Old 05-15-2017, 05:25 PM   #141
FRS Justin
Drives: 2013 Asphalt FRS
Originally Posted by Kris86 View Post
no we did the compression test when the engine was cold. just swinging the engine.
not sure about the crank case pressure tho :-S, would you mind explaining to me how to go about checking this?? I have in the Radium DUAL catch can set up, which are vented to atmosphere.
it has not pushed any coolant out what so ever.
ive been suggested that it would either be bent valves ( when engine wasn't timed correctly first) or maybe rings ground to much. :-(
I appreciate your help
Before you pull the engine air up the cylinder and listen for blow by. Listen to the intake, exhaust, and the crankcase.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
Kris86 (05-16-2017)
Old 05-15-2017, 05:35 PM   #142
FRS Justin
Looks like we are gonna be pulling the motor :-( @FRS Justin @GsxrMe @Yoda @Moto-Phil
My mechanic thinks maybe the rings could have been cut to wide possibly, so he said he will get the rings and replace them. We have no vacuum leak, we have back check everything possible. We did the compression test and came up with this
Piston 1 - 95
Piston 2 - 90
Piston 3 - 98
Piston 4 - 93
Even though I'm running 9:0:1 compression I shouldn't be seeing such low results
They are all fairly equal which leads me to believe its in the heads or timing components
710whp
Kris86 (05-16-2017)
Old 05-21-2017, 12:35 PM   #143
Kris86
Kris86's Avatar
Drives: RHD Gt86
So, after not finding anything externally, we pulled the motor :-(
Upon inspecting the rings we found they were indeed cut a bit to big, not drastically. We replaced them and cut them over correctly and have put the engine back in last night and stared her up this morning.
Still, on intial cold start up it will not idle by itself, but after a while it definitely got to idle unassisted a lot quicker than before.
Still doesn't sound like I've fixed the problem :-(
My next step is thinking of flying in my tuner I don't know what else to do
Mechanic thinks it could be tuning related
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
Old 05-21-2017, 12:36 PM   #144
Kris86
Kris86's Avatar
Drives: RHD Gt86
We did this when we pulled the engine out, we could hear it going down into the crank case
Old 05-21-2017, 12:37 PM   #145
Kris86
Kris86's Avatar
Drives: RHD Gt86
NONE of the pistons had any marks on them to indicate there would be any bent valves
Old 06-01-2017, 12:00 PM   #146
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Anything new @Kris86 ?
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Kris86 (06-05-2017)
Old 06-01-2017, 12:02 PM   #147
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
When you replaced the valve springs, did you lap each valve, maybe its you head and valves not seating correctly?
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
The Following User Says Thank You to GsxrMe For This Useful Post:
Kris86 (06-05-2017)
Old 06-01-2017, 02:08 PM   #148
Dipstik-sportech
Dipstik-sportech's Avatar
The initial startup rough idle is caused by it firing up on larger than stock port injectors. Mines done it for years, you get use to holding the throttle a bit for 20-30sec until it kink onto the direct injectors.
Old 06-05-2017, 02:43 PM   #149
Kris86
Kris86's Avatar
Drives: RHD Gt86
Wish I knew what to say
Do u know if something is wrong with Delicious Tuning? Or maybe they are just point blank avoiding me.
Been trying to get in contact with them about a log I sent them since the 27th of may
Old 06-05-2017, 02:44 PM   #150
Kris86
Kris86's Avatar
Drives: RHD Gt86
Yes we made sure we did this process with precision... we made sure all valve shims were gapped correctly
Old 06-05-2017, 02:46 PM   #151
Kris86
Kris86's Avatar
Drives: RHD Gt86
Pretty sure is isn't supposed to be this bad... to me it needs more fuel at idle. Especially on cold start
Old 06-05-2017, 02:55 PM   #152
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
?? I didn't have this issue on my ID1000s. Not even on E85 in below freezing weather. Possibly tune related...
The Following User Says Thank You to DustinS For This Useful Post:
Kris86 (06-05-2017)
Old 06-05-2017, 03:38 PM   #153
Sportsguy83
Drives: Limited BRZ
Me neither but he's running 2000cc injectors, really don't know if it makes htat much of a difference.
DustinS (06-05-2017)
Old 06-05-2017, 03:38 PM   #154
Sportsguy83
Drives: Limited BRZ
I particularly don't know. Hope you get a reply soon.
Who's tired of the "Pedal Dance" and wants to be in real control of their car? FT-86 SpeedFactory Tracking / Autocross / HPDE / Drifting 61 10-01-2015 08:44 PM
I drive fast because the car feel "slow" fang_gt86 Scion FR-S / Toyota 86 GT86 General Forum 65 05-04-2015 02:06 PM
Most effective ways to make a "fast" NA car Kronos Engine, Exhaust, Transmission 68 02-16-2014 02:59 PM
XSXV: Nissan R34 Skyline from "Fast and Furious" goat_cheese Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 29 10-25-2012 05:15 PM
come and hoon they say.... it will be "like Fast and the Furious", they say... davey90 AUSTRALIA 5 10-23-2012 01:11 AM
