Old 07-03-2012, 02:30 PM   #561
Lonewolf
Lonewolf's Avatar
Drives: Moped
Originally Posted by Marrk View Post
Do we have this documented? If so, I'd like to see it.
There was a poster who attended a tech meeting and stated that they were told that the first three gears have triple cone synchros. I don't recall seeing any official documentation with the synchros mentioned, but maybe someone with access to a repair manual can post it up.
The Following User Says Thank You to Lonewolf For This Useful Post:
Marrk (07-03-2012)
Old 07-03-2012, 02:40 PM   #562
OrbitalEllipses
Drives: Attitude
There's a document floating around on the forum that details the specifications of the transmission.
EDIT: Found it here.
Lonewolf (07-03-2012)
Old 07-03-2012, 03:11 PM   #563
jeebus
Originally Posted by Fenrir View Post
Gonna post this in all the idle chirp threads I can. Just got back from the dealership where a Subaru corporate rep was taking a look at my car due to front bumper fitment issues, and I asked him about the chirping noise.
He says they've been holding classes for techs on the new motors, and their demo cars are all doing it. As of right now, it's a known "issue" and it's been logged that people are complaining about it. This is what he had to say about it.
"The issue has been classified as a normal noise to the Direct Injection high-pressure release valves when operating under normal conditions. It's intermittent in that the DI/PI systems work in tandem, and it will only generate noise when operating under specific circumstances which are most likely at engine idle. Every single car (Scion, Toyota, and Subaru) will emit this noise at some point in it's life. There is no current plan to investigate a fix unless enough people whine about it."
More or less a direct quote. Yes, he said whine.
They logged a report on the issue saying that I found the noise detrimental. Cars are noisy and I'm not gonna get my panties in a bunch over it, but FOR YOU GUYS I told him that I "didn't mind either way, but I guess I would prefer if it didn't make the noise."
Subaru Rep: "hey aren't you the same group of kids that like to make their blow off valves as noisy as possible? We thought you'd like this!"
jeebus is offline   Reply With Quote
Old 07-03-2012, 04:35 PM   #564
Marrk
Drives: Honda Fit
Note: When I test drove the FR-S, I found the 3-4-5-6 shift a little awkward. The 1-2 shift was fine. The car had 40 mi. on the odo.
Marrk is offline   Reply With Quote
Old 07-03-2012, 09:50 PM   #565
csaba
Drives: scion tc
What he said its sad.
How can he say its should be acceptable . When they desinged the engine they should have think of it it will be an issue for most people. Its the 21st century who wants a loud noise engine, otherwise people would buy a diesel !!
I can see this DI/PI. Combo ,one of them gonna go away for 2014/2015 model year. So they gonna end up DI or Port injection.
Cause of the noise unless they come up with a solution
csaba is offline   Reply With Quote
Old 07-03-2012, 10:03 PM   #566
Jared0934
Jared0934's Avatar
Drives: Strawberry Pie
I'm pretty sure a minor "noise" complaint wont make them change the design of the engine if the DI/PI combo is working as planned... I think for the most part people, myself included, are just curious about it because it's not something we've experienced and heard before.
Jared0934 is offline   Reply With Quote
Old 07-03-2012, 10:20 PM   #567
celicafan
Drives: Whiteout FRS
not really sure if this is the correct thread to post this in, so forgive me.
I don't have any issues with the rpms when the car is idling at a stop, but here is what I have noticed:
when I let my foot off the gas, put in neutral and coast, the rpms drop just below 500 and jump back up as the car is slowing down, and as I apply the brakes to completely stop, the car sounds like it is going to stall out.
But when I coast while in gear, and apply brakes at the end, put the clutch in just before coming to a complete stop, rpms are completely normal, no jumping and no stalling sound at all.
Not sure if this is normal for this car, but all the cars I've had have never done this (I have only owned manuals). Thoughts?
celicafan is offline   Reply With Quote
Old 07-04-2012, 01:19 AM   #568
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
My car does exactly this. Two ways I can make the rough idle noise produce
1) >40mph in 5th or 6th. Put it in neutral and let it coast; no gas pedal. Car slows down on its own. Once the car slows past 36-38mph the noise happens. Every single time.
2). >50mph in 5th or 6th. Put it in neutral and apply brake to stop. Once the car slows past 20ish mph the noise happens. Every single time.
Dealer documented it, and I got Scion NA involved. Dealer thinks something is up in the transmission. The last update I got from Scion NA is "no update. Still researching. Will call you back in a week"
My take is that if the car idles long enough it will make the noise (DI/PI switch?) or the transmission does not fully disengage when in neutral causing the lugging (holy shit, but not likely)
F1point4 is offline   Reply With Quote
Old 07-04-2012, 02:07 PM   #569
enigmaaron
enigmaaron's Avatar
Drives: '13 Firestorm FR-S MT, '04 Tacoma
Only 225 miles on mine so far but I thought I would point out that my idle is consistent at 650rpm. Seems like everyone reporting this issue is idling at 800 then drops to 400, correct me if I'm wrong? Maybe a clue as to what's going on?
If I turn the AC on it will dip to 500 for a moment, bounce up to 750-800, then come right back down to 650 all in a matter of 1-2 seconds. Also, no crickets here yet (fingers crossed) in case anyone is tracking a correlation.
enigmaaron is offline   Reply With Quote
The Following User Says Thank You to enigmaaron For This Useful Post:
Marrk (07-04-2012)
Old 07-04-2012, 03:12 PM   #570
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
Actually DI systems are more noisy by nature and are often equated to sounding like deseil motors. They have great potential Performance wise. I wouldnt trade the funny noises for less hp personally and I can't really understand why someone would care about a small chirping sound that you can't even hear inside the cabin. This is a $25k sports car not a Lamborghini.
blu_ is offline   Reply With Quote
Old 07-04-2012, 03:34 PM   #571
Lonewolf
Lonewolf's Avatar
Drives: Moped
The funny thing is that the Lambo will probably have much more serious breakdowns...
Old 07-04-2012, 04:02 PM   #572
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
Lol I was referencing the sound lambos make
Old 07-04-2012, 04:24 PM   #573
Lonewolf
Lonewolf's Avatar
Drives: Moped
Derr, I'm an idiot. That sound is godly...it really is something to hear a monster V10 behind your head....
Old 07-04-2012, 11:28 PM   #574
Hanzo
Hanzo's Avatar
Drives: Waiting for the ND Miata
I am just expecting my brz to idle better than or equal to my Honda fit. I don't think that's asking for much. Now I am actually developing a tweet noise during driving condition which it's becoming annoying.
Hanzo is offline   Reply With Quote
A Small Easter Egg avusblue Scion FR-S / Toyota 86 GT86 General Forum 28 06-29-2012 12:38 AM
Subaru BRZ - The biggest small car ever Laika BRZ Photos, Videos, Wallpapers, Gallery Forum 7 06-09-2012 02:21 AM
Received my FR-S with a small ding Neurytic Scion FR-S / Toyota 86 GT86 General Forum 10 06-03-2012 01:53 PM
Isn't 6-10 miles on a new car kinda high? houseofsuffering BRZ First-Gen (2012+) — General Topics 45 05-15-2012 01:32 PM
Kinda make me worry! (Radiation related thing) EJ20 Off-Topic Lounge [WARNING: NO POLITICS] 32 05-09-2011 01:58 AM
