Old 07-02-2012, 12:44 PM   #1
Lil Abner
Drives: 2013 FR-S, 6MT, Ultramarine
Exclamation HELP: Need Tach Signal!!
Does anyone know where I can get a tach signal inside the car? I would rather not grab a signal off the engine. There has to be a signal at the Body ECU, but my o-scope is broke so I can't find it.
Any help is appreciated!!
Lil Abner is offline   Reply With Quote
Old 07-02-2012, 01:12 PM   #2
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
There isn't one.
Sorry.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 07-02-2012, 01:20 PM   #3
Lil Abner
I don't believe that. There has to be a tach signal for the OEM tachometer in the gauge cluster. Unless it's in a data stream from the engine bay...
Old 07-02-2012, 01:26 PM   #4
Reason
Reason's Avatar
Drives: Whiteout 6MT FR-S; E30 BMW's
Here you go: http://www.ft86club.com/forums/showthread.php?t=10292
Originally Posted by jedibow View Post
Thank you Don!
So that everybody will know, the tach wire is located behind the drivers side cylinder head, there is a harness with black, and black and grey wires this is where you need to clamp.
Should be able to follow that to its termination, however it very well may terminate in the engine bay into a control module, and not go all the way to the ECU in the cabin.
Reason is offline   Reply With Quote
Old 07-02-2012, 01:46 PM   #5
Lil Abner
Hmm. Thanks, but still not helping. I'm hoping someone knows what pin on the Body ECU under the dash is the tach signal. I hate splicing into wires in the engine bay.
Old 07-02-2012, 01:49 PM   #6
Jeff Lange
Jeff Lange's Avatar
The tach signal is communicated between the Engine ECU and Gauge Cluster, etc. on the CAN BUS. There is no single wire for tach, it is a data stream.
I didn't just guess before I posted, I looked it up first.
Jeff
The Following User Says Thank You to Jeff Lange For This Useful Post:
civicdrivr (07-02-2012)
Old 07-02-2012, 01:51 PM   #7
Lil Abner
Jeff
Ok, thanks. I guess I'll do some solder/heat shrink under the hood...
Old 07-02-2012, 01:52 PM   #8
vividracing
vividracing's Avatar
Why do you not want to grab the tach signal in the engine bay? With a little spray silicone you should be able to run the wire through an existing hole in a grommet.
vividracing is offline   Reply With Quote
Old 07-02-2012, 01:57 PM   #9
Lil Abner
I actually already have wires run into the engine bay for the tach wire as well as for my amp. I just dislike tapping into a wire under the hood with the Michigan/Ohio winters. But since that's the only source, then I'll have to run with it.
The schematic I'm using shows 4 tach signals on the passenger side large connector. So I'm going to try those.
Old 07-02-2012, 02:20 PM   #10
PrimeMotoring
PrimeMotoring's Avatar
Drives: FRS with 2jz, 2015 STI 9.68@147
If theres a red/black at the obd 2 connector you can get tach there.
PrimeMotoring is offline   Reply With Quote
Old 07-02-2012, 02:23 PM   #11
vividracing
Oh yeah, I forgot winter even existed. We have a few months out of the year that require a hoody and jeans but that's it.
The Following 2 Users Say Thank You to vividracing For This Useful Post:
ftc~brz (01-23-2014), SirBrass (01-20-2014)
Old 07-02-2012, 02:26 PM   #12
Jeff Lange
Jeff Lange's Avatar
Looking into it further, it looks like the ECU has a dedicated "TACH" output signal, pin A35-15 on the ECU. This is the 35-pin connector.
It probably heads over to the DLC2 connector or something, because it isn't heading to any other systems in any of the wiring diagrams which is where I initially checked. Every other ECU, etc. uses the CAN-BUS to get the tach signal, but as I said there is an output dedicated to it on the ECU. It's not shown in any wiring diagrams, but it is mentioned in the RM.
Nice of them to do that.
Jeff
gmookher (09-28-2012)
Old 07-04-2012, 12:40 PM   #13
xcelir8brz
Drives: 2013 BRZ Limited
subscribed.
xcelir8brz is offline   Reply With Quote
Old 07-04-2012, 04:20 PM   #14
cruzinbill
Drives: Argento 6spd FR-S
subd as well... if jeff lange is on top of this research it will be no time at all till a definitive answer. Guy knows his shit.
cruzinbill is offline   Reply With Quote
BRZ NAV system GPS signal issues? DigDloppyFonkeyBick Electronics | Audio | NAV | Infotainment 73 06-07-2016 03:14 AM
Turn Signal Repeaters Ben_G Cosmetic Modification (Interior/Exterior/Lighting) 1 06-22-2012 11:26 PM
BRZ signal light bulb ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 8 06-20-2012 02:26 AM
Scion FR-S Tach Sweep Video F1point4 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 06-15-2012 04:53 PM
plastic in front of tach feldy Cosmetic Modification (Interior/Exterior/Lighting) 8 06-10-2012 01:03 AM
