#15 | |
Drives: between cars...
#16 | |
Drives: 2014 BRZ
#17 | ||
Drives: '13 FRS - STX
It's my understanding that while they are independent systems they both get turned off via pedal dance. I never meant to imply they were the same. |
#18 |
Drives: 2014 BRZ
I don't see any mention of Auto LSD or Brake LSD in the Pedal Dance thread. Is there a reference about it somewhere else?
#19 | ||
Mentioned here as well: http://www.ft86club.com/forums/showp...02&postcount=7 Guess I just drew my own conclusions (that could be false), the "auto-LSD" feature didn't really come to light as an explanation until a year or two after this initial "research" and it's rare for anyone to go back and update a technical post years later. |
| The Following User Says Thank You to strat61caster For This Useful Post: | Sleepless (07-11-2017) |
#20 | |
Imagine having brakes suddenly being applied to one corner of the car at 125+. I've experienced it, and can replicate it at will. Pedal dancing eliminates this behavior. So does a mechanical LSD (like Cusco or OS Giken). Normally, it's pretty seamless, particularly at lower speeds. When it happens at triple digit speeds... code brown may result. I've seen some cars fly off at T8 of WSIR (very bumpy 120+ corner) because of the E-diff function. The corner itself is only about 0.65G lateral, but the bumps can let a wheel spin, and then it gets scary. |
#21 | |
| E-Brake issue "clunking noise" when pulling the e-brake while rolling. | Kinzo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 55 | 06-20-2018 11:14 PM |
| Diagnosing a brake noise, need help.. | Subie_Nubie | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 12-27-2017 03:47 AM |
| Brake pedal release noise | FR-YES | Issues | Warranty | Recalls / TSB | 4 | 10-19-2014 05:39 AM |
| Loud clunk noise when i pull E-Brake | Deagle50 | Issues | Warranty | Recalls / TSB | 28 | 09-20-2014 02:01 AM |
| rear brake noise | norcal_brz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 08-19-2013 04:25 PM |
