Old 08-24-2017, 10:11 PM   #1
SwaggFPS
SwaggFPS's Avatar
Drives: 2016 BRZ Limited
Flasher issue
I recently purchased the DEPO BLACK HOUSING TAIL LIGHTS along with the OLM VISION AMBER LED TURN SIGNAL BULB. I'm not sure if it's the tail lights or the LED bulbs, but my flasher is faster that normal. Like if one of the turn signals had a burnt out light. The hazards though, blink at a normal speed.
Do I need a new flasher relay? or is there a way to reprogram them to blink at a normal speed?
Mid-TN
SwaggFPS is offline   Reply With Quote
Old 08-24-2017, 10:40 PM   #2
BRZyJ
BRZyJ's Avatar
Drives: 2013 BRZ Limited / 2024 G70 3.3T
Yep, a relay or resistors.
Good choice BTW, I have those as well...the best looking tail lights for these IMO.
BRZyJ is offline   Reply With Quote
The Following User Says Thank You to BRZyJ For This Useful Post:
SwaggFPS (08-25-2017)
Old 08-24-2017, 10:40 PM   #3
Chimera
Drives: FRS
You need an led flasher relay
The Following User Says Thank You to Chimera For This Useful Post:
Old 08-25-2017, 10:27 PM   #4
SwaggFPS
SwaggFPS's Avatar
Thank you both, I'll look into getting one.
Mid-TN
Flasher Relay Help STZ Cosmetic Modification (Interior/Exterior/Lighting) 12 08-29-2019 11:01 AM
FS: TapTurn Flasher toeout Exterior Parts (Aero, Lighting, Etc.) 1 04-24-2017 02:12 PM
BRZ OEM Flasher brzsubarusti13 Exterior Parts (Aero, Lighting, Etc.) 0 04-26-2015 07:56 PM
LED Flasher 6spd Exterior Parts (Aero, Lighting, Etc.) 2 08-08-2014 12:19 PM
Diy F1 rear flasher? eppikos123 DIY (Do-It-Yourself) Guides 37 07-25-2014 10:07 PM
