Old 07-06-2017, 03:39 PM   #99
Originally Posted by Derek J View Post
So I realized today that I can't turn off the daytime running lights and it seems they use they same bulb as the high beams. Can I purchase a bulb that doesn't have the daytime running lights?
Personally, I'd rather just rather use the low beams for this purpose....
On yours, the DRL is actually the high beam. It can be programmatically disabled using the dealer's Techstream app, or maybe Carista but I'm not sure about that one.
Some just disconnect the series resistor which is behind the little access panel under the front bumper on the right side.
Old 07-06-2017, 03:41 PM   #100
Originally Posted by Glight View Post
Got it!! Thanks for the welcome and your comments, will keep that in mind about being less defensive. Cheers
Sheesh!
humfrz (07-06-2017), Tcoat (07-06-2017)
Old 07-06-2017, 03:44 PM   #101
Sheesh!
I think sheesh should be spelled with one more 'e'. I also don't think the ! is required.
humfrz (07-06-2017), Ultramaroon (07-06-2017)
Old 07-06-2017, 03:48 PM   #102
Oh, man, don't even...
Old 07-06-2017, 04:00 PM   #103
I have to fill at least 3 pages to maintain my rep!
Old 07-06-2017, 05:29 PM   #104
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
WELCOME, there, @Glight ......
You have sure done a lot of nice things to your car in a short period of time ....
I suggest you try to be a bit less defensive about your posts. Usually, if a poster is trying to say something directly to you they will quote you.
For example, some signs of disapproval from some of the regulars are like so:
@Tcoat - will start a 3 page debate
@Ultramaroon - will just go sheeeesh
@Scrappydoo - will post something unintelligible
and humfrz will give you a .........
Got it ..??
Some things are only unintelligible to Humfrz.
Small print
Opening medicine caps
Laces
Front and rear on an incontinence pad etc.
Are these my feet?
Scrappydoo is offline   Reply With Quote
Old 07-06-2017, 06:16 PM   #105
Small print
Laces
Are these my feet?
Well now, that's not quite accurate.
small print - I just don't bother to read it
medicine caps - I just use a hacksaw to open them
laces - my bedroom slippers don't have laces
front and rear of pads - it don't matter, I don't change them till they are completely soaked, front and rear.
are these my feet? - unintelligible
Scrappydoo (07-07-2017)
Old 07-06-2017, 06:44 PM   #106
You're off to a weak start on this one ....... oh, where is @Gforce when he's needed ...... ??
Old 07-06-2017, 06:48 PM   #107
Calling him isn't going to do you any good!
Old 07-06-2017, 07:10 PM   #108
Oh, I forgot ....... he went bye-bye ..... again.
Old 07-06-2017, 08:49 PM   #109
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
But one could argue from an efficiency standpoint that the 3rd "e" is redundant...
The Following User Says Thank You to Spuds For This Useful Post:
Ultramaroon (07-07-2017)
Old 07-06-2017, 08:58 PM   #110
The third e does add weight to the rear. It could probably be corrected by using the springs from a 17.
Spuds (07-06-2017)
Old 07-06-2017, 10:47 PM   #111
juicyg6
juicyg6's Avatar
Drives: 2017 Toyota 86
Another suggestion for you which is what I did.
If you care about your car, get some paint protection to make your life easier when you wash and maintain your car.
Window tints if you want to do that as well.
Then grab a shift knob - aesthetically it improves the look of your interior and "performance" wise it will make your shifting feel better
juicyg6 is offline   Reply With Quote
Old 07-07-2017, 12:57 AM   #112
Silver Supra
Hombre
Silver Supra's Avatar
Drives: 1994 Supra Turbo
Originally Posted by KnightRyderx2 View Post
If you didn't specify I would have mistaken that for drive across Kansas.
Except there would be a tornado cloud mixed in........
Silver Supra is offline   Reply With Quote
P2096, Completely stock. cbell7492 Issues | Warranty | Recalls / TSB 6 01-31-2016 11:10 PM
200+ WHP Completely Stock Vehicle, E85 and EcuTeK ProECU RaceROM Only (VIDEO) DeliciousTuning Software Tuning 156 07-01-2014 09:37 PM
Any issues with Hoosiers on a completely stock BRZ for autocross? Thrustin Tracking / Autocross / HPDE / Drifting 66 03-06-2014 12:43 PM
Tire PSI for completely stock autocross? bladesamurai Tracking / Autocross / HPDE / Drifting 16 06-11-2013 11:07 AM
Completely stock BRZ / FR-S needed AMR Engine, Exhaust, Transmission 11 04-03-2013 11:01 AM
