Old 08-28-2017, 11:48 AM   #1
Kris86
Kris86's Avatar
Drives: RHD Gt86
Will not idle when cold
Hey guys, been getting hit with every single thing in the books with this build still here trying to iron things out, got my low vacuum issue sorted out, turned out to be the GDI injector seals issue now is, when doing a cold start, the engine fires up right away but would not idle.. I can keep my foot on the throttle until it warms up some until you can hear it come out of the cold start map and then it would idle perfectly.
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
Old 08-28-2017, 10:35 PM   #2
Turdinator
Señor Member
Turdinator's Avatar
What mods and tune are you running? Does the car drive fine once its up to temp?
1974 TA22 Celica
2013 86 GT
Old 08-28-2017, 10:54 PM   #3
steve99
Drives: FT86
Ill assume that cold startup is only issue and car runs ok after that and new injectors are scaled and latency is set up.
Car starts on port injection only.
During the cold start routine the fueling is richened via the "maf offset after start" table.
also reduce the post start ignition timing from -15 to say -6
Log you AFR and if its getting to rich maybe decrease the offsets in the table
Old 08-29-2017, 11:01 AM   #4
Kris86
Kris86's Avatar
Drives: RHD Gt86
Hey, I've got this issue ever since I rebuilt my engine and went with a turbo kit.
dw 900cc injectors, FBM 485 pump kit.
Once the car warms up and comes out of the "warm up map" it will idle perfectly smooth, once warm enough I can also lock it off and it starts back just fine.
I'm currently doing customs remote tuning with my tuner
Old 08-29-2017, 11:03 AM   #5
Kris86
Kris86's Avatar
Drives: RHD Gt86
Hey Steve thanks for ur reply,
I could pass ur message onto my tuner, just hope I won't come across rude to them as if I don't have faith in them
Old 08-29-2017, 09:37 PM   #6
steve99
Drives: FT86
double check for leaks on intake and exhaust side especially bov. small leaks have most effect at idle ans low rpm
(Spark?) Knock on cold start idle nickw14 Software Tuning 0 04-07-2015 12:41 PM
Low idle? MadeInSweden Issues | Warranty | Recalls / TSB 2 12-09-2014 03:15 AM
AFR @ Idle woode Forced Induction 12 01-19-2014 08:38 PM
How cold is too cold to seal and wax? Jertronic Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 11-01-2013 11:20 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
