo setup is cost of turbo times 2 for the supporting mods and tune.
Don't get stuck on the numbers of "350". The video below is probably around 270whp on a Mustang dyno (likely 300 on Dynopack). Judge for yourself if this is around the power you want. I personally don't want anymore power than this for the longevity of my motor. I drive most often running far less boost, only adding more boost and better fuel for the race track.
rb6freak is offline   Reply With Quote
Old 09-03-2017, 02:41 AM   #9
This is probably the worst reason to go FI I have ever heard.
The numbers game at it's very best.
Got an extra $10k kicking around? Something tells ma not.
If you do I look forward to the "is this totalled?" Thread to come.
Ultramaroon (09-03-2017)
Old 09-03-2017, 06:11 AM   #10
CSG Mike
CSG Mike's Avatar
Supercharger + E85.
Easiest, simplest solution, with the least number of things that can fail, with proven reliability, both on the street and track.
Cal3000 (09-09-2017), Tcoat (09-09-2017)
Old 09-08-2017, 07:52 PM   #11
Q2
I like your point it honestly makes more sense to get something a little lower since I'm not gonna be on a track that often and that looks like definitely enough to have fun with.
The Following User Says Thank You to Q2 For This Useful Post:
Tcoat (09-09-2017)
Old 09-09-2017, 03:34 AM   #12
Cal3000
Drives: Panda FR-S
Supercharger + E85.
This right here. My motor has 145k miles on it at 300+whp.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
The Following 2 Users Say Thank You to Cal3000 For This Useful Post:
86 South Africa (09-14-2017), Tcoat (09-09-2017)
Forced Induction Kits Putting Out Around 300-350Whp SalM Forced Induction 13 11-05-2012 03:07 PM
