Old 07-14-2017, 01:42 PM   #29
willimusk
willimusk's Avatar
Drives: 2017 BRZ PP CWP
That's a drag. Do any of the Bass Boost settings make any audible difference?
willimusk is offline   Reply With Quote
Old 07-14-2017, 02:31 PM   #30
Krion
Drives: 2017 BRZ
Not really. It sounds like all the bass lines and kick drums are coming through the mid speakers. It sounds distorted and really dull. I have no idea what could be causing this. I mean the car never had good bass before but it was definitely noticeable and would at least vibrate the door panels with the volume turned up.
Krion is offline   Reply With Quote
Old 07-14-2017, 02:49 PM   #31
willimusk
willimusk's Avatar
Seems your HU is not communicating bass properly. Changes in the bass boost options are pretty dramatic for me.
Old 07-14-2017, 03:17 PM   #32
Krion
Drives: 2017 BRZ
I've touched every single setting I could find on the damn thing with no results. I don't know if it could possibly be defective or possibly wired wrong.
Old 07-14-2017, 03:22 PM   #33
willimusk
willimusk's Avatar
I doubt it is defective. I'd guess wiring.
Old 07-14-2017, 06:15 PM   #34
Krion
Drives: 2017 BRZ
I think it may be the crossover settings. If it's not too much trouble, could you post a picture of what yours are set to?
Old 07-14-2017, 06:21 PM   #35
HBKeazy!
Drives: 2017 Toyota 86
Are they the stock speakers?
HBKeazy! is offline   Reply With Quote
Old 07-14-2017, 06:34 PM   #36
Krion
Drives: 2017 BRZ
They are. I realize the stock speakers have awful bass but I was able to get a decent amount with the stock head unit. I can't get anywhere close to what it was now that I have the Kenwood installed. I'm almost positive that the issue is the Xover settings though.
Old 07-14-2017, 06:51 PM   #37
HBKeazy!
Kenwood DDX917WS head unit -- any installed?
I listened to my speakers before I bypassed the amp and it was a difference. It did sound loud and not as clean at first when it was connected to the oem amp.
http://www.ft86club.com/forums/showthread.php?t=42239
That's where I got the info and idea on how to bypass the amp. So instead of connected it to an external amp I just connected the corresponding wires together, and I had to buy the adapter to. Just read the post entirely so you can understand what I'm saying. It would make sense that the 6.5 speaker producing the lower notes would be effected since it's amplifying and amplified signal.
Old 07-14-2017, 07:26 PM   #38
Krion
Drives: 2017 BRZ
Well I found the issue. My door speakers just aren't getting any signal. There's no sound coming from them at all haha. I was just listening to tweeters and the speakers in the back.
Time to take it to the shop.
Old 07-14-2017, 07:49 PM   #39
HBKeazy!
Check your fuses, you probably blew the oem amp fuse.
Old 07-15-2017, 02:28 PM   #40
willimusk
willimusk's Avatar
I'm embarrassed to say, my door speakers aren't working, either! After adjusting the bass boost and other effects, I was getting decent enough bass not to notice at first. Checked the fuse and it looks fine. Seems the HU is just not communicating with the amp that powers the door speakers. I have an email in to Carbon. They installed one of these in a 2017 BRZ, so they should have some insight.
The Following User Says Thank You to willimusk For This Useful Post:
driggity (07-17-2017)
Old 07-15-2017, 08:12 PM   #41
Krion
Drives: 2017 BRZ
The issue is with their harness. I forget exactly what the audio guy I took my car to said but it did indeed have something to do with how it's connected to the amp. He ended up wiring something in and now it's fine.
Sorry, I know that probably doesn't help too much!
The Following User Says Thank You to Krion For This Useful Post:
willimusk (07-16-2017)
Old 07-17-2017, 01:53 PM   #42
Jakinit
Drives: 2017 CWP BRZ Limited (MT)
Maybe I'm glad I didn't go with the carbon setup. I should be getting the last piece I need for my camera to work shortly. After that I am fully functional. Minus the stock USB..the toyota USB adapter did not work for me.
Jakinit is offline   Reply With Quote
Kenwood DDX916WS head unit -- any installed? willimusk Electronics | Audio | NAV | Infotainment 39 07-27-2017 11:47 AM
Kenwood DDX630WBT Toyota-spec head unit w/ nav install in US GSX-R35 Electronics | Audio | NAV | Infotainment 17 05-26-2015 04:37 PM
Anybody know ... what head unit this is? chaoskaze Electronics | Audio | NAV | Infotainment 3 12-21-2014 07:44 PM
Soo i installed a new head unit....gaps Sniper2606 Electronics | Audio | NAV | Infotainment 2 01-16-2014 06:12 PM
Toyota sized Kenwood Navigation unit Laurie Electronics | Audio | NAV | Infotainment 36 09-26-2012 01:07 PM
