Old 06-08-2017, 03:13 PM   #841
Rybot
Rybot's Avatar
Drives: Subaru BRZ Series.Blue
Originally Posted by Alltezza View Post
Just got the clutch installed hoping to get this broken in before we get the kit installed
What catch cans are you guys running?
I just run JDL's catch can. Convenience and price.
Rybot is offline   Reply With Quote
The Following User Says Thank You to Rybot For This Useful Post:
Alltezza (06-08-2017)
Old 06-08-2017, 03:13 PM   #842
drambo136
drambo136's Avatar
Drives: 2013 Hot Lava
Originally Posted by Kris86 View Post
what is your vacuum reading at idle from your map sensor?
I'm going off memory but it think it was around 30 to 35
Sent from my SM-G955U using Tapatalk
drambo136 is offline   Reply With Quote
The Following User Says Thank You to drambo136 For This Useful Post:
Kris86 (06-08-2017)
Old 06-08-2017, 03:17 PM   #843
Kris86
Kris86's Avatar
Drives: RHD Gt86
Originally Posted by Amputechture View Post
Same here. I just took mine off as it was causing a big ass vacuum leak.
what exactly caused a big vacuum leak? what did u take off
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
Old 06-08-2017, 07:21 PM   #844
Amputechture
Drives: 2014 BRZ
If I remember correctly I stated this in reference to the crawford air oil separator.
Amputechture is offline   Reply With Quote
The Following User Says Thank You to Amputechture For This Useful Post:
Kris86 (06-08-2017)
Old 06-15-2017, 08:59 PM   #845
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
I'm scheduled for an install Monday! I can't wait......
Alltezza is offline   Reply With Quote
Old 06-24-2017, 08:36 PM   #846
jlim86
Drives: White FRS
Upgrade My V1 turbo
Hey guys i have the v1 turbo kit with the base Precision 48mm. Does anyone know if i can upgrade to the Garrett GTX2860 gen 2?
jlim86 is offline   Reply With Quote
Old 06-25-2017, 12:41 AM   #847
Evil Rocky
Drives: FRS
Jlom86- with the precision turbo kit how was it? Any issues?
Evil Rocky is offline   Reply With Quote
Old 06-25-2017, 04:08 AM   #848
ft86me
ft86me's Avatar
Drives: 2013 FRS
I've gone from the precision to the 2867r and now the 3076r gen 2. What you will need to do is get a hold of Jesse or Alan at JDL and have them piece the turbo together for you so they can put it on their jig so that they can weld a vband connector on the turbo side that will match your downpipe. When I got my 2867r from their turbo company they use without having that done, it didn't fit at all. Had to send it to them and they were able to sort it out.
ft86me is offline   Reply With Quote
Old 06-25-2017, 04:16 AM   #849
jlim86
Drives: White FRS
No problems just want to upgrade. I don't like how the precision spools up, after driving other boosted 86s with different turbo setups.
Old 06-25-2017, 04:16 AM   #850
ft86me
ft86me's Avatar
Drives: 2013 FRS
Originally Posted by HawaiianMike View Post
I was Looking at purchasing a JDL Twin scroll turbo kit with a gtx2867r because I want a pretty broad power band.
Other things I would like (but may be a bit much who knows), recirculated wastegate and a high flow cat. These are because I would like to pass emissions here in NY.
I would like to know if there are two comparable dyno charts showing UEL vs twin scroll and if anyone has a cat and hows its affecting things....
Will be getting a flex fuel tune for it.
Thanks so much guys!
As another person stated, the work carb kit is the only kit that will do it for emissions.
Twin scroll and no twin scroll wont' effect much in terms of power. What you will notice is transient response which is not too noticeable. Now if you are pushing some bigger power, then you might feel a slight difference. It depends on how picky you are about transient response. Now I can tell you when I had the precision turbo vs the gtx2867r, the response was very impressive and mind you I don't have twin scroll. High flow cat is nice to have to eliminate some of the stinkyness of exhaust. I have jdl 3" op and mp with the high flow. it's a beautiful setup with lots of clearance.
Old 06-25-2017, 04:18 AM   #851
ft86me
ft86me's Avatar
Drives: 2013 FRS
Originally Posted by AllSickLike View Post
any numbers yet?
on JDL new base kit, they have hit 400hp. Saw it on IG
Old 06-25-2017, 04:18 AM   #852
jlim86
Drives: White FRS
How did you like the GTx2867 compared to the Precision? And comparing the 2867 to the gen 2 3076R?
Old 06-25-2017, 04:18 AM   #853
ft86me
ft86me's Avatar
Drives: 2013 FRS
Originally Posted by Rybot View Post
I had seen this as well once I bought my Perrin mounts.
I wrapped them in exhaust wrap and heat shielding before install.
Wrap is underneath the shielding and a few stainless steel bands are loosely tightened around to make sure it doesn't work its way off the mounts.
I did the same thing! Should help a lot!
Old 06-25-2017, 04:25 AM   #854
ft86me
ft86me's Avatar
Drives: 2013 FRS
THe gtx2867r was a HUGE difference over the precision and I also had a stupid oil leak from the turbo that would not go away so I was basically forced into doing the upgrade from the precision to the garrett. I at the time had the 2867r with a .62 AR for a very fast spool time. The transient response was amazing and it spooled much quicker with the 2867r and if you're into cool spooling noises, the 2867r sounds like a fucking jet lol. The 3076r gen 2 I haven't been able to really test yet since my motor is being rebuilt. I should have the car back monday evening then off to get it wrapped. What I can tell you is that I hit 430hp on e85 with the gtx2867r, but then I windowed the block lol. I would imagine the the gtx3076r will have a good amount of lag over the 2867r since it's much larger. I opted for the 3076r gen 2 because the turbo was choking on the higher end of the rpm, but mind you I had a lower AR vs the higher one because I wanted a quicker spool. So with my goal now, I am shooting for 550-600+ hp so I need the 3076r and also have done about 98% of the supporting mods to make sure my motor and driveline would hold that power minus the trans. Careful with decisions because with a higher flowing turbo and more power, the possibilities of internal part failures becomes much higher.
The Following 2 Users Say Thank You to ft86me For This Useful Post:
Alltezza (06-25-2017), Jonathanlim (06-25-2017)
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 02:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 08:33 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 07:27 PM
