Sam Strano
Old 06-06-2017, 11:40 AM   #4607
JermMX5
Drives: 2017 Toyota 86
Originally Posted by Cueman View Post
-1.8 seems a bit beyond the norm, but I think you should be able to find a degree and a half with a jack and some ratchet straps.
So what does this mean exactly? Is there a guide anywhere on what I'm trying to stretch out?
2017 Toyota 86 - Whiteline 20mm Front Bar | Crash Bolts | 235/45/17 RE-71R | 17x7.5 OZ Omnia | OFT Stage 1 For Street Driving | Trackpipe for AutoX | Not enough camber.
JermMX5 is offline   Reply With Quote
Old 06-06-2017, 11:41 AM   #4608
Biggins
Drives: Yes
I sprayed at least the front on RE71Rs after each run when the weather is hot. I did not seen many people spraying the BFG 1.5s or the new Hankook RS4s (quite fast tire) at our 90* event on Sunday.
There is never enough water to cool down my V720s on a very hot day, but they still give competitive times if I can get them cool enough.
Biggins is offline   Reply With Quote
Old 06-06-2017, 01:07 PM   #4609
TrqlessWonder
Drives: 2014 FR-S
It's not a stretching things out thing. None of the joints you're moving around in have any bushings. It's a keep-things-in-the-right-spot-while-I-use-both-hands-to-tighten-this-down thing. You're taking advantage of slop in bolt holes, not changing the shape of hard parts.
If you're on Koni's, it's crash bolt with centering washer in the top hole, loosen both top and bottom up, move things so that the top arm is as far inboard as possible, tug outward at the bottom for any slop that might be there, find out how to hold it there (a second set of hands is useful), and then tighten back down. 1.7-1.8 is about what you get out of that. If it's factory struts, remove the reference to the centering washer.
If you want to chase the miniscule rest, pop the hood, loosen the three nuts up top, move those inboard and re-tighten.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 06-06-2017, 02:57 PM   #4610
simpleisbest
Senior Citizen
Drives: Scion FR-S
Mechanically speaking, if the Koni full replacements are getting actual -1.7 or more then they are still probably not legal. Technically the spacer should be used in the upper front hole. That is supposed to be the smaller of two and that is what the spacer was supposed to correct. If the internal diameter of the spacer is larger than OEM (w/crash bolt) or the location of the spacer's hole (due to fitment slop or misalignment), then you could protest it as illegal. I would guestimate that to get anywhere -1.7 or -1.9ish on the car, you would need to get about 0.5mm more than OEM. The most I was able to get on my last 2 sets of Street legal struts was about -1.3 to -1.4 depending on the alignment rack at 0 front toe.
These cars do not gain front camber from right height, so any gains are though geometry, ie mounting hole locations or size.
simpleisbest is offline   Reply With Quote
Old 06-06-2017, 03:07 PM   #4611
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
As much as I hate to say it, because it'd mean spending more money and time on the suspension again, I'm wondering if variance in drilling out the upper strut mount to accommodate the larger shaft size of the Konis is what's causing these variances in extra camber. I imagine a lot of people, like myself, are going this in a garage without the most precise measurements, and often late at night frustrated/tired.
I know when installing my Konis we did our best to only drill the hole out enough to work, but didn't having use the most precise tools/methods available since it was a job done in my buddy's garage. I could see where slight differences in how the upper strut mounts were drilled out could account for added camber.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
simpleisbest (06-06-2017)
Old 06-06-2017, 03:11 PM   #4612
simpleisbest
Senior Citizen
Drives: Scion FR-S
Drilling of the top hats is only done in the rear.
The fronts use a bearing, so no drilling possible.
The Following User Says Thank You to simpleisbest For This Useful Post:
Shark_Bait88 (06-06-2017)
Old 06-06-2017, 03:58 PM   #4613
Shark_Bait88
That's right, disregard my previous statement. Running on very little sleep, so not operating at 100%. haha
Old 06-06-2017, 04:36 PM   #4614
M0nk3y
Best of luck trying to protest with that logic
The Following 2 Users Say Thank You to M0nk3y For This Useful Post:
DocWalt (06-06-2017), renfield90 (06-07-2017)
Old 06-06-2017, 05:27 PM   #4615
JermMX5
I mean the rule is pretty clear...
"Suspension geometry and alignment capability, not including ride height, may not be altered by the substitution of alternate shock absorbers."
The konis are changing the alignment capability are they not?
Old 06-06-2017, 05:31 PM   #4616
Shark_Bait88
It was proven that they were with just the standard full replacement. The washer insert was supposedly a fix to bring them into OEM spec. So if people are questioning it, then someone will have to take the measurements and prove it, like what was originally done with the full replacements.
The Following 2 Users Say Thank You to Shark_Bait88 For This Useful Post:
CCJ (06-06-2017), DocWalt (06-06-2017)
Old 06-06-2017, 06:29 PM   #4617
M0nk3y
Degassed shocks can lower the car and thus gain camber from lowering.
It's a McPherson front. Of course you're going to gain camber on any height change.
Kyle H. - #89 STX
Old 06-06-2017, 07:11 PM   #4618
simpleisbest
Senior Citizen
Drives: Scion FR-S
smh lol
Old 06-06-2017, 07:13 PM   #4619
M0nk3y
smh lol
Go ahead and start protesting every ND in CS that is lower than OE and running -2.5* of camber and is completely legal.
I'll wait here and enjoy my popcorn
Kyle H. - #89 STX
Old 06-06-2017, 07:32 PM   #4620
simpleisbest
Senior Citizen
Drives: Scion FR-S
please go educate yourself on MacPherson struts.
NDs are double wishbone....yeah not sure what the NDs have to do with the front MacPherson struts and camber gain, but I'm sure you do
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
