Old 07-13-2017, 05:17 PM   #1
Gray Fox
Gray Fox's Avatar
Car won't start, not battery
Hello, friends!
So, my car has been having issues starting lately. I have a push start brz, and sometimes when I try to start the car I hear a single click, and no crank. after trying a few times the car would start. Some days it starts on the first try. Other days, it takes a few tries. Today, it wouldn't start at all, so I took the battery to get tested, and it's still good (less than 6 months old). I then moved on to the alternator. Got it out and took it for testing too. Alternator is also good. Okaaaay... so, my only conclusion now is that the starter is faulty. What do you guys think? Thanks ahead of time for the help!
Gray Fox is offline   Reply With Quote
Old 07-13-2017, 07:23 PM   #2
I know this is the most basic of things but did you try cleaning the terminals really well and put the battery back in? Even clean looking terminals can have a thin coat of oxides that will give exactly those symptoms.
Gray Fox (07-13-2017), guybo (07-13-2017), Scrappydoo (07-13-2017)
Old 07-13-2017, 08:25 PM   #3
retoocs
Try placing the key fob next to the push button start. If it starts up, replace the battery on the key fob.
retoocs is offline   Reply With Quote
Old 07-13-2017, 08:41 PM   #4
^^ good suggestions ......one old school, the other new school ......
Old 07-13-2017, 08:47 PM   #5
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Sounds like a starter solenoid to me. There's also a starter (ignition) relay which is much easier and cheaper to replace so it's worth a look, but my money's on the solenoid. Reman starters should come with the solenoid attached.
BirdTRD is offline   Reply With Quote
Old 07-13-2017, 09:04 PM   #6
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Doesn't the click mean the solenoid is working, but the starter isn't getting enough current? I had this happen on a really old Subaru before, and it turns out the ground cable was corroded. A bit early for that to be happening on a 14 though. I'm assuming there hasn't been any electrical work done recently?
Gray Fox (07-13-2017), Tcoat (07-13-2017)
Old 07-13-2017, 09:10 PM   #7
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Mechanically and partially electrically working, yes, but if the contacts inside that pass the current thru from the battery to the starter motor are worn or corroded, the starter won't spin, just get the solenoid click x1.
I'm sure @humfrz and @Tcoat have done the 'ol screw driver across the solenoid terminal trick when they were mounted near the battery.
It would be worth checking the connections at the starter to make sure they are good.
The Following 2 Users Say Thank You to BirdTRD For This Useful Post:
Gray Fox (07-13-2017), Spuds (07-14-2017)
Old 07-13-2017, 09:11 PM   #8
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I don't know why you'd think it's alternator. There's 2 things a single solid click might be:
1) battery terminal. If you have aftermarket cheap-o terminals that are painted, scrape off the paint from the inside of the terminals and clean up the terminals and make sure they are very tight and no corrosion
2) starter is about to shit the bed. Often they will start to go intermittently then one day it'll just fail altogether. If you have a standard, it's no big deal. If you have a slushbox, you're gonna need a tow so get AAA.
My money is on B. Often happens just after getting a new battery. And now that it's hot out, starters start to fail a lot.
guybo is offline   Reply With Quote
The Following User Says Thank You to guybo For This Useful Post:
BirdTRD (07-13-2017)
Old 07-13-2017, 10:46 PM   #9
Yep, run a piece of #9 wire from the battery to the starter and with a screwdriver, start touching things together till you hear a click and/or a whirring or the starter turns the flywheel.
Watch your eyes from a shower of sparks, in case you don't get it right. Oh yes, gloves are handy if that wire heats up ......
OR ....... just get the crank out from under the seat ......
Old 07-14-2017, 04:17 AM   #10
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
There doesn't happen to be a yellow flashing key symbol on the dash, is there?
- The Ancient BRZ Sacrament
by Zaku
Old 07-14-2017, 05:02 AM   #11
steve99
Drives: FT86
Or the clutch switch is intermittent if manual
Or the park switch if its auto
Old 07-14-2017, 08:59 AM   #12
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
That wouldn't lead to a single click though. I had this issue, car just went into accessory power mode.
Old 07-15-2017, 01:51 AM   #13
Gray Fox
Gray Fox's Avatar
Thanks for the suggestions, guys. I ended up removing the starter and took it to get tested, and it turned out to be good as well, which really surprised me. Starter itself looked pretty dirty, so I checked the cables that connected to the starter, and they were incredibly dirty as well; turned out to be the source of the issue! Cleaned them really well and she starts up just fine now, no hesitation whatsoever. Super happy I saved money on parts thanks to you guys
The Following 3 Users Say Thank You to Gray Fox For This Useful Post:
Guff (07-15-2017), lantsalot (09-12-2017), Tcoat (07-15-2017)
Old 07-15-2017, 10:20 AM   #14
JD001
JD001's Avatar
Drives: Subaru BRZ
Dirty connections.. now where have I heard that before???
Car doesn't start without fully charged battery. frsq5 Issues | Warranty | Recalls / TSB 6 06-09-2017 10:59 PM
Key battery dies, anyway to start firs manually. cfee40 Electronics | Audio | NAV | Infotainment 11 05-21-2017 12:31 PM
Losing all battery voltage when trying to start car. armstrom Issues | Warranty | Recalls / TSB 14 11-18-2016 04:15 AM
Car WON'T START dead battery? AnthonyArcaro Issues | Warranty | Recalls / TSB 17 01-19-2016 01:00 AM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 07:06 PM
