Old 07-13-2017, 06:51 PM   #1
bju90
Drives: Toyota 86 GT Manual
Roll Center
Has anyone actually measured the roll center and CG heights (either stock or lowered)?
Thought it might be worth checking before I go measure myself.
bju90 is offline   Reply With Quote
Old 07-13-2017, 07:14 PM   #2
JoeC
Drives: Subaru BRZ Limited
I assume roll center is the balance point of the car from the front to the back and the CG is the center of gravity from the ground to the roof. is that correct?
How would you go about measuring either of those?
JoeC is offline   Reply With Quote
Old 07-13-2017, 07:40 PM   #3
Gunman
Drives: 2019 Mazda Miata RF
Roll center:
http://www.morsemeasurements.com/tec...-roll-centers/
Cg
http://www.longacreracing.com/techni...spx?item=42586
The Following 2 Users Say Thank You to Gunman For This Useful Post:
JoeC (07-13-2017), strat61caster (07-13-2017)
Old 07-13-2017, 08:12 PM   #4
JoeC
thanks. some interesting reading there. The roll center is still over my head...
Old 07-13-2017, 08:34 PM   #5
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
http://www.ft86club.com/forums/showthread.php?t=26661
But I think it's worth checking yourself.
ineedyourdiddly
bju90 (07-13-2017)
Old 07-13-2017, 08:54 PM   #6
Gunman
https://en.wikipedia.org/wiki/Roll_center
Simply put, it is the point, or axis, that the car rolls around, when cornering. It gets more complicated, once you put dynamics into it, and the roll center starts to migrate.
Some suspension engineers design around it, others nearly ignore it. I've worked with both.
The Following User Says Thank You to Gunman For This Useful Post:
Old 07-13-2017, 10:30 PM   #7
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
You small?
Scrappydoo is offline   Reply With Quote
The Following 2 Users Say Thank You to Scrappydoo For This Useful Post:
bju90 (07-14-2017), JoeC (07-13-2017)
PArt Shop Max Roll center knuckles. laextreme5 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 03-14-2017 10:07 PM
Roll Center Adjusters, Tie bar, BNIB nickmerronesucks Brakes, Suspension, Chassis 20 05-06-2016 10:37 AM
Roll Center correction Mikepage Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 03-14-2016 04:22 PM
Whiteline Front Roll Center Kit - Anyone have and can review? stockysnail Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-17-2015 04:36 PM
Roll center location? :iono: BRZranger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 54 09-05-2014 10:20 AM
