go_a_way1, MisterSheep
Old 06-24-2017, 11:46 AM   #16857
BFIFE22
BFIFE22's Avatar
Drives: 2013 GBS BRZ Limited
Originally Posted by orz View Post
Just installed the Velox throttle spacer kit. It feels toeriffic! Enjoy some of these pictures and thanks to the guys at FT86speedfactory for your customer service.
I've been looking at this but it seems pretty pricey. Was it fairly easy to get used to the new pedal position?
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
BFIFE22 is offline   Reply With Quote
Old 06-24-2017, 12:57 PM   #16858
Originally Posted by MuseChaser View Post
Thanks. All it took was 17 years of laying on my back in an inch or two of salty mud every time I had to work on a car (which used to be VERY frequently, prior to buying the FR-S), literally having to shovel the mud out of the garage every few weeks, tracking mud in the house EVERY time we went into the garage for anything... eventually, I got sick enough of it to do something about it. Sooo.. I'm not exactly disciplined either...
OK, good upgrade on your garage ..... so far ...... now, when does it get a new roof ... ??
MuseChaser (06-24-2017)
Old 06-24-2017, 01:21 PM   #16859
Ron B Avery
Ron B Avery's Avatar
Drives: 2017 86 Coupe
Had the TRD quick shift kit installed at my dealer. A big difference. What I did not post earlier was, when I got to the dealer they had two 860's in Halo White on thel lot. My mind started racing, what if I trad my car in. And have the switch my exhaust and my springs plus my head unit over to an 860? Well that all came to a hault when I realized that they were both automatics! My sales guy was there an said they have only had one 860 stick out of 6 so far.
Ron
2017 Toyota 860 Halo White, TRD springs, TRD air filter, Center consul arm rest lid, Magnaflow cat back exhaust, Pioneer SPH-DA120 head unit with Apple CarPlay,
TRD sway bars , 17" 949 Wheels Beryllium finish, Michelin Pilot Super Sport tires, 225/45 ZR 17, Garage Vary Kouki splitter
Ron B Avery is offline   Reply With Quote
Old 06-24-2017, 01:37 PM   #16860
Teseo
Drives: frs
The Following User Says Thank You to Teseo For This Useful Post:
OrangeGuitar (06-24-2017)
Old 06-24-2017, 02:12 PM   #16861
Ashikabi
Ashikabi's Avatar
You can replace the pedal itself with a wider one. Got one (forgot brand) from ft86sf for 35$. Now I can heel-toe
Sent from my XT1575 using Tapatalk
Old 06-24-2017, 07:26 PM   #16862
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Did a standard oil change, spilled oil on the driveway while using my new ramps . Some dummy at the autoparts store gave me the wrong air filter, after 30+ mins wrestling with it I realize it's not the right size and won't sit right. I always forget to pull off that whole front intake to properly fit the filter in flush. Next time will be the time I remember, I hope. I dropped my oil cap into the engine bay :p had to fish it out and clean it off. I also spilled some coolant all over the front bumper, it's one of those days.
DandoX is offline   Reply With Quote
Old 06-24-2017, 07:37 PM   #16863
mrg666
pessimistic skeptic
mrg666's Avatar
Sorry about the oil change drama.
I can't use my RhinoGear ramps with FR-S. Bumper touches the ramp before the tires. I have scratched the bottom of bumper trying to use those ramps. What ramps are you using?
Old 06-24-2017, 08:02 PM   #16864
DandoX
Senior gif poster
DandoX's Avatar
I'm using https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
I'm a slender dude so I can get fully under the car with these ramps but only just so.
Problem is the oil pan is so tall I can't loosen the drain plug because my hand won't fit so I had to use this bowl thing and then pull the pan over quickly...., as you can imagine this created a big mess.
The Following User Says Thank You to DandoX For This Useful Post:
mrg666 (06-24-2017)
Old 06-24-2017, 08:06 PM   #16865
mrg666
pessimistic skeptic
mrg666's Avatar
My fat ass will not fit under those Back to using jack stands
The Following User Says Thank You to mrg666 For This Useful Post:
DandoX (06-24-2017)
Old 06-24-2017, 08:29 PM   #16866
Ashikabi
Ashikabi's Avatar
I have to use low ramps to get a jack under it. Y'all should be using Fumoto valves to help with the oil plug problems and whatnot
Old 06-24-2017, 08:42 PM   #16867
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
No pics but I surpassed 60k miles whilst autocrossing today, bye bye warranty, hello spark plug replacement.
ineedyourdiddly
The Following 4 Users Say Thank You to strat61caster For This Useful Post:
DandoX (06-24-2017), MasonL1997 (06-30-2017), Teseo (06-24-2017), trvth (06-27-2017)
Old 06-24-2017, 08:50 PM   #16868
mrg666
pessimistic skeptic
mrg666's Avatar
I am just afraid those valves will be dripping oil after a while.
Old 06-24-2017, 09:34 PM   #16869
Syche
Syche's Avatar
Drives: 2013 Black FR-S 6A
I put in some Speed Demon H11 replacements in low beam here is a pick of the difference left stock and right is the 6000K speed demons, did an oil change and tire rotation.
Also ordered my reverse, licence plate, and dome lights.
Originally Posted by 22R View Post
Now get off your Mom's computer and go wash the BRZ she bought you.
22R
Syche is offline   Reply With Quote
Old 06-24-2017, 10:32 PM   #16870
Ashikabi
Ashikabi's Avatar
Shouldn't, they are all metal and don't get opened very often. It's up to you though
