go_a_way1, MisterSheep
Old 09-01-2017, 09:48 AM   #17417
Darth Khan
I think therefore.....
Darth Khan's Avatar
Drives: Toyota 86 860 Halo White (Manual)
Turned around looked at it lovingly and gave it a reassuring wave that I would be back at 5:00pm for the drive home
May the N.A. force be with you.
Darth Khan is offline   Reply With Quote
Old 09-01-2017, 10:16 AM   #17418
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Originally Posted by MasonL1997 View Post
Changed out the stock front pipe for a 1320 Performance Catless Dual Resonated Front pipe, sounds great with the Invidia Q300 catback. No drone, no rasp, really great deep rumble.
Yeah im running the HKS dual resonated FP, Yours is basically the knockoff but looks great for half the price. Along with HKS Legamax premium catback which is another quiet style like the Q300. I also have the Gruppe-s UEL catless header the combination sounds great with a rumble and no rasp or drone. The only thing with no cats is a bit of smell. If you go with a header I would consider a catted version not for the sound but for some smell reduction.
SuperTom is offline   Reply With Quote
The Following User Says Thank You to SuperTom For This Useful Post:
MasonL1997 (09-05-2017)
Old 09-01-2017, 10:49 AM   #17419
Weigaldo
Weigaldo's Avatar
Drives: 2016 Steel AT FRS
Coincidentally I just placed my order for a Tomei UEL and OP to go with my HKS FP and Tomei 60R... My neighbors will love me.
Weigaldo is offline   Reply With Quote
Old 09-01-2017, 12:02 PM   #17420
Teseo
Drives: frs
I would love you more if you can post a video about your set up
Old 09-01-2017, 12:14 PM   #17421
Weigaldo
Weigaldo's Avatar
I'm going for the same sound as Anthony (he has a video on youtube), and hopefully flames. I can hear the afterfire already, just need get the cat out of the way... It could take a while though as it looks like the OP isn't in stock.
Old 09-01-2017, 05:40 PM   #17422
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I changed my transmission fluid to Motul300, adjusted my reverse lockout so I don't get locked out of 2nd gear when shifting fast out of first, and relocated my USB port to the glove box. I will put a toggle switch in the blank spot for something eventually. I like keeping my ipod in the glove box, I don't need everyone who walks by my car seeing the telltale white cable....
Sent from my SM-G930V using Tapatalk
SuperTom (09-01-2017)
Old 09-01-2017, 05:54 PM   #17423
stock
stock's Avatar
Drives: 2015 FRS Steel (manual)
Well, not today, but very recently a first track day for my FR-S.
I've been so hesitant, but did well and most important, had a great time.
I've put a few mods on my car, but in this case I let it out to run.
stock is offline   Reply With Quote
The Following User Says Thank You to stock For This Useful Post:
Overdrive (09-01-2017)
Old 09-02-2017, 02:29 AM   #17424
Is Always Angry
Is Always Angry's Avatar
Drives: Low and Slow
Ah, this is why I bought a *black* cable! Would've saved you a lot of work
Is Always Angry is offline   Reply With Quote
Old 09-02-2017, 05:41 AM   #17425
rookietopro_frs
rookietopro_frs's Avatar
Drives: 2013 Scion FRS
I'm trying my best to wait for Black Friday, so I can stock up on parts at a better price.
rookietopro_frs is offline   Reply With Quote
Old 09-05-2017, 06:06 AM   #17426
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
Hi guys I'm a little confused by what is written in the owners manual concerning the headlights
I know that when you put the handbrake down with key to on position, the drl lights come on but it says in the manual that the headlights come on too at a lower intensity .
For me it's only my drl that comes on and not the headlights
Sorry for my confusion and thanks in advance
Sent from my SM-G925W8 using Tapatalk
Young_makaveli is offline   Reply With Quote
Old 09-05-2017, 08:21 AM   #17427
Ashikabi
Ashikabi's Avatar
They mean the drl. The drl and high beam are the same light. I disabled my drl because I have custom halos
Old 09-05-2017, 12:11 PM   #17428
mrderp
ಠ_ಠ
mrderp's Avatar
Drives: 860 SansOverspray
Swapped most of the black interior parts back to their silver counterparts.
Removed anything I changed underhood.
I said goodbye to my Monogram this morning. Hopefully it will find a good owner.
The kouki steering is odd. It's even thinner than the already pretty thin FR-S one.
Pictures / FS thread soon
mrderp is offline   Reply With Quote
The Following User Says Thank You to mrderp For This Useful Post:
Jizzfunk (09-05-2017)
Old 09-05-2017, 03:23 PM   #17429
Young_makaveli
Drives: 2013 frs
Ah ok by headlight I thought they were referring to the low beam, I knew the drl and high beam were the same light
DRL = daytime running lights and high beams
Headlights = low beams
Old 09-05-2017, 06:44 PM   #17430
MasonL1997
MasonL1997's Avatar
Drives: Man
Send a message via AIM to MasonL1997 Send a message via Yahoo to MasonL1997
Ohhhh.......you should have taken the wrapping off it before you installed it....
Too bad it's too short .....
I thought ya'll down under there shouldn't mess with the OE exhaust system .....
However, it sure is perty .....
Hmm that funny plastic burning smell may have explained itself then
I was honestly worried about the length of it before I put it on. It does look shorter than the stock one by a little bit. Although once I got under there and put it on. Fitment was perfect.
Yeah down under we aren't meant to touch anything to do with the cats. We can do exhaust work, however the police can be fairly strict on it. Although you have to be doing the wrong thing for them to pull you up on it.
MasonL1997 is offline   Reply With Quote
The Following User Says Thank You to MasonL1997 For This Useful Post:
humfrz (09-05-2017)
