#155 | |
Drives: 2016 BRZ
This works exactly like that with this radiator, you will always have oil left inside the lines and radiator, but everytime you change the oil, you will probably get liek 70% of it out, so every time you do 2 oil changes, you are basically changing more than 100% of the engine oil. hope this helps
#156 | |
Drives: Q5 + BRZ + M796
#157 | |
Drives: Scion FR-S
It was installed by a reputable installer and the kink was really minimized. I believe installer even called JR to ask about the hose kinking issue. The soft bend area broke. I guess the rubber inside just get hardening overtime and break at some point. So even a soft bend is not safe. Hope Jackson Racing can solve this issue. |
| The Following 2 Users Say Thank You to Jojo-frs For This Useful Post: | Pekingduck (05-27-2017), TkTk (05-28-2017) |
#158 | |
Drives: Subaru BRZ / Toyota 86 Experts
#159 | |
Drives: 2014 TRD GT86 CUP, 2014 991 GT3
Braided Steel Lines
I had similar failure using the same lines. Hope Jackson Racing offers braided steel lines as an option for this kit.
#160 |
Drives: 86
I went to install this kit a year ago and found the lines to be unacceptable. The shorter line had a kink regardless of how it was installed. Line failures like the one shown above aren't surprising.
Just built my own lines using Earl's ultra pro nylon braided hose and fittings. Hoses are PTFE lined and have a 2 inch bend radius so they can tolerate tight bends without folding or losing shape. The dual radiator should have came from the factory with these lines... Two hoses are compared below, bent the same amount. |
| The Following 9 Users Say Thank You to Colin86 For This Useful Post: | CounterSpace Garage (05-29-2017), CxG (01-10-2018), Espi (07-05-2020), JDM4E (05-29-2017), Kestrel (05-28-2017), Rosticles (05-29-2017), sato (05-29-2017), TheMedakaBox (08-09-2017), TofuJoe (07-21-2017) |
#161 |
Drives: 86
Other than the lines the kit has been great!!
| The Following 2 Users Say Thank You to Colin86 For This Useful Post: | CounterSpace Garage (05-29-2017), CxG (01-10-2018) |
#162 |
Drives: 2015 FRS
Agreed. Coming off track with coolant temps right at 200* F (highway stays around 190*). Those hoses look nice though. Kinda feeling the need to switch to those before problems come up.
Sent from my Pixel using Tapatalk |
| The Following 2 Users Say Thank You to Reamer For This Useful Post: | CounterSpace Garage (05-29-2017), Harvie1031 (05-29-2017) |
#163 |
Drives: Honda Accord Euro
A few questions
![]() 1) is the radiator deeper than stock to the engine area? (read: will it fit JDL EL catted longtube header?) 2) any disadvantages or concerns for daily use? I am thinking of this piece as another step from Forester water/oil cooler. I live from -30 °C to +30 °C, daily, spirited, and 20 mins max. occasional track sprints. Also if this warm up the oil even faster than Forester cooler, than great. I don't want dedicated air-oil cooler because of winter hassle 3) any chance JacksonRacing will reconsider and provide better quality hoses as mentioned above? 4) can you see the JacksronRacing logo from the front of the car? If so, can it be removed or somewhat erased? Nothing about the brand, just OEM stealth look for me. Thanks |
#164 |
Drives: 2016 Hyperblue Brz
Is there any way to drain the oil from this cooler during oil change?
#165 |
How does the oil cool? Does the coolant veins go into the side of the radiator with the oil chamber or does the chamber on the side just have the side of the radiator to come into contact with it. Is there a cross section pic to better understand what is going on?
| The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post: | jbailey8748 (05-25-2018), JDM4E (06-04-2017) |
#166 |
Senior Citizen
Drives: 2015 WRB BRZ
Damn...was just about to pull the trigger on this kit, seems like the perfect compliment to my Edelbrock S/C.
Now I'm afraid the line is going to bust, lose oil and destroy my motor....
| The Following User Says Thank You to Dan37BRZ For This Useful Post: | Harvie1031 (06-04-2017) |
#167 | |
Does anyone know if this is an improvement over the Forester XT cooler mod with a larger radiator? Sent from my iPhone using Tapatalk
#168 |
Drives: FRS
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing Scion FR-S & Subaru BRZ Dual Radiator/Oil Cooler | Jackson Racing | Engine, Exhaust, Bolt-Ons | 0 | 04-25-2016 06:35 PM |
| Jackson Racing Oil Cooler, NA, NEW IN BOX, NEVER INSTALLED. | OkieSnuffBox | Engine, Exhaust, Bolt-Ons | 5 | 01-12-2016 12:26 PM |
| Jackson Racing Supercharger and JR Oil Cooler | bobsacamenoh | Engine, Exhaust, Bolt-Ons | 20 | 12-12-2014 03:00 AM |
| Jackson Racing oil cooler for NA vs FI | ayau | Engine, Exhaust, Transmission | 1 | 05-29-2014 12:04 PM |
