Old 05-14-2017, 05:59 PM   #43
choi0706
Drives: t
how effective would it be to just have larger naca ducts without the large vent in the front?
choi0706 is offline   Reply With Quote
Old 05-14-2017, 11:00 PM   #44
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
I'm guessing that it'd be even worse than no ducts at all, since there'd be no where for the air to flow out. The NACA ducts might add positive pressure to the engine compartment; reducing the airflow through the radiator. IMHO, the vent is the most important part of this hood. As I understand it, the vent allows hot air to exit the engine compartment and also creates negative pressure, which draws more air through the radiator than no vent at all. The NACA ducts are secondary to that.
shiumai is offline   Reply With Quote
Old 05-14-2017, 11:26 PM   #45
choi0706
Drives: t
I wonder what it'll look like paint matched to the car.
Old 05-14-2017, 11:27 PM   #46
choi0706
Drives: t
Even setup in reverse?
Old 05-15-2017, 12:42 AM   #47
shiumai
shiumai's Avatar
Not sure I follow you - can you describe what you're envisioning?
Old 05-20-2017, 01:42 PM   #48
shiumai
shiumai's Avatar
OK, got my hood on Thursday. I bought it to reduce under hood temps during stop and go traffic in summer, and to increase efficiency of the radiator by increasing airflow on spirited drives. It should work the same as cutting vents in the OEM hood, which I didn't want to do. I'm not expecting it to reduce peak oil temps but to aid in coolant recovery time between pulls during occasional canyon runs.
I'm leaving it unpainted (it comes with a clear coat) because it's an additional cost, it blends in pretty well with my DGM car, and if I ever need to return to stock, it's easier to sell an unpainted CF hood.
Observations - it's very light and rigid. The backing structure around the perimeter makes it stiff, and it doesn't feel flimsy at all. The rear corners are slightly high (maybe 1/8"), so I've let Joel know about that for future builds. No biggie to me. All the holes for the OEM rubber/plastic seals are drilled and the seals transfer over perfectly. I got mine with the tubes to direct airflow from the NACA ducts down to the coil packs, but I haven't installed them yet. There's probably no need to install them for daily driving, but might be nice to have them for canyon runs or track.
Visit this thread for pics - screw photobucket: http://www.ft86club.com/forums/showt...t=43402&page=6
The Following 8 Users Say Thank You to shiumai For This Useful Post:
ajaxthebetter (05-20-2017), FRS_Ken (05-30-2017), GTHachiRoku (06-25-2017), johan (05-20-2017), Kestrel (05-25-2017), PuslarBrrrz (02-18-2019), yberther (12-12-2018), zigzagz94 (06-06-2017)
Old 07-13-2017, 10:37 PM   #49
avishenoy1
avishenoy1's Avatar
Drives: 2015 FR-S Release Series 1.0
Pics are dead for me
avishenoy1 is offline   Reply With Quote
The Following User Says Thank You to avishenoy1 For This Useful Post:
TheBRZsKnees (10-01-2019)
Old 07-13-2017, 11:57 PM   #50
shiumai
shiumai's Avatar
They're dead for everyone else, too because of photobucket. visit this thread for pics: http://www.ft86club.com/forums/showt...t=43402&page=6
The Following User Says Thank You to shiumai For This Useful Post:
avishenoy1 (07-14-2017)
Old 07-14-2017, 01:44 PM   #51
shadow_772
Drives: 2014 BRZ Limited
I'd say that's the best looking hood I've seen so far!
shadow_772 is offline   Reply With Quote
The Following 4 Users Say Thank You to shadow_772 For This Useful Post:
Clipdat (07-14-2017), shiumai (07-14-2017), vintagemxer (07-15-2017), yberther (12-12-2018)
Old 02-06-2018, 08:57 AM   #52
Paulo86
Paulo86's Avatar
Drives: Toyota GT86 euro version
i want to put one on my 86 in france, i'm edelbrock supercharged, jackson racing dual radiator, built engine etc
i want one to reduce the temp + put out the air at high speed because stock hood flex on the sides at 150mph+
the big question is will it be safe to drive sometimes in germany at 186 mph with stock latch ? or will i take it in the windshield ^^
Paulo86 is offline   Reply With Quote
Old 02-06-2018, 09:51 AM   #53
shiumai
shiumai's Avatar
If I was planning on driving that fast, I'd definitely install hood pins.
Old 07-24-2018, 02:59 PM   #54
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Originally Posted by MPHfab View Post
Confirmed fitment with the edelbrock supercharger today. It just barely touched the intake tube but was able to close with normal pressure and didn't touch until all the way latched. We also noticed the mounting brackets for his airbox were slotted and could have been moved down about an 1/8" and wouldn't have touched at that point. https://www.facebook.com/MPHfabricat...29530573844478
Any chance this will fit the Cosworth Supercharger? Thanks!
botbs is offline   Reply With Quote
The Following User Says Thank You to botbs For This Useful Post:
MrDinkleman (07-24-2018)
Old 07-24-2018, 07:57 PM   #55
MrDinkleman
Drives: 2016 Oceanic, "base" model
Something I've always wondered about extraction vents (which made me hesitate about installing one in my other cars): does the heated air get sucked into the cabin, either through the cowl vent or open windows? It might be fine in Winter but definitely would suck in summer...
TIA
Edit: p.s. nice looking good. Very clean and finished look...
MrDinkleman is offline   Reply With Quote
Old 07-24-2018, 08:18 PM   #56
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
MPH Carbon Fiber hood with reverse scoop and NACA ducts!
The orientation of the ducts doesn't matter that much in this case, since they are so close to the windshield. This is a high static pressure area, as opposed to further towards the front where the extractor is, which is a low static pressure area. The high pressure will force air into the engine bay even if you turn the NACA ducts backwards.
APR Carbon Fiber Radiator Cooling Plate & Brake Ducts LANI86 Exterior Parts (Aero, Lighting, Etc.) 3 12-21-2016 07:19 PM
Looking for R35/GT-R Aero data... on the NACA ducts Kiske Other Vehicles & General Automotive Discussions 0 03-03-2016 09:34 PM
Hood Venting, NACA Ducts Lunatic Scion FR-S / Toyota 86 GT86 General Forum 70 02-08-2015 12:10 PM
NPA: APR Carbon Fiber Brake Cooling Kit with Ducts - A must for track days 86_Insider Brakes, Suspension, Chassis 1 09-26-2013 02:39 AM
APR Performance Carbon Fiber Brake ducts! enjoi23 Cosmetic Modification (Interior/Exterior/Lighting) 16 06-01-2013 03:56 PM
