Old 07-03-2012, 03:50 PM   #1
Cheddar
Saving them pennies...
RPF1 are coming in 17x9 5x100 in Nov!
Checked tirerack today and it shows RPF1 in 17x9 5x100 will be Est. Availability: 11/09/12
Front and RearYaY!!!!!!!
Cheddar is offline   Reply With Quote
Old 07-03-2012, 03:54 PM   #2
bneale
bneale's Avatar
Drives: Scion FR-S
That's great news. I've been looking into getting a set of these. But I'm worried I may have some rub when going to full lock on the stock suspension. Others have reported this so this is why I'm so interested.
Any idea if these will work on the stock suspension without having any rub issues? I realize tirerack checks fitments and all, but I'm still a little worried about ordering without confirming this.
After all, its like $1000+ for a set of 4. I'm looking at these in black with Dunlop Star Specs for my autocrossing wheels.
bneale
bneale is offline   Reply With Quote
Old 07-03-2012, 03:59 PM   #3
Cheddar
bneale
Well in the wheel fitment thread theres a car with 17x9 (cant rememeber the offset) fitting with stock suspension.
Old 07-03-2012, 04:06 PM   #4
bneale
bneale's Avatar
Drives: Scion FR-S
That doesn't help if they are not the same wheels or offset.
I've searched the wheel thread and if you read, they are actually 17x8 and not 17x9 for the RFP1's.
Only the Mach V's seem to fit right now and none of them fit with a 255 tire. Everyone seems to say they rub.
EDIT: Just so everyone is on the same page, the big problem right now with 17x9's and 255 tires is the spring coils themselves. With a 255 tire, the sidewalls will actually rub against the coil when the tire compresses under deflection. So while people have fitted them on the car, under loads they start to rub. People with coilovers are able to get around this because the spring coils are smaller then stock. Thats why I want to confirm fitment on stock suspension.
bneale
Old 07-03-2012, 04:38 PM   #5
Cheddar
Ohh i'm thinking of going 245s
Old 07-03-2012, 04:44 PM   #6
bneale
bneale's Avatar
Drives: Scion FR-S
Thats what I'm thinking also. 245 should be enough tire but I'm still kinda worried about fitment. Not all tires are the exact same size after all.
205 Toyo R1R is the same size as a 225 Hankook RS3. The Toyo's are freaks though.
Have you thought about 17x8 instead? 235's should fit on 17x8's instead. Are you doing some serious track duty or autocrossing?
bneale
Old 07-03-2012, 04:49 PM   #7
Cheddar
bneale
Nope nothing serious just trying to fit a wide rim with a nice size tire to get a semi stretch look going.
Old 07-03-2012, 05:02 PM   #8
Matt Andrews
Matt Andrews's Avatar
Drives: race cars
255's will fit with stock suspension on 17x9's like the Mach V. in fact, my mach V's show up today. See my last blog entry on wheel fitments. we used a 949 wheel with spacers to create the right offset. but it fits for sure.
bneale
11/19/12 - Just back from Redline TimeAttack's demo event. Video and write up in link below.
http://fecompetition.wordpress.com/
https://www.facebook.com/FECompetition
Matt Andrews is offline   Reply With Quote
Old 07-03-2012, 05:31 PM   #9
Cheddar
You got a set of 6ULRs?! Must see pics!
Old 07-03-2012, 05:40 PM   #10
bneale
bneale's Avatar
Drives: Scion FR-S
I've seen your blog and I like it. But the only problem with the 949 wheels is that they are sold out and its not clear on if they will be getting more or not.
Also, did you really need the spacer? I prefer to do it without the spacer if possible but I can understand if it didn't work without it.
bneale
Old 07-03-2012, 05:42 PM   #11
Cheddar
If been wanting a set but no one has them!
Old 07-03-2012, 05:50 PM   #12
bneale
bneale's Avatar
Drives: Scion FR-S
You could do that with just a different offset though. Why don't you simply pick a 17x8 wheel with a goofy offset and a skinny tire? You'll acheve the same look without having to go to an actual 9 inch wide rim.
The only reason why I say this is because 17x9's in 5x100 are hard to find right now. They are also going to cost you more money then 17x8's and there is way more styles to choose from in 17x8 size.
The reason why I want the 17x9 size is purely for tire fitment and track use. I want my contact patch to be as wide as possible for track use and I don't want to sacrafice that 1 inch.
bneale
Old 07-03-2012, 06:20 PM   #13
Matt Andrews
Drives: race cars
I didn't add a bunch of spacers for the purpose of running the wheel on the street. we added spacers just to understand what fits. the standard offset of the 949 wheel doesn't fit with a 255 tire. the 6mm of spacers just made it clear the spring and stay inside the wheel well. But if you want to see a picture, there is on in my blog in my signature.
My Mach V's get here today according to the fedex tracking info. They are hub centric, and perfect offset for 255s.
Old 07-03-2012, 06:44 PM   #14
Jdogg180
Jdogg180's Avatar
Drives: 2008 Fit Sport
All this is telling me is my initial guess of 17 or 18x9.5 +38 with a 255, coilovers and around 2-3 degrees neg camber will fit and function perfectly. Love reassuring information like this^
Jdogg180 is offline   Reply With Quote
WEDSSPORT TC105N - 17x8.0 +42 / 17x9.0 +35mm 5x100 ~ 15 Lbs Per Wheel RavSpec Wheels and Tires 72 12-04-2012 03:58 PM
OEM Stockers vs my new Hankook RS3's both 215/45/17 WoW! Blk RPF1 wheels MarkRacerX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 08-13-2012 09:00 PM
WORK Emotion Kiwami - 17x9.0 +38mm 5x100 *** BRZ/FRS Spec *** RavSpec Wheels and Tires 5 07-19-2012 06:44 PM
TE37SL - 17x8.5 / 17x9.5 / 18x9.0 5x100 Pre Order Available Now ! RavSpec Wheels and Tires 2 07-14-2012 10:37 PM
Why is the 5x100 PCD ? adprokid Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 02-21-2012 05:22 PM
