Drives: 2016 Black subaru BRZ limited
Reading the dip stick
Hello all,
Does any one have any tips for trying to read the dip stick? Every time I use it I only get a bit of oil along the edge of the stick and its impossible to read. Is this how it is for everyone or am I just useless... lol let me know guys! |
#2 |
Killed Scion
Drives: 2013 FR-S Whiteout
If you're only getting oil along the side, try changing the direction of the dipstick (as in change the way the dipstick is positioned). If that doesn't work then your oil is definitely low.
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
| The Following 3 Users Say Thank You to MisterSheep For This Useful Post: |
#3 |
I have read here that scuffing up the dipstick with some scotch-brite makes it much easier to read. I haven't tried it but it makes sense. It's easier to see the glossy oil against a matte surface than it is against the shiny surface of the oem dipstick.
If you do try it, make sure all the abrasive dust is cleaned off before you stick it in. Don't contaminate your engine. Sounds obvious but it still bears mentioning.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | soulreapersteve (07-03-2017), Tcoat (07-02-2017) |
#4 |
Drives: 2014 BRZ Limited
| The Following 6 Users Say Thank You to extrashaky For This Useful Post: | lantsalot (07-05-2017), MasonL1997 (07-05-2017), pfaffendorn (07-03-2017), Spuds (07-04-2017), Tcoat (07-02-2017), Ultramaroon (07-02-2017) |
#5 |
Well, yes. I suppose that is true.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Tcoat (07-02-2017) |
#6 | |
I have done this (sort of) with every car I have owned in the last 20 years. I score the dipstick horizontaly between the holes. Not only is it easier to see the oil against the rough surface it actually holds more of it in place on the dipstick.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | soulreapersteve (07-03-2017), Ultramaroon (07-02-2017) |
#7 |
Hombre
Drives: 1994 Supra Turbo
| The Following User Says Thank You to Silver Supra For This Useful Post: | Scrappydoo (07-03-2017) |
#8 |
| The Following User Says Thank You to Tcoat For This Useful Post: | spike021 (07-03-2017) |
#9 |
Does scoring it randomly or vertically ruin the effect?
#10 |
Well it is only basically horizontal so is pretty random. I suppose vertically would have almost the same effect of having the oil stick better. Just don't score too deeply or the car will be off balance to sink like a stone in a turn.
| The Following 9 Users Say Thank You to Tcoat For This Useful Post: | Drakiv (07-03-2017), gravitylover (07-03-2017), JD001 (07-04-2017), Mr.ac (07-04-2017), Scrappydoo (07-03-2017), Silver Supra (07-03-2017), Somerandom18 (07-04-2017), Spuds (07-04-2017), Ultramaroon (07-03-2017) |
#11 | |
#12 | |
Drives: 2014 ssm BRZ Limited 6M
By the way, while we're speaking of oil, I have also found that adding a pint or so more oil above the top hole in the dipstick results in a smoother startup and less metal-on-metal noise on the road. I know I'm probably courting some kind of disaster, but I feel less engine noise means less wear and tear, and it seems to work the same way with both my BRZ and our Legacy 2.5 (which made a horrifying clatter for a few seconds after pushing the start button, but not anymore). And the music of the exhaust is much more enjoyable. Any comments, y'all?
There are worse things to worry over.
#13 |
I thought wiping and re-inserting was a given. If not then, yes. Pull, wipe, insert, pull, read.
Do not overfill unless you know for a fact where the hard limit is. I don't.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | pfaffendorn (07-05-2017), Teseo (07-04-2017) |
#14 |
Drives: Subaru BRZ
| The Following User Says Thank You to JD001 For This Useful Post: | pfaffendorn (07-05-2017) |
| OFT not reading ECU | Gray Fox | Software Tuning | 12 | 08-02-2017 06:44 PM |
| What can I stick this onto... | GhostRai | Other Vehicles & General Automotive Discussions | 28 | 07-05-2017 06:24 PM |
| Reading Vin # | Knightmare | BRZ First-Gen (2012+) — General Topics | 2 | 11-16-2012 01:26 PM |
| RPM stick between 3.5 - 4.5 | Realm | Engine, Exhaust, Transmission | 6 | 09-18-2012 01:10 PM |
