| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 | |
Does the master cylinder brace have any cons? Damn I'm researching about this now! I do need new pads too. I was looking at a set of hawk hps. Or maybe even trying out the trd ones. Sent from my iPhone using Tapatalk |
#16 | |
Off Topic
For brake pads and fluid, talk with @CSG Mike about your expected usage and see what he recommends. |
#17 |
I've been experimenting with extreme stock brake system usage, and would recommend a BBK for track use.
That being said, I've *actually* warped stock replacement rotors, and have completely obliterated the outer dust boots. I've also seen caliper temps that are dangerously high (3x maximum recommended temperatures), and the only solution I've found that holds is using a $1516 set of racing pads. |
#18 | |
Off Topic
#19 |
Drives: 2014 FR-S
It all depends on what you want to do with your car. From what it sounds like you want to keep the car agile, maybe some tail swinging every now and then, but still be planted on the back country turns.
As far as new rims go, if your budget is some Rotas Grids dont get them. They are heavy, especially with an 18" wheel. As said this will make your feel like crap. Now if you can get some RPF1s, MT03s, GTX01s or something light like that then go ahead. If you size a good light weight 18" wheel with the correct tire, that is not to wide, it will be about the same weight as stock. But more so if you get a light weight 17" you will be way under stock weight. With that said, my suggestion is to stick with the stock wheel for now, wrap them in a good tire, and get your suspension. I just got Tein Flex Zs and they are great, sitting on stock wheels and tires too for now. Painted my wheels metallic gray and they look good. |
#20 | |
I've heard nothing but good things about flex zs I think I'm Guna keep my stock rims and get mpss on em. Thanks for all your help guys Sent from my iPhone using Tapatalk |
#21 |
Only happy when it rains.
Drives: series.blue
Since no one else answered this, only go coilovers if you really really like playing with all the different settings to see what works best for you. Otherwise they are overcomplicated and overkill for a car not being tracked. After the tires if you really think the suspension needs to be upgraded their are literally tons of options that will make it better handling and still keep the stock shocks and springs. And after researching those if you still want to upgrade the shocks and springs there are several options that do it without the craziness of going all adjustable everything.
| The Following User Says Thank You to why? For This Useful Post: | Gforce (06-09-2017) |
#22 | |
*Some really cool title*
Lighter wheels is 100% worth the investment. And I didn't say you had to spend as much as a grand. I'm in the process of negotiating for a set of wheels that weigh 15.8 lbs each, and the guy is asking for $500. You can get good deals if you look for them. Coilovers are mainly for #stancenation (and I use that term loosely) purposes and you won't feel much of a difference performance-wise from stock with them. Shaving 5 pounds off each corner is something that you can actually feel while driving. |
#23 |
Drives: 2017 Series.Yellow
I have done lots of research lately because I want to replace my OE wheels and tires. I found light weight 18x8 wheels work the best, because you can fit in 225 grippy tires. It will still be lighter than OE at each corner. 17x7.5 with 225 is also acceptable but i don't like the look myself. So I would say 18x8 would be a good compromise between handling performance and appearance.
#24 |
17 inch vs 18 inch
This just got confusing lol. I've heard people raving about how coilovers transform the car. I'm not doing no stancednation crap because I daily my car and I don't want to dodge roads because of it being too low. I don't mind stiffness. Wouldn't 17 inch lightweight be better because you can probably get them a lot lighter than 18 inches ? I don't want to ruin the agility of the car
My focus is handling Sent from my iPhone using Tapatalk |
#25 |
Drives: 2014 GT86
artongdou: and 17x8 don't exist, right?
If you need specific width for best specific width tire fitment, it has nothing to do to diameter of wheels.
#26 | |
Drives: series.blue
And the smaller the wheels the better. Like that person said, 18 is only for looks. I think I might go 16x7 when I finally buy wheels, because I want the lightest I can buy. |
#27 | |
Drives: GT86 Harrop S/C
For the OP, I'm supercharged at 240wheel and I find that stock rims with good tyres (PS4s) is enough grip. Would like to save some weight with the wheels, but not sure if it's worth the cash needed for a good set of 17s. With the brakes - stock ones were pathetic on track so I got a front BBK |
#28 |
As usual, stuff like this all comes down to what you plan on using the car for. If the car will be used mainly for daily driving/showoff stuff then 18' wheels and coils might be worth it simply for the looks. If you want to do any fast or spirited driving and have the best setup, keep stock suspension and get lighter wheels and better tires. Or do a mix and do a little bit of both things. It's up to you.
| FS: Weathertech mats, Staggered 18 inch Rims and tires, 17 inch winter tires | Tdot | Canada Classifieds | 19 | 02-20-2017 11:18 PM |
| Blowout Sale Ambit Wheels 5x100 17 Inch & 18 Inch!! | JonMotoring | Wheels and Tires | 14 | 11-16-2015 07:24 PM |
| ft Perrin exhaust 2.5 inch for 3 inch | FISHBURGLAR | Engine, Exhaust, Bolt-Ons | 1 | 08-03-2015 08:30 PM |
| 17 inch in the front, 18 inch in the back ? | brz_fan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 06-16-2014 10:35 PM |
| Help! Two 10 inch vs One 10 (or 12) inch | cyntage | Electronics | Audio | NAV | Infotainment | 7 | 09-28-2012 12:20 AM |
