07-06-2017, 11:52 PM | #1051 | |
@anthonysestito
Drives: 2013 Sterling Silver Metallic BRZ
Did this, worked for about 5 seconds then froze again. Did it 4 more times...still nothin. Really hoping @Shiv@Openflash can chime in or respond to my emails. Sent from my iPhone using Tapatalk
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO |
07-11-2017, 03:24 AM | #1053 | |
Drives: FT86
G
I think the wording in the tune read.me file was something like Openlash Header -Stock air box (any filter is fine) -91 or (better yet) 93oct fuel from a quality Top Tier brand (Shell, Chevron, 76, etc,.)" Yes it will run on 91 but will be much better on 93,,. Id like to see a log of the ofh specific tune on 91 i suspect their would be some knock, especially when pushed hard Its a more agressive tune than the older 93 tune timing and fueling wise |
07-11-2017, 10:20 AM | #1054 | |
The engine doesn't feel lively with the 91 tune on 93 octane, nor did it increase gas mileage. Sent from my SM-G930V using Tapatalk
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
07-11-2017, 07:59 PM | #1055 | |
Drives: 2013 FRS
You are correct I just pulled the read me file up... I will throw that OFH tune on and do some logging... Granted here in Portland the highest I can get is 92OCT
07-12-2017, 05:16 PM | #1056 |
Drives: 2013 brz
Is open flash tablet manager mac compatibly yet?
07-12-2017, 07:04 PM | #1057 |
Drives: DGM BRZ
I just bought a used tablet and when I plug it to the car nothing happens. If I plug it into the computer the screen turns on and everything seems fine. Any ideas? I tried googling but couldn't find any similar issues.
07-12-2017, 07:31 PM | #1058 |
Drives: 2013 Asphalt 6spd
If it works with the comp, but not the car it could likely be the cable. The connector on the Tablet side has small open square sockets, if they get stretched open they won't make contact or will make poor contact causing a flicker/reset. (which is what mine was doing). look with a magnifying glass and light, If they are even slightly bent open, I would bet this is the issue. If you have a small jewlers screwdriver, or pick/scribe you can try to gently bend the sockets closed again.
Phantom ESC, OFH, OFT, K&N Drop in
The Following User Says Thank You to Target70 For This Useful Post: | jubella2 (07-12-2017) |
07-12-2017, 10:46 PM | #1059 |
Drives: DGM BRZ
Problem solved. There is an OBD fuse on the inside panel that was blown. Replaced that and the tablet booted right up. @Target70 thanks for your response.
The Following User Says Thank You to jubella2 For This Useful Post: | Target70 (07-13-2017) |
07-15-2017, 10:36 PM | #1060 |
Drives: frs
How accurate is the oil temp on OFT? Mine's are on 203 - 228 on spirited driving
07-16-2017, 12:22 AM | #1061 |
The Dictater
Drives: '13 Red Scion FRS
07-16-2017, 05:31 AM | #1062 |
Drives: frs
07-16-2017, 10:18 AM | #1063 |
The Dictater
I recommend finding the part number in the tech manual, then looking that up. I haven't read through it, but the manual might have the basic specifications for the sensor in there too.
http://www.ft86club.com/forums/showthread.php?t=12135 |
07-16-2017, 07:53 PM | #1064 |
Drives: 2013 FRS
I went ahead and tried to do a 3rd gear WOT but ran out of room before I could get to redline. BTW this is on 92oct OFT & OFH using the OFH tune. I just got a K&N drop in filter so after I read up on tuning and logging I will be doing another. I realized how little I know about tuning and the OFT has got me really interested in learning more...
Similar Threads | ||||
WTB: Open Flash Tablet | TOZER | Canada Classifieds | 3 | 07-05-2015 07:13 PM |
Open Flash Header & Open Flash Tablet | Calavera | Engine, Exhaust, Bolt-Ons | 9 | 05-11-2015 08:27 PM |
FS: open flash headers / open flash tablet - SOLD | alanhung85 | Canada Classifieds | 12 | 02-10-2015 02:08 PM |
FS: Open Flash Tablet (OFT) | mex2309 | Engine, Exhaust, Bolt-Ons | 1 | 10-29-2014 02:49 PM |
Open flash tablet. | cooldandani | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-22-2014 07:14 PM |
