#2381 | |
Drives: 2014 BRZ
#2382 |
Drives: none
It's possible you didn't properly bleed the coolant system and have an air bubble trapped somewhere. Did you fully drain the coolant as described in the installation manual?
Sent from my XT1650 using Tapatalk |
#2383 |
Drives: 2013 FRS
Most likely you've still got air in the coolant system. I'd bleed again with a spill free funnel. Don't forget about the bleed screw behind the supercharger.
You know it's bleed right if you're getting hot air through the heater system. Sent from my Nexus 6 using Tapatalk |
#2384 | |
Drives: 2014 BRZ
Yes you were exactly right, thank you very much, I successfully purged like the air from the engine coolant system, just to double check though, is there a trick to be sure all air is purge from the surge tank? I appreciate your quick response, very helpful |
#2385 |
Drives: 2013 FRS
Surge tank doesn't require bleeding, just make sure you don't let the surge tank run dry.
#2386 |
Drives: 2014 BRZ
#2387 | |
Drives: 2013 Subaru BRZ
#2388 | |
#2389 | |
It took me three weeks of rigorously checking the header tank daily and topping it up with coolant before it finally settled down and stayed full. You cannot fill it when it's hot because the header tank is pressurized and "boils over". Even when cold gravity is not your friend. I found opening the cap when the engine was cold and switching on the ignition but not the engine activated the coolant pump drawing down the coolant in the header tank which allowed about 4oz of coolant to be added. Close the cap and drive. Then repeat the following morning and so on until the coolant overflows a bit when you release the cap when cold. Normal level when cold is about halfway up the header tank. There's no issue with low coolant in the header tank other than intercooler efficiency. The coolant pump cares not if there's a bit of entrained air. But until the header tank is filled above the flow hoses you cannot get full power. |
| The Following User Says Thank You to Gforce For This Useful Post: | sato (06-21-2017) |
#2390 | |
Drives: 2014 BRZ
Thank you Gforce and Zut for your information, yall were very helpful. Does anybody know, on a stock engine, how small of a pulley could it handle... Safely? |
#2391 |
People generally serm to think something less than 300 bhp at the crank is the most the factory rods can handle. Cosworth holds this view. I imagine Edelbrock would know this. They (and Harrop in Australia) opted for the 1320 Eaton blower internals which is designed for 2.2 - 4.2 litre engines. Cosworth went with the 900 designed for 1.5 to 2.9 litres engine capacity. Obviously, everybody knows this engine could take more boost but have not yet issued an upgrade pulley and software. Makes you wonder why not?
#2392 | |
Glorious BRZ Master Race
Drives: Subaru Libird
| The Following User Says Thank You to switchlanez For This Useful Post: | Trefoil (07-07-2017) |
#2393 |
Supercharger thermal efficiency is related to size. The TVS 1320 in the Edelbrock kit is just loafing along. Audi and Jaguar fit that size to their 3.0 engines.
I think Edelbrock was designing for road use where the engine runs more of the time at low rpm. Since these superchargers deliver a constant volume of air per revolution (positive displacement, an air pump) the larger volume of the 1320 would tend to work better than the TVR 900 lower in its rpm range giving better drivability at the mid range typically used in North America. Driving conditions in Australia tend to be more similar to those in North America than in the UK so Harrop's choice of the same size may support my conjecture. Certainly the Edelbrock kit transforms this engine from a high rpm screamer to an engine with solid mid range punch. Remarkably this supercharged version still revs usefully right through its redline, were it not for the limiter. Incidentally, the Edelbrock limiter is fully soft as I discovered recently at a stop light. I really did need the other guy's lane and he seemed determined to cut me off.....I thought it strange that I overhauled and passed him but then stopped making gains...stuck on the limiter in second for a brief moment and didn't realize it right away. Pretty smooth limiter. |
| The Following User Says Thank You to Gforce For This Useful Post: | CSG Mike (06-21-2017) |
#2394 |
Drives: 2015 BRZ, 2005 STI, 2024 Type R
I need to access the high pressure side port of the AC system and it looks to be way too close to the supercharger, anybody have any tips on accessing the port?
I would be doing a full AC recharge and would need the car to be running in order to spin the compressor, so I can't just unbolt the supercharger and leave it floating. |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
