Old 07-22-2017, 07:52 PM   #15
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
Also the radio reception is really good. It supports HD radio ( needs optional box) also supports OTA tv (w/adapter).
Sent from my Pixel XL using Tapatalk
Rican_D is offline   Reply With Quote
Old 07-22-2017, 07:56 PM   #16
allowe
allowe's Avatar
Did it come with a back up camera? I'm trying to see the difference between joying and this. They have different processors
allowe is offline   Reply With Quote
Old 07-22-2017, 08:17 PM   #17
Rican_D
Rican_D's Avatar
Yeah it came with backup cam
Old 07-22-2017, 11:23 PM   #18
FR-S Guy
Drives: '14 Whiteout FR-S
What wiring kit did you need for it?
Was there no way to dremel around the bezel to squeeze it in to the stock trim piece?
FR-S Guy is offline   Reply With Quote
Old 07-23-2017, 12:05 AM   #19
Rican_D
Rican_D's Avatar
This Look at this on eBay http://www.ebay.com/itm/271942724505
If you mean the HU I didn't want to risk doing damage.
Old 07-23-2017, 12:16 AM   #20
Rican_D
Rican_D's Avatar
Update** the mirroring works fine
Old 07-23-2017, 12:51 AM   #21
FR-S Guy
Nice. Thanks for the feedback.
Pretty sure I'm gonna get one to try out. Will I need anything else other than that bracket and wire harness set?
Appreciate the help!
Old 07-23-2017, 01:27 AM   #22
Rican_D
Rican_D's Avatar
I already had the other two items which are the antenna adapter and the USB adapter to keep the factory USB location.
Old 07-23-2017, 02:22 PM   #23
thewongster
Drives: 2013 BRZ Sport-tech
This may also be a good alternative option from HIZPO, this would a good alternate option that would not require the side pieces I'm thinking: https://www.amazon.com/Android-Unive...s=hizpo+toyota
thewongster is offline   Reply With Quote
The Following User Says Thank You to thewongster For This Useful Post:
BRZyJ (07-23-2017)
Old 07-23-2017, 02:52 PM   #24
BRZyJ
BRZyJ's Avatar
Drives: 2013 BRZ Limited / 2024 G70 3.3T
Interesting...says 204mmX103mm, wonder if it would be a tight fit. The Toyota specific Joying's are 200x100. An exact fit unit with 1024x600 resolution is what I've been waiting for. Even the newest 2GB/32GB 200mmx100mm models from Joying still have 800x480 screens for some reason.
BRZyJ is offline   Reply With Quote
Old 07-23-2017, 03:51 PM   #25
thewongster
Dasaita and xtrons
I hear ya... personally I've been looking for this Toyota fit one by Dasaita with the better resolution:
Toyota fit: https://www.aliexpress.com/store/pro...800492477.html
They also sell a universal fit one that would fit but for sake of fitment part of me is still leaning towards the Toyota-fit with the premium price tag...
Universal fit: https://www.aliexpress.com/store/pro...612.0.0.pWONZh
There are also options from xtrons but I'm not a fan of the DVR from xtrons. Toyota fit: http://xtrons.com/pb76hgtap-6-95-hd-...or-toyota.html
Old 07-23-2017, 03:56 PM   #26
FR-S Guy
I'm going to assume that the fit should be the same as OP, since he seemed to have issues with the vertical height, which the ebay listing he bought it from also lists at 103 mm. Also the width for the one OP got was 182, so I guess the one you linked should fill the sides a bit better, however you lose some screen size for an additional bank of buttons.
Old 07-23-2017, 04:17 PM   #27
Rican_D
Rican_D's Avatar
I like the modular approach they are taking with these new units, as far as the rear outputs are concerned. You don't have to have unused wiring in the back since outputs are separate harnesses.
Old 07-23-2017, 05:49 PM   #28
thewongster
I like the DVR that Dasaita uses with "their" app. Many of the companies seem to use a proprietry style DVR that will link up with their apps... For example xtrons will not neccesary work with just any DVR you attach to it unforunately, same with Dasaita or Joying.
Android head unit drz400dude Electronics | Audio | NAV | Infotainment 6 12-20-2016 01:47 AM
200mm android head unit with android lollipop rsingh Electronics | Audio | NAV | Infotainment 3 05-23-2016 09:48 PM
Another Android Head Unit Starscream15 Electronics | Audio | NAV | Infotainment 57 08-23-2015 01:41 AM
FS: T7019A Android Head Unit pheoxs Audio/Visual, Electronics, Infotainment, NAV 4 08-26-2013 06:05 PM
Android head unit drei Electronics | Audio | NAV | Infotainment 21 07-16-2012 03:42 AM
